Pic code omzetten
Ik heb een stukje piccode voor een PIC 12F629.( zie onder)
Voor een nog te bouwen project moeten op bepaalde vaste tijdstippen dagelijks 4 relais worden aangestuurt gedurende een paar seconden.
Wie kan/wil me dit stukje code geschikt maken voor een PIC 26F628.
zodat ik zelf de relais etc kan toevoegen?
PS: Er staat veel "overbodige" uitleg in onderstaande citaat.
Ben
'PROGRAM: EZCLOCK2
' Paul R. Borgmeier, PhD
'DESCRIPTION: This bare bones program demonstrates how to
' create a very simple yet accurate clock without the use of
' a RTC IC.
' This version of the code tracks time in an HH:MM:SS format.
' Time is tracked by the program but not displayed. The initial
' starting time is arbitrarily set to 12:00 noon but can be
' changed to meet your needs.
' This version requires a 4.000 MHz Xtal - accuracy is
' controlled 100% by Xtal tolerance: (schematic is below)
' 100ppm tolerance gives < 9 sec/day error
' 50ppm tolerance gives < 5 sec/day error
' 30ppm tolerance gives < 3 sec/day error
' 20ppm tolerance gives < 2 sec/day error
'HOW IT WORKS: This clock is based on Roman Black's "Zero-error
' One Second Timer!" (www.romanblack.com) but has been optimized
' for simplicity and implementation using PicBasic Pro. This
' program keeps track of .5 second intervals. On the
' whole second, the time is udated.
' The version here makes use of TMRO with a prescaler of 256 and
' manual polling for TMRO overflow (interrupts could easily by
' added if needed). This makes the TMRO period equal to 65,536
' microseconds(65.536 mSec), which gives the user lots of time to
' do other stuff between TMRO overflows.
' Note that although the overall accuracy of the clock is as accurate
' as the Xtal tolerance, individual seconds are not and vary slightly
' from second to second - however,the cummulative error of the second
' to second variation appraoches ZERO! Each half second calculated by
' the program is either 0.4588 seconds or 0.5243 seconds in length.
' The program combines these so that the total error approaches zero
' when compared to a perfect timer - the only error left is due to
' crystal tolerance. Note that the longer the program runs, the more
' accurate the clock becomes. For example, after 1000 seconds, the
' total error is just 0.0052% (this equates to 52mSec&#8212;not bad!).
' The news gets even better. If you cannot live with this accuracy,
' for example in a timer application, once the timer or program has
' been stopped, the error can be determined in software and corrected.
' The correction can be determined from the values of TMRO, HzTimer,
' and Col at the time of interest. Most will not have to deal with
' this correction because the error approaches zero the longer the
' clock runs anyway. The value of the error from any second is always
' less than 65.5mSec regardless of the elapsed time.
' Black's timer uses three separate byte-sized variables to track the
' instruction counts for one second periods. His method is fast and
' clever, but requires manually watching and maintaining addition
' overflows and carries between three variables.
' With a 4 MHz crystal, 0.5 seconds equals 500,000 instructions (h7A120),
' which is larger than a word-sized variable in PicBasic Pro. The TMRO
' time period used in the code is 65,536 (h10000). The trick used here is
' to divide both the instruction count and timer count by 16 (h10), which
' makes the instruction count trackable in a single word-sized variable,
' HzTimer.
' This bare bones program demonstrates how to implement this clock.
' The program has one sections:
' (1) Maintains time internally. Hours are HH 0-23, Minutes are
' MM 0 - 59, Seconds are SS 0-59
' The user can add code to perform tasks as needed. To demonstrate
' this, the code below toggles GP1 for 1 second on the hour. The code
' also turns of GP0 at 8:00 pm and turns it off at 8:15 pm.
' The entire code is amazingly short&#8212;just about
' 30 to 40 lines of code, depending on how you count.
'PIC: 12F629
' GP0: Turn Something On (relay, FET, alarm, etc)
' GP1: Test Location LED, Buzzer, VOM, nothing?
