Hieronder vind je een tabel met daarin de 4000 serie IC's.
| Nummer | Pinnen | Omschrijving |
4000 4001 4002 4006 4007 4008 4009 4010 4011 4012 4013 4014 4015 4016 4017 4018 4019 4020 4021 4022 4023 4024 4025 4026 4027 4028 4029 4030 4031 4032 4033 4034 4035 4038 4040 4041 4042 4043 4044 4045 4046 4047 4048 4049 4050 4051 4052 4053 4054 4055 4056 4060 4063 4066 4067 4068 4069 4070 4071 4072 4073 4075 4076 4077 4078 4081 4082 4085 4086 4089 4093 4094 4095 4096 4097 4098 4099 4502 4503 4508 4510 4511 4512 4514 4515 4516 4517 4518 4520 4527 4529 4532 4536 4538 4541 4543 4555 4556 4582 4584 4585 4724 40085 40097 40098 40100 40101 40102 40103 40104 40105 40106 40107 40108 40109 40110 40147 40160 40161 40162 40163 40174 40175 40181 40182 40192 40193 40194 40257 |
14 14 14 14 14 16 16 16 14 14 14 16 16 14 16 16 16 16 16 16 14 14 14 16 16 16 16 14 16 16 16 24 16 16 16 14 16 16 16 16 16 14 16 16 16 16 16 16 16 16 16 16 16 14 24 14 14 14 14 14 14 14 16 14 14 14 14 14 14 16 14 16 14 14 24 16 16 16 16 24 16 16 16 24 24 16 16 16 16 16 16 16 16 16 14 16 16 16 16 14 16 16 16 16 16 16 14 16 16 16 16 14 8 24 16 16 16 16 16 16 16 16 16 24 16 16 16 16 16 |
Dual 3-Input Nor Gate
Plus Inverter Quad 2-Input Nor Gates Dual 4-Input Nor Gates 18-Bit Static Shift Register Dial Complimentary Pairs Plus Inverter 4-Bit Binary Ful Adder Hex Inverting Buffers Hex Buffers Quad 2-Input Nand Gates Dual 4-Imput Nand Gates Dual D Flip Flop With Set/Reset 8 Stage Static Shift Register Dual 4 Stage Static Shift Register Quad Bilateral Switches Decade Counter With 10 Outputs Presettable Divide-By-N Counter Quad And-Or Select Gates 14 Stage Binary Ripple Counter 8 Stage Static Shift Register Octal Counter With 8 Outputs Triple 3-Input Nand Gates 7-Stage Binary Counter Triple 3-Input Nor Gates Bcd Decade Counter, 7-Segment Decoder Dual J-K Master Slave Flip Flop Bcd To Decimal Decoder Presettable Up/Down Counter Quad Exclusive-Or Gates 64- Stage Shipt Register Triple Positive Logic Serial Adders Bcd Decade Counter, 7-Segment Decoder 8-Bit Bi-Directional Shift Register 4-Stage Parallel In/Out Shift Register Triple Negative Logic Serial Adders 12-Stage Binary/Ripple Counter Quad True/Complement Buffers Quad Clocked D-Latch Quad Nor R-S Latches (3-S) Quad Nand R-S Latches (3-S) 21-Stage Binary Counter/Divide W/Oscillator Micropower Phase-Locked Loop Monostable/Astable Multivibrator 8-Input Expandable Multifuntion Gate Hex Inverting Buffers/Converters Hex Buffers/Converters 8-Channel Mux/Demux Differential 4-Channel Multiplexer Triple 2'channel Multiplexer 4-Segment Lcd Driver Bcd To 7-Segment Decoder Lcd Bcd To 7-Segment Decoder Lcd Driver 14-Stage Binary Counter W/Osc. 4-Bit Magnitude Comparators Quad Bilateral Switches 16-Channel Analog Mux/Demux 8-Input Nand/And Gate Hex Inverters Quad 2-Input Exclusive-Or Gates Quad 2-Input Or Gates Dual 4-Input Of Gates Triple 3-Input And Gates Triple 3-Input Or Gates Quad D-Type Flip Flop Quad 2-Input Exclusive-Nor Gates 8-Input Nor/Or Gates Quad 2-Input And Gates Dual 4-Input And Gates Dual 2-Wide 2-Input And-Or-Invert Gates Expandable 4-Wide 2-Input And-Or-Invert Cascadable 4-Bit Binary Rate Multiplier Quad 2-Input Nand Schmitt Trigger Cascadable 4-Bit Binary Rate Multiplier Gated J-K Master Slave Flip-Flop Gated J-K Master Slave Flip-Flop Differential 8-Channel Mux/Demux Dual Monostable Multivibrators 8-Bit Addressable