16f88 PORTB.1 als uitgang
Ik krijg op een 16f88 poort B1 niet werkend als digitale uitgang.
Wat doe ik verkeerd ?
pic basic code:
Device 16F88
@CONFIG_REQ
@__CONFIG _CONFIG1, CP_OFF & CCP1_RB0 & DEBUG_OFF & WRT_PROTECT_OFF & CPD_OFF & LVP_OFF & BODEN_ON & MCLR_OFF & PWRTE_ON & WDT_OFF & INTRC_IO
@__CONFIG _CONFIG2, IESO_OFF & FCMEN_OFF
Xtal 8
; OSCCON Oscillator Control Register:
; bit 7: unimpl. read as 0
; bit 6-4: frequency (IRCF):
; 110: 4 mhz
; 111: 8 mhz
; bit 3: OSTS: 1 (run from primary system clock), 0 (run from T1OSC or INTRC as a secondary system clock)
; bit 2: IOFS: INTOSC Freq. stable bit (1 stable, 0 not stable)
; bit 1-0: ; SCS<1:0>
; 00: OSC mode defined by fuse / configuration bits (FOSC<2:0>)
; 01: T1OSC is used for system clock
; 10: Internal RC is used for system clock
; 11: Reserved (don't use it)
OSCCON = %01111000
Declare Adin_Res 10
;Declare ADIN_TAD FRC
; Allow ?? us sample time, typical is 50-100, this allows
; adequate charge time without losing too much conversion speed.
; According to page 119 of the 16F88 datasheet, typical AD
; conversion takes 11-12 TAD. Using FRC nets an average of 4
; us per TAD. A minimum of 48 us is therefore recommended. But
; TAD time of FRC varies between 2-6 us! So worst-case, conversion
; takes 12 * 6 = 72 us. To be sure, use ADIN_STIME 75.
Declare Adin_Stime 75
Symbol OUT_HHaccu    = PORTA.4
Symbol OUT_Backlight = PORTA.6
Symbol Switch        = PORTA.7
Symbol OUT_STaccu    = PORTB.0
Symbol OUT_HH__ST    = PORTB.1
Dim UPAN As Dword
Dim POTM As Dword
Dim UST As Dword
Dim UHH As Dword
Dim Teller As Word
Dim UDelta As Word
Dim HH_max As Word
Dim ST_max As Word
Dim Tellerbacklight As Byte
Dim Tellerreturn As Word
; Disable comparators, CMCON = 7
CMCON  = %00000111
; All pins of port A low
PORTA  = %00000000
; AN1 as an input
TRISA  = %10001111
; AN1 is analog
ANSEL  = %00001111
; Use FRC, Channel 1 (RA1/AN1, pin 18), clear GO/DONE bit (is
; automatically set by ADIN when converting), and turn on ADC.
; This is why ADIN_TAD is commented out above, the use of
; FRC can also be set directly into ADCON0 (2 MSB's):
ADCON0 = %11001001
; Right justified (A/D Result), AD clock divide by 2 disabled,
; voltage ref. config bits set to 00 (AVdd = Vref+, AVss = VRef-).
ADCON1 = %00000000
Declare LCD_ENPin PORTB.2
Declare LCD_RSPin PORTB.3
Declare LCD_DTPin PORTB.4
Clear
Hoe weet je dat die poort niet werkt? uit dit stuk code kan ik dat niet opmaken.
pic basic code:
Device 16F88
@CONFIG_REQ
Xtal 8
; 110: 4 mhz
; 111: 8 mhz
OSCCON = %01111000
Declare Adin_Res 10
Dim UPAN As Dword
Dim POTM As Dword
Dim UST As Dword
Dim UHH As Dword
Dim Teller As Word
Dim UDelta As Word
Dim HH_max As Word
Dim ST_max As Word
CMCON  = %00000111
PORTA  = %00000000
; AN1 as an input
TRISA  = %10001111
; AN1 is analog
ANSEL  = %00001111
ADCON0 = %11001001
ADCON1 = %00000000
Clear
DelayMS 500
Cls
OUT_STaccu = 0
OUT_HHaccu = 0
OUT_HH__ST = 0
OUT_Backlight = 1
DelayMS 500
While 1 = 1
Toggle OUT_HH__ST
DelayMS 3000
Wend
End
Wat heb je aangesloten op RB1?
De uitgang RB1 van de pic is aangesloten op een ingang van een ULN2803.
RA4, RA6 en RB0 zijn ook aangesloten op dezelfde ULN2803 en werken wel.
Zou moeten werken. Is de ULN niet gewoon kapot? (of de RB1 pin van de 16F88?)
[Bericht gewijzigd door Arco op 8 april 2018 11:07:16 (24%)]
Ik weet vrijwel niks van Pic basic dus misschien dat er onder water van alles gebeurt en ik een onzinnige opmerking maak, maar waarom initialiseer je wel trisa en niet trisb?
In dit geval zou ik de code terugbrengen tot zijn meest simpele vorm, dus alleen die pin aan en uit zetten, en dan liefst met LOW en HIGH, om te checken of de output pin en de ULN nog werken. Mij gebeurt het met enige regelmaat dat ik er zo achter kom dat ik de verkeerde pin gebruik.
Als ik de pic er uit haal en dan pin 7 met de 5v verbind schakelt het relais via de ULN.
