Battery indicator
Arduino:1.8.6 (Windows 10), Board:"Arduino Nano, ATmega328P (Old Bootloader)"
sketch_nov21c:179:1: error: 'percentage' does not name a type
percentage = map(accuspanning, accuvol, acculeeg, 100, 0);
sketch_nov21c:180:1: error: expected unqualified-id before 'if'
if (percentage < 0) { percentage = 0;}
sketch_nov21c:181:1: error: expected unqualified-id before 'if'
if (percentage > 100) { percentage = 100;}
sketch_nov21c:182:17: error: expected constructor, destructor, or type conversion before '(' token
showBatteryLevel(percentage);
sketch_nov21c:184:1: error: 'Serial' does not name a type
Serial.print("*****************");
sketch_nov21c:185:2: error: 'Serial' does not name a type
Serial.print("analogread: ");
sketch_nov21c:186:2: error: 'Serial' does not name a type
Serial.println(analogRead(A0));
sketch_nov21c:187:2: error: 'Serial' does not name a type
Serial.print("accuspanning: ");
sketch_nov21c:188:2: error: 'Serial' does not name a type
Serial.println(accuspanning);
sketch_nov21c:189:2: error: 'Serial' does not name a type
Serial.print("percentage: ");
sketch_nov21c:190:2: error: 'Serial' does not name a type
Serial.println(percentage);
sketch_nov21c:191:6: error: expected constructor, destructor, or type conversion before '(' token
delay(1000);
sketch_nov21c:192:1: error: expected declaration before '}' token
exit status 1
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
Krijg na vervangen van i=0 naar i=1 error
code:
#include <U8g2lib.h>
 #include <U8x8lib.h>
 // This is the display object. You will change this line if you are using pins
 // other that 12, 11, 9 and 10.
 U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
 // This is the battery bitmap// This is the area inside the battery bitmap, in pixels
 static const PROGMEM unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
 #define CHARGE_AREA_START_X 20
 #define CHARGE_AREA_START_Y 18
 #define CHARGE_AREA_WIDTH 83
 #define CHARGE_AREA_HEIGHT 28
 // This is the battery fill mode
 // BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
 // a solid rectangle according to the battery charge.
 // BATTERY_MODE_SOLID = 0 means the battery will be filled with a
 // rectangle subdivided in 3. If the battery level is 66% or more, it will
 // draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
 // draw 1 rectagle if the battery is less than 33%.
 #define BATTERY_MODE_SOLID 1
 // This is the main function, and the one you will want to transplant to your
 // code. Pass the battery charge percent and it will draw the battery with
 // the corresponding charge level.
 void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
display.clearBuffer();
display.drawXBMP(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
display.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 1; i < bars; i++)
display.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
display.sendBuffer();
float accuspanning = 0.0;
int accuvol = 135; //(volle accu 13,5V)
int acculeeg = 110; //(lege accu 11,0V)
int percentage;
void setup()
// Initialize the display object
display.begin();
Serial.begin(9600);
pinMode(A0, INPUT); //neem ingang A0
void loop()
// Some test code to scan all the battery levels
// *3 is de spanningsdeler van de weerstanden
// *10 omdat de map niet met kommagetallen werkt. 13,5V => 135
accuspanning = ((analogRead(A0) * 5.0) / 1024.0 ) *3 *10;
delay(1000);
Nogmaals de complete scetch
void loop()
delay(1000);
deze doorstreepte } sluit je loop af, dus alles wat volgde zit buiten je programma
heb er vermoedelijk fouten in gemaakt
sketch functioneerd weer
in het display wisseld nog steeds van 50% naar 60%
accuspanning nu 12.04V
A0 - GND nu 3,79V (stabiel)
wanneer ik er 'n externe voeding opzet 5V
A0 -GND 3.79V stabiel
display weergave 10% a 15% (stabiel)
monitor
accuspanning 122.46
percentage 48
analogread 836
heb geprobeerd 1000 te veranderen in
eerst 10000
daarna 100000
meer stabiel display ( wisseling 40sec )
is dat 'n probleem?
