Potentiometer
Hello,
I'm making a circuit however I'm struggling to find any cheap 470k Dual Gang Potentiometers would It be ok for me to use a 500k Potentiometer Instead.
Thanks,
Digital.
This depends on the circuit and the context.
.... but most often such a difference is not an issue. Most often the ratios matter and those will be the same for the 470k and the 500k pots.
Het is belangrijker erop te letten of het een lineaire moet zijn dan wel een logaritmische. Het verschil 470k <=> 500k zal zelden relevant zijn, inderdaad.
Op 12 augustus 2020 21:03:07 schreef big_fat_mama:
An Attempted translation:
It is more important to verify if you need a liniair Potentiometer or a logarithmic Potentiometer.
The differenced 470k <=> 500k will indeed seldon be relevant.
(Added)
Audio circuitry normally uses Logarithmic Potentiometers.
Neovo.
Slechtziend aan linker oog, Blind aan rechter oog. Hosting van Forumbestanden: https://drive.google.com/drive/folders Meetarsenaal welke ik heb: https://drive.google.com/file/d/1vx54QxPe6YS3pJhybK_y0a380MYUFGyb/view