Nieuwe pic er in gezet en bovenstaande programma aangevuld;
pic basic code:
Clear
DelayMS 500
Cls
DelayMS 500
Print At 1, 1, "test lcd voor while"
OUT_STaccu = 0
OUT_HHaccu = 0
OUT_HH__ST = 0
OUT_Backlight = 1
DelayMS 2000
While 1 = 1
Toggle OUT_HH__ST
Print At 3, 1, "test lcd in while"
DelayMS 3000
Wend
End
test lcd voor while --> Tekst goed op lcd
test lcd in while --> gaat niet goed op lcd TEQT@LAD@IL@UHILE
Een fout in de configuratie ?
maar waar
Op 8 april 2018 11:26:21 schreef Paulussie:
Da's gewoon /de/ fout. Spijker op z'n kop en zo.
Ik heb geen verstand van PICs maar zoals verwacht initialiseert TRISB op "alles input" (alle bitjes hoog).
Picbasic schijnt een pin automatisch te definieren als output wanneer je er naartoe schrijft... (maar trisb is misschien wat netter)
Wat bedoel je met lcd test "gaat niet goed"? (zie je helemaal niks?)
En wat stelt " TEQT@LAD@IL@UHILE" voor??
Maar doet PicBasic dat ook als je zoals hier een poort als variabele definieert en dan de waarde direct wijzigt? Commando's als LOW en HIGH zullen tris wel setten maar als je een bit op een output port verandert gebeurt dat wellicht niet. Althans, niet in de code die uit mijn C compiler rolt :-)
Schijnbaar wel. Maar daar zal 't trouwens niet aan liggen als de lcd_write wel werkt buiten de while loop en niet erin...
Ik heb het nooit zo op 'zelfdenkende' compilers die dingen doen die ik niet wil, doe ik zelf wel...
[Bericht gewijzigd door Arco op 8 april 2018 12:08:32 (29%)]
Print At 1, 1, "test lcd voor while" wordt weergegeven test lcd voor while.
Print At 3, 1, "test lcd in while" wordt weergegeven als TEQT@LAD@IL@UHILE
Ik heb het geprobeerd met low en high, maakt geen verschil.
Als PORTB.1 niet gebruikt wordt in het programma dan wordt alles goed weergegeven op het display.
Als PORTB.1 laag of hoog gemaakt wordt dan gaat het mis, onleesbare teksten op het display.
Als ik TRISB = %00000000 er in zet gaat het niet goed met het display,
onleesbare teksten.
Als je de pin een 'normale' naam geeft werkt het ook niet? (zonder dubbele underscores. Namen die met een underscore beginnen vindt picbasic n.l. ook niet fijn)
Lambiek
Als je iets onder "DECLARE" zet hoef je verder niets in te stellen onder "TRISA, TRISB, TRISC, enz." maar als je dat niet doet, moet je altijd "TRIS" neer zetten.
Dat is ook de reden dat je display wel werkt, en je uitgang niet.
pic basic code:
Even voor de zekerheid: Ik begrijp nu dat:
- Poort B1 niet (nooit) werkt als output.
- Het PRINT commando wel werkt in de while loop als er vlak daarvoor geen TOGGLE commando wordt gegeven
- Het PRINT commando niet werkt in de while loop als er vlak daarvoor wel een TOGGLE commando wordt gegeven
Komt er ook een list file (een file waarin je kunt zien in welke assembler de Picbasic commando's vertaald zijn) uit de compiler?
Want zowel TOGGLE als PRINT zullen trisb zetten. Misschien dat daar iets fout mee gaat?
En nogmaals: trim het programma terug naar het bare minimum en kijk of je die poort dan wel kunt besturen. Gewoon iets in de trant van:
pic basic code:
DEVICE 16F88                ;We gebruiken een 16F88 type
CONFIG wat_er_nodig_is_om_een 16F88_te_laten_starten
ALL_DIGITAL TRUE              ;Alle ingangen digitaal
Opnieuw:                      ;Label met zelf te verzinnen naam
TOGGLE PORTB.1                ;Aan moet uit, uit moet aan
DELAYMS 500                   ;500 milliseconden = 0,5 seconde
GOTO Opnieuw                  ;Spring naar 'Opnieuw' en ga zo steeds door
END                           ;Einde programma
Met dank aan http://www.picbasic.nl/
Op 8 april 2018 12:24:02 schreef Lambiek:
Dat verklaart niet waarom lcd write in de while loop niet, en daarbuiten wel werkt... Schijnbaar 'schrikt' de compiler van die 'OUT_HH__ST'
Lambiek
Ja, dat is ook vreemd. Maar ik vind de hele opbouw van het programma vreemd, maar misschien zijn het stukjes van de code. :)
hadv
print at 3, x veronderstelt een lcd met 3 (nog nooit gezien) of 4 regels. aangezien de meeste lcd's maar 2 regels hebben zou de fout hier wel eens in kunnen zitten
Ik nam aan dat het ook een 4 regel display was... ;)
Maar er zijn ook wat displays die afwijkend ik mekaar steken. Bijv. sommige 1x16 displays bestaan intern uit 2 regels van 8 karakters...
Bij vroegere 4x20/4x40/2x40 displays waren er ook soortgelijke eigenaardigheden.
hadv
Declare LCD_Lines 1,2 or 4
If the declare is not used in the program, then the default number is 2.
(rtfm)
@arco: nooit zomaar iets aannemen tenzij je in de bouw zit...
[Bericht gewijzigd door hadv op 9 april 2018 13:15:58 (23%)]