[Bericht gewijzigd door a.j nieuwlaat op 9 december 2018 14:24:02 (19%)]
fcapri,
al een beetje beter?
ik denk dat de sketch nu naar behoren functioneert
bedankt voor alle moeite
Gr
Goedemorgen fcapri,
sorry dat ik u weer moet lastig vallen
Met de sketch voor die Batterij indicator heb ik toch weer 'n probleem
Hoop dat u mij wil/kan helpen
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
for (uint8_t i = 0; i < bars; i++)
offset += 28;
void setup()
display.begin();
// A variable to test our code.
uint8_t percent = 100;
void loop()
showBatteryLevel(percent);
#include "U8glib.h" // U8glib library for the OLED
int analogInput = 0;
float vout = 0.0;
float vin = 0.0;
float R1 = 100000.0; // resistance of R1 (100K)
float R2 = 10000.0; // resistance of R2 (10K)
int value = 0;
U8GLIB_SH1106_128X64 u8g(13, 11, 10, 9, 8); // D0=13, D1=11, CS=10, DC=9, Reset=8
void draw(void)
void setup(){
pinMode(analogInput, INPUT);
void loop(){
// read the value at analog input
value = analogRead(analogInput);
vout = (value * 5.0) / 1024.0; // see text
vin = vout / (R2/(R1+R2));
if (vin<0.09) {
vin=0.0;//statement to quash undesired reading !
u8g.firstPage();
do
draw();
while( u8g.nextPage() );
delay(500);
else
percent = 100;
delay(50);
geeft hierna 'n fout melding
In file included from C:\Users\Toon\Documents\Arduino\libraries\U8glib\src/U8glib.h:42:0,
from C:\Users\Toon\Documents\Battery_Indicator\Battery_Indicator.ino:175:
C:\Users\Toon\Documents\Arduino\libraries\U8glib\src/clib/u8g.h: In function 'void loop()':
C:\Users\Toon\Documents\Arduino\libraries\U8glib\src/clib/u8g.h:70:8: error: expected unqualified-id before string constant
extern "C" {
Battery_Indicator:213:1: error: expected '}' at end of input
exit status 1
met vriendelijke groet
A.J Nieuwlaat
Sorry fcapri
had 'n oudere versie van de sketch
bij de goede sketch word er nu aangegeven te weinig geheugen
kan die sketch ingekort worden om te uploaden naar 'n Arduino Nano
Met vriendelijke groet
A.J Nieuwlaat
Hoeveel geheugen gebruikt ie dan? Volgens mij zit er 32k in een 'nano. (in ieder geval in de mijne die ik heb).
fcapri,
was nu zover om de sketch in de Nano te uploaden, welke ik nu gemonteerd heb in mijn model truck,en krijg nu elke keer 'n fout melding. Vorige was op 'n bread board als test, ook met 'n Nano maar die is met pinnen en ik gebruik in mijn truck, een zonder pinnen om rechtstreeks te bedraden.
Zou u zo vriendelijk willen zijn om de sketch te controleren en eventueel in te korten omdat ik ook al 'n melding heb gekregen te weinig geheugen.
sorry ik kom er niet uit
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
offset += 28;
int percentage;
void setup()
display.begin();
Serial.begin(9600);
void loop()
delay(1000);
hierna foutmelding
extern "C" {
exit status 1
Rew
Mag ik 'n beroep op jou doen om in de sketch Battery indicator gemaakt door Capri, ( waar ik niets mee van hoor )
wanneer ik de sketch in mijn modeltruck upload krijg ik 'n error
Arduino:1.8.7 (Windows 10), Board:"Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\Toon\Documents\Arduino\Battery_indicator_07-03-2019\Battery_indicator_07-03-2019.ino: In function 'void showBatteryLevel(uint8_t)':
Battery_indicator_07-03-2019:154:1: error: expected ';' at end of input
Battery_indicator_07-03-2019:154:1: error: expected '}' at end of input
exit status 1
Je programma lijkt afgekapt te zijn. De compiler geeft aan dat het bestand afgelopen is terwijl ie nog op z'n minst een puntcomma en drie accolades sluiten moest krijgen.