Latch Hex Strobed Inverting Buffers Hex Buffers (3-S) Dual 4-Bit Latchers Bcd Up/Down Counter Bcd To 7-Segment Latch/Decoder/Driver 8-Channel Data Selector/Multipexer 4-Bit Latch/4-To-16 Line Decoder/Demux 4-Bit Latch/4-To-16 Line Decoder/Demux Presettable 4-Bit Binary Up/Down Counter Dual 64-Stage Static Shift Register Dual Bcd Decade Counters Dual 4-Bit Binary Counters Cascadable Bcd Decade Rate Multiplier Dial 4-Channel Data Selector/Mux 8-To-3 Line Priority Encoder Programmable Timer Dual Retrig. Monostable Multivibrator Programmable Oscillator/Timer Bcd To 7-Segment Latch/Decoder/Lcd Driver Dual Binary To 1-Of-4 Decoder/Demux Dual Binary To 1-Of-4 Decoder/Demux Look-Ahead Carry Generator Hex Schmitt Trigger 4-Bit Magnitude Comparator 8-Bit Addressable Latch Cascadable 4-Bit Magnitude Comparator Hex Buffers Hex Inverting Buffers 32-Stage Static Left/Right Shift Register 9-Bit Parity Generator/Checker Presettable Sync. Bcd 2-Decade Down Conter Presettable Sync. 8-Bit Binary Down Counter 4-Bit Bidir. Univ. Shift Register 16-Word By 4-Bit Fifo Register Hex Schmitt Triggers Dual 2-Input Nand Buffers/Drivers 4x4 Multiport Register Quad Low-To-High Voltage Level Shifters Bcd Decade Up/Down Counter/Decoder 10-To-4 Bcd Priority Encoder Sync. Bcd Decade Counter W/Clear Sync 4-Bit Binary Counter W/Clear Sync. Bcd Decade Counter W/Sync. Clear Sync. 4-Bit Binary Counter W/Sync. Clear Hex D-Type Flip Flops Single Rail Output Quad D-Type Flip Flops Single Rail Output Arithmetic Logic Unit/Function Generator Look Ahead Carry Generator Sync. Bcd Decade Up/Down Couter Sync. 4-Bit Binary Up/Down Counter 4-Bit Bidir. Univ. Shift Register Quad 2-To -1 Line Data Selector/Mux |
Hieronder vind je een tabel met daarin de 7400 serie TTL IC's.
7400 7401 7402 7403 7404 7405 7406 7407 7408 7409 7410 7411 7412 7413 7414 7416 7417 7420 7421 7422 7423 7425 7426 7427 7428 7430 7432 7437 7438 7440 7442 7443 7444 7445 7447 7448 7450 7451 7453 7454 7459 7460 7470 7472 7473 7474 7475 7476 7479 7480 7482 7483 7485 7486 7489 7490 7491 7492 7493 7494 7495 7496 7497 74100 74104 74107 74109 74121 74122 74123 74125 74132 74141 74145 74148 74150 74151 74152 74153 74154 74155 74156 74157 74158 74159 74160 74161 74162 74163 74164 74165 74166 74170 74173 74174 74175 74176 74177 74180 74181 74182 74191 74192 74193 74194 74195 74196 74197 74199 74221 74247 74251 74259 74265 74273 74276 74178 74279 74283 74284 74285 74298 74351 74365 74366 74367 74368 74390 |
14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 14 16 14 14 14 14 14 14 14 14 14 16 16 16 16 16 16 14 14 14 14 14 14 14 14 14 14 16 16 14 14 14 16 16 14 16 14 14 14 14 16 14 16 16 24 14 14 16 14 14 16 14 14 16 16 16 24 16 14 16 24 16 16 16 16 24 16 16 16 16 14 16 16 16 16 16 16 14 14 14 24 16 16 16 16 16 16 14 14 24 16 16 16 16 16 20 20 14 16 14 16 16 16 20 16 16 16 16 16 |
Quad
2-Input Nand Gate Quad 2-Input Nand Gate (Open Collector) Quad 2-Input Nor Gate Quad 2-Input Nand Gate (Open Collector) Hex Inverter Hex Inverter (Open Collector) Hex Inverter Drivers (30v O/C) Hex Driver (30v O/C) Quad 2-Input And Gate Quad 2-Input And Gate (Open Collector) Triple 3-Input Nand Gate Triple 3-Input And Gate Triple 3-Input Nand (Open Collector) Dual 4-Input Schmitt Trig. Nand Hex Schmitt Trigger Inverter Hex Inverting Drivers (15 O/V) Hex Drivers (15 O/C) Dual 4-Input Nand Gate Dual 4-Input Positive And