' GP2:
' GP3: (MCLR Internal)
' GP4: XTAL 4.0000 Hz (w/tolerance = 30 ppm) w/ cap to GND
' GP5: XTAL 4.0000 Hz (w/tolerance = 30 ppm) w/ cap to GND
' -_-
' +5V--| |--GND
' Xtal-|12F|--to turn on circuit (relay, FET, alarm, etc)
' Xtal-|629|--test location (LED, buzzer, etc. if required)
' (Xtal caps to GND not shown)
' CONFIGURATION SETUP
' Oscillator: XT
' Watchdog Timer: OFF
' Power up Timer: OFF
' Master Clear Enable: Internal
' Brown Out Detect: OFF
' Code Protect: OFF
' Data EE Read Protect:OFF
CMCON=7 'all digital for low power use
GPIO=0
TRISIO=0
OPTION_REG=%10000111 'weak pullups off, TMRO prescale = 256
INTCON=0 'interrupts off
HzTimer VAR Word '1/2 second counter (2 Hz)
HH VAR Byte ' Hours 0-23
MM VAR ByTE ' Minutes 0-59
SS VAR Byte ' Seconds 0-59
col VAR Bit ' colon 1=on, 0=0ff
HzTimer=$7A12 'for 1/2 Sec
HH=12:MM=0:SS=0:col=0 'initial conditions (12:00 O'clock noon)
Main:
ClockLoop: IF intcon.2=0 THEN ClockLoop 'Poll for TMRO overflow
INTCON.2=0 ' Clear TMRO overflow flag
HzTimer=HzTimer-$1000 'decrement timer count
IF HzTimer < $1000 THEN
IF Col=1 THEN ' update time'
SS=SS+1
GPIO.1=0 ' Turn off GP1
IF SS=60 THEN ' minute
SS=0
MM=MM+1
IF MM=60 THEN ' hour
MM=0
HH=HH+1
IF HH=24 THEN HH=0
IF HH=20 then GPIO.0 = 1 ' Turn on GP0 at 8:00pm
GPIO.1=1 ' Turn On GP1 for 1 second on the hour
ENDIF ' Adjust these to meet your needs
if MM=15 then GPIO.0 = 0 ' Turn off GP0 at 8:15pm
ENDIF
ENDIF
Col=Col+1
HzTimer=HzTimer+$7A12 ' Add 0.5 seconds to count
ELSE
' Do something here but must be less than 65.5 mSec
ENDIF
GOTO Main 'forever
END
Poorten en config aanpassen, het is in PBP dus omzetten naar Proton+ is even een paar minuten meer werk.
Edit: het is geen superklok.
[Bericht gewijzigd door Henry S. op 1 april 2010 20:50:05 (13%)]
Wie wat bewaart moet later veel weggooien. Word lid van de Benelux DX Club, Een ATX-voeding gebruiken?
Wat een bagger-code.
Tijdkritische zaken handel je altijd af in een interrupt. Zoek iets beters. Er is vast wel iemand die een timer heeft gemaakt met een 16F628.
Elektronica: Fuzzcraft.com | Concertfoto's: Fuzzphoto.eu
De code ziet er misschien niet netjes uit maar hier onder beter weergegeven.
Ik heb voor deze code gekozen vanwege zijn gemiddelde, zie eerste uitleg, nauwkeurigheid en zeer simpele hardware.
CONFIGURATION SETUP
Oscillator: XT
Watchdog Timer: OFF
Power up Timer: OFF
Code Protect: OFF
GPIO=0
TRISIO=0
MM VAR Byte ' Minutes 0-59
Main:
ClockLoop: If INTCON.2=0 Then ClockLoop 'Poll for TMRO overflow
If HzTimer < $1000 Then
If Col=1 Then ' update time'
SS=SS+1
If SS=60 Then ' minute
SS=0
MM=MM+1
If MM=60 Then ' hour
MM=0
HH=HH+1
If HH=24 Then HH=0
If HH=20 Then GPIO.0 = 1 ' Turn on GP0 at 8:00pm
EndIf
If MM=15 Then GPIO.0 = 0 ' Turn off GP0 at 8:15pm
EndIf
EndIf
Col=Col+1
Else
EndIf
GoTo Main 'forever
End
Een klok via een interrupt vergt niet meer hardware, en is zo nauwkeurig als het kristal. Bovendien hoef je er, als het eenmaal loopt, geen rekening meer mee te houden. Als je hoofdlus een keer wat langer bezig is dan 65,5 milliseconden, dan mis je een time-out, wat je met een interrupt nooit zal hebben.
Heb je ook weer gelijk in.
Maar ik heb nergens een simpele timer,met PICBASIC, die dagelijks een paar relais voor een paar seconden kan aansturen gevonden.
Of heb jij een voorbeeld die ik kan uitwerken?
Ben
Tsja in je naam staat al I2C, kortom waarom geen DS1307 ?
Echte hobbyisten gebruiken ARM of FPGA ook voor een knipperledje ...