De kans dat dit het enige is wat er mist lijkt me klein. Maar in die hoek moet je het zoeken.
heb in opleiding gezeten, dus geen tijd voor internet. examens pas afgelopen sinds gisteren.
dit deel is fout, ik heb die #### gezet waar je loop eindigt, dus alle code erna ... tja, daar doet de compiler gek over.
ofwel moet je daar een nieuwe functie openen
void Doiets(){ ofwel moet al die code in u loop staan:
code:
void loop()
}   <=##################### hier sluit je de loop AF ####################
delay(1000);
zonder die regel, compiled het wel bij mij
code:
void loop()
delay(1000);
[Bericht gewijzigd door fcapri op 17 mei 2019 10:39:44 (25%)]
Goedemorgen fcapri
Hoop dat u het examen met goed gevolg hebt doorstaan.
na uploaden;
De schets gebruikt 10986 bytes (35%) programma-opslagruimte. Maximum is 30720 bytes.
Globale variabelen gebruiken 1721 bytes (84%) van het dynamisch geheugen. Resteren 327 bytes voor lokale variabelen. Maximum is 2048 bytes.
Weinig geheugen beschikbaar, er kunnen zich stabiliteitsproblemen voordoen
avrdude: ser_open(): can't open device "\\.\COM9": De time-outperiode van de semafoor is verlopen.
Probleem bij het uploaden naar het board. Zie http://www.arduino.cc/en/Guide/Troubleshooting#upload voor suggesties.
hoe is dat op te lossen
vriendelijke groet
bordje in een andere usb geplugged?
je zal in systeembeheer eens moeten gaan kijken welke com poort u arduino krijgt, en die in de software gelijk zetten.
of eenvoudig trukje, start de arduinosoftware op zonder arduino in geplugged en ga naar 'tools' -> 'port'.
en kijk welke er in staan.
bv com1, com2, com3...
Sluit de software af, plug je arduino in en start de software opnieuw. er zal een com poort bijgekomen zijn, dat is de arduino en die moet je selecteren
je software staat nu dus om COM9 en daar vind die de arduino niet (of arduino loopt vast of die heeft een andere poort nr gekregen). als die vastloopt, kan je op reset drukken vlak voor je pc de software zal doorsturen
Fcapri,
heeft nu op com 10 het uploaden voltooid
Nogmaals bedankt
a.j nieuwlaat
waarvoor hebt u examen gedaan
interne opleiding op het werk (1maand). nu in augustus begint het 2de deel voor 2maand en dan kan ik hoger gaan in functie
fcapri
Hoe gaat het met u druk op het werk ?
mag ik nog 'n verzoek om hulp aan u doen ?
Ik wil graag de snelheid van mijn truck meten op 'n rollerbaan
daarvoor vond ik deze sketch;
//arduino bike speedometer w serial.print()
//by Amanda Ghassaei 2012
//https://www.instructables.com/id/Arduino-Bike-Speedometer/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 3 of the License, or
* (at your option) any later version.
//calculations
//tire radius ~ 13.5 inches
//circumference = pi*2*r =~85 inches
//max speed of 35mph =~ 616inches/second
//max rps =~7.25
#define reed A0//pin connected to read switch
//storage variables
int reedVal;
long timer;// time between one full rotation (in ms)
float mph;
float radius = 13.5;// tire radius (in inches)
float circumference;
int maxReedCounter = 100;//min time (in ms) of one rotation (for debouncing)
int reedCounter;
void setup(){
reedCounter = maxReedCounter;
circumference = 2*3.14*radius;
pinMode(reed, INPUT);
// TIMER SETUP- the timer interrupt allows precise timed measurements of the reed switch
//for more info about configuration of arduino timers see http://arduino.cc/playground/Code/Timer1
cli();//stop interrupts
//set timer1 interrupt at 1kHz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;
// set timer count for 1khz increments
OCR1A = 1999;// = (1/1000) / ((1/(16*10^6))*8) - 1
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bit for 8 prescaler
TCCR1B |= (1 << CS11);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
sei();//allow interrupts
//END TIMER SETUP
Serial.begin(9600);
ISR(TIMER1_COMPA_vect) {//Interrupt at freq of 1kHz to measure reed switch
reedVal = digitalRead(reed);//get val of A0
if (reedVal){//if reed switch is closed
if (reedCounter == 0){//min time between pulses has passed
mph = (56.8*float(circumference))/float(timer);//calculate miles per hour
timer = 0;//reset timer
reedCounter = maxReedCounter;//reset reedCounter
else{
if (reedCounter > 0){//don't let reedCounter go negative
reedCounter -= 1;//decrement reedCounter
else{//if reed switch is open
if (timer > 2000){
mph = 0;//if no new pulses from reed switch- tire is still, set mph to 0
else{
timer += 1;//increment timer
void displayMPH(){
Serial.println(mph);
void loop(){
//print mph once a second
displayMPH();
delay(1000);
Heb 'n magneetje in 'n band ( omtrek band 23mm )geplakt en als opnemer 'n reedcontact no
voor 'n aTtiny85 of ( indien te weinig geheugen ) 'n arduino nano
met 0.91" 128x32 oled lcd display driver ic SSD1306
sketch zo compact mogelijk voor de aTtiny85
a.j nieuwlaat
Bij voorbaat bedankt
ik heb ooit zoiets gemaakt, maar veel compacter in code. ik nam gewoon de omtrek van het wiel in de code. beetje zoals je ook met commerciele fietscomputers hebt.