Gate Dual 4-Input Nand Gate (Open Collector) Expandable Dual 4-Input Nor Gate Dual 4-Input Nor Gate W/Strobe Quad 2-Input Nand Gate (15v 0/C) Triple 3-Input Nor Gate Quad 2-Input Nor Buffer 8-Input Nand Gate Quad 2-Input Nor Gate Quad 2-Input Nand Buffer Quad 2-Input Nand Buffer (Open Collector) Dual 4-Input Nand Buffer Gates Bcd-To-Decimal Decoder Excess-3 Decimal Decoder Excess-3-Gray Decimal Decoder Bcd-To-Decimal Decoder/Driver Bcd-7-Seg. Decoder/Driver(15v) Bcd To 7-Segment Decoder/Driver Xpan. Dual 2-Wide 2in A-O-I Gate Dual 2-Wide 2-In And/Or Inverter Gate Xpan. 4-Wide 2in And/Or Inverter 4 Wide 2-Input And/Or Inverter 2 Wide 2-3 In And/Or Inverter Gate Dual 4-Input Expanders Edge Triggered Jk Flip Flop J-K Master Slave Flip Flop Dual D Master Slave Flip Flop Dual D Flip Flop Pos. Edge Trig Quad Bistable Latches Dual Jk Master Slave Flip Flop Dual D Flip Flop Gated Full Adder 2-Bit Full Adder 4-Bit Binary Full Adder 4-Bit Magnitude Comparator Quad 2-Input Exclusive Or Gate 64-Bit Ram Bcd Decade Counter 8-Bit Shift Register Divide-By-Twelve Counter 4-Bit Binary Counter 4-Bit Shift Reg. Par. In/Ser. Out 4-Bit Right Shift Left Shift Reg. 5-Bit Par. In Par. Outshift Reg. 6-Bit Binary Rate Multiplier Dual 4-Bit Bistable Latch Gated J-K Master Slave Flip Flop Dual Jk Masterslave Flip Flop Dual J-K Pos-Edge Triggered F-F Monostable Multivibrator Retriggerable Monostable Multivibrator Dual Retrig. Monostable Multivi. Tri-State Quad Bus Buffer Quad Schmitt Trigger Bcd-Todecimal Decoder/Driver Bcd-To-Decimal Decoder/Driver 8-To-3 Line Priority Encoder 16-Line To 1-Line Multiplexer 1 Of 8 Data Selector/Multiplexer 8-Channel Data Selector Dual 4/1 Multiplexer 4-To-16-Line Decoder/Demultiplex Dual 2/4 Demultiplexer Dual 2/4 Demultiplexer (Open Collector) Quad 2/1 Data Selector Quad 2/1 Multiplexer (Inv. Out) 4-To-16-Line Decoder/Demultiplexer Synch Bcd Decade Counter W/Direct Clear Synchronous 4-Bit Counter Synch Bcd Decade Counter W/Syn. Clear Synchronous 4-Bit Binary Counter W/Syn. 8-Bit Serial-In Parallel-Out Shift Register 8-Bit Serial/Parallel-In Serial-Out Shift Reg. 8-Bit Serial/Parallel-In Serial-Out Shift Reg. 4 X 4 Register File (O/C) 4-Bit D-Type Register Tri-State Hex D Flip Flop With Clear Quad D Flip Flop With Clear Presettable 35-Mhz Decade Counter Presettable 35-Mhz 4-Bit Binary Counter 8-Bit Odd/Even Parity Generator/Checker Arithmetic Logic Unit/Function Generator Look-Ahead Carry Generator Synchronous 4-Bit Binary Up/Down Counter Synchronous Bcd Decade Up/Down Counter Synchronous 4-Bit Binary Up/Down Counter 4-Bit Bidirectional Shift Register 4-Bit Serial/Parallel-In Parrellel-Out Shift Reg. Presettable 50-Mhz 4-Bit Decade Counter Presettable 50-Mhz 4-Bit Binary Counter 8-Bit Bidirectional Universal Shift Register Dual Monostable Multivibrator Bcd-7-Segment Decoder/Driver 1-Of-8 Data Selector/Multiplexer 8-Bit Addressable Latch Quad Complementary-Output Elements Octal D-Type Flip Flop With Clear Quad J-K Flip Flop 4-Bit Cascadable Priority Register Quad S-R Latches 4-Bit Binary Full Adders W/Fast Carry Tri-State 4-Bit Multiplexer Tri-State 4-Bit Multiplexer Quad 2-Input Multiplexer W/Storage Dual Data Selector/Multiplexer T.S. Output Tri-State Hex Buffer Non-Inverting Hex Inverting Bus Drivers Hex Non-Inverting Bus Drivers: Tri-State Hex Inverting Bus Drivers (Tri-State) Dual 4-Bit Decade Counters |