weet de sketch niet meer staan, dus heb het deel gecopieerd uit een ander programma dat hetzelfde deed:
de interrupt regel: hier opletten dat je de correcte pin neemt die interrupts kan verwerken (https://www.arduino.cc/reference/en/language/functions/external-interr…)
c code:
  pinMode(speedPin, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(speedPin), speedkm, CHANGE);
de verwerkingscode
c code:
void speedkm() {
  float wielomtrek = 1540;
  unsigned long currentMillis = millis();
   tijd tussen 2 omwentelingen
   per toer = xx meter.
   xx meter / tussentijd => m/s => km/h
   km/h = (3600 / timetaken) * (wielomtrek / 1000)
   voorbeeld: 1 toer in 200ms, wielomtrek 2000mm (2m).
   3600/200 * 2000/1000 = 36km/h
  if (millis() - lastspeed > 80) {
    timetaken = currentMillis - lastspeed;
    bikespeed2 = bikespeed;
    bikespeed =  (3600 / timetaken) * (wielomtrek / 1000);
    lastspeed = currentMillis;
Begrijp ik niet helemaal
die code c
moet ik die ergens tussen de sketch invoegen of is dit de de totale sketch
als dat zo is moet ik daar nog iets aan veranderen
Gr a.j nieuwlaat
die moet je invoegen.
je moet een interupt aanmaken in je setup, dat is de pin waar je magneetsensor op zit
c code:
en die zal telkens het magneetje passeert aan de sensor, zal die onderstaande code uitvoeren
c code:
void speedkm() {
je moet dan wel even je wielomtrek correct zetten, want dit was een stuk code voor mijn fiets.
wat die doet is gewoon de tijd tussen 2 pulsen meten. en daarmee ook de omtrek van je wiel nemen.
dan weet die dus hoeveel meter je hebt afgelegd tussen een bepaalde tijd en met wat omrekenen de snelheid.
je zal zelf die code wat moeten omzetten naar jouw noden, aangezien het een deel copy was uit een bestaand programma van mij (sturing van een ebike motor waarbij ik dus ook de snelheid nodig had om die wettelijk te houden)
Goedemorgen fcapri,
De wielomtrek begrijp ik 1540, bij mij ( 230mm )
wat vul in dan in bij bikespeed
onderin de sketch staat wielomtrek 1000
Je zegt hierboven omtrek 23mm. Als het om een RC voertuigje gaat dan kan dat best. Maar 230mm kan ook best. Het zou ook kunnen dat het model 1:10 is en je 10x grotere getallen in het display wilt hebben. Wat het moet zijn weet ik niet, maar zolang je niet beargumenteert waarom er nu 230 staat is het een beetje fout.
fcapri z'n code is zo goed als de heel sketch. In de loop moet je alleen nog iets zetten om de "bikespeed" variabele op het display te zetten.
Rew
had me vergist in de omtrek geen 23 maar 230mm
mijn truck is 1:14.5
denk jij dat dit de hele sketch is of met ik die ergens in mij gevonden sketch zetten en waar ?
