Arduino fout melding
Goedemorgen CO'ers
Na het handmatig toevoegen van een library krijg ik de volgende melding:
c code:
C:\Users\jeffr\Documents\Arduino\Confetti_timer_230416\Confetti_timer_230416.ino: In function 'void setup()':
C:\Users\jeffr\Documents\Arduino\Confetti_timer_230416\Confetti_timer_230416.ino:100:13: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
   lcd.begin();
In file included from C:\Users\jeffr\Documents\Arduino\Confetti_timer_230416\Confetti_timer_230416.ino:18:0:
C:\Users\jeffr\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: candidate: void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
   void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
C:\Users\jeffr\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note:   candidate expects 3 arguments, 0 provided
exit status 1
Compilation error: no matching function for call to 'LiquidCrystal_I2C::begin()'
De library heb ik hier gedownload: https://www.arduinolibraries.info/libraries/liquid-crystal-i2-c
Onderstaand de code uit het programma, wat gaat er fout? Ik begrijp het niet..
c code:
TIMER ARDUINO
Questo progetto è di libero utilizzo, basta che venga citato il programmatore.
Programmatore Firmware: Tartaglia daniele
sito: www.labdomotic.com
email: edstarink@fastwebnet.it
Youtube channel: https://www.youtube.com/channel/UCwMjr5HocO6S363x_-jzsmA
Facebook: https://www.facebook.com/daniele.tartaglia.73?ref=bookmarks
#include <EEPROM.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // set the LCD address to 0x27 for a 16 chars and 2 line display
#define encoder0PinA  2
#define encoder0PinB  3
volatile int encoder0Pos = 4;
volatile boolean PastB = 0;
volatile boolean update = false;
int contatoreFineTempo;
int lastButtonState = 0;
// ------------------------++++++++++++++++++++++   ENCODER
int encoderPin1 = 2;
int encoderPin2 = 3;
volatile int lastEncoded = 0;
volatile long encoderValue = 0;
volatile long encoderValue2 = 0;
volatile long encoderValue3 = 0;
long lastencoderValue = 0;
long lastencoderValue2 = 0;
long lastencoderValue3 = 7;
int lastMSB = 0;
int lastLSB = 0;
int ore = 45;
int minuti = 5;
int secondi = 6;
//---------  timer variabili
int buzzer = 7;           //PIEDINO DEL BUZZER
int rele = 6;
int secondiTotali = 0;     //Tempo totale
int msg = 0;
int reset = 0;
int start = A6;            //Pulsador de arranque
int empieza = 1024;        // Variable para almacenaje del pulsador de arranque
// assegnazione ingressi per i due pulsanti start e encoder
int pushButton = 4;
int pushButtonSTART = 5;
int pushButtonSTARTstate = 0;
int timeHOLD;
int timeSEC = 0;
int HorMinSec = 0;
int step_funzione = 0;
// Grafica per clessidra e cursore
uint8_t testChar[8] = {0x1F, 0x17, 0x1B, 0x1D, 0x1D, 0x1B, 0x17, 0x1F,};
uint8_t testClessidra[8] = {0x1F, 0x11, 0x0A, 0x04, 0x04, 0x0E, 0x1F, 0x1F,};
  xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                            VOID  SETUP                    VOID  SETUP
void setup() {
  lcd.begin();
  Serial.begin(9600);
  Serial.begin(9600);
  pinMode(pushButton, INPUT); // dichiara che il "pushButton" è un input:
  pinMode(pushButtonSTART, INPUT);
  pinMode(start, INPUT);    //Pin de pulsador de arranque --> Entrada
  pinMode(encoder0PinA, INPUT);
  pinMode(encoder0PinB, INPUT);
  digitalWrite(encoder0PinB, HIGH);
  digitalWrite(encoder0PinA, HIGH);
  int pushButtonSTARTstate = HIGH;   //  RESISTENZA PULL UP DEL PULSANTE  START
  attachInterrupt(1, doEncoderB, FALLING);
  // CARICAMENTO dei valori temporali (ore, minuti, secondi)
  lastencoderValue3 = EEPROM.read(1);
  lastencoderValue2 = EEPROM.read(2);
  lastencoderValue = EEPROM.read(3);
// portare i resitori interni a pull up
  pinMode(encoderPin1, INPUT_PULLUP);
  pinMode(encoderPin2, INPUT_PULLUP);
  pinMode(pushButtonSTART, INPUT_PULLUP);
  pinMode(pushButtonSTARTstate, INPUT_PULLUP);
  pinMode(pushButton, INPUT_PULLUP);
  digitalWrite(pushButton, HIGH);  // forza il pin  a livello alto sfruttando la resistenza di pull-up interna ad arduino
  pinMode(buzzer, OUTPUT);
  pinMode(rele, OUTPUT);
 // presentazione iniziale
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Timer Arduino");
  lcd.setCursor(0, 1);
  lcd.print("D.T Channel");
  delay(2000);
  lcd.clear();
  lcd.print("Vers. Firmware");
  lcd.print("Beta 0.1");
  delay(2000);
  lcd.clear();
  msg = 0;
  empieza = 1024;
// CREAZIONE DEI DUE CARATTERI CUSTOM
  lcd.createChar(0, testChar); // Sends the custom char to lcd
  lcd.createChar(1, testClessidra); // Sends the custom char to lcd
                            VOID loop                    VOID  loop
void loop() {
  lcd.print((char)1);  // STAMPA LA CLESSIDRA
  if (update) {
    update = false;
    PastB ? encoder0Pos++ : encoder0Pos--;
  //  ore minuti secondi
  ore = lastencoderValue;
  minuti = lastencoderValue2;
  secondi = lastencoderValue3;
  switch (step_funzione) {
    case 0:    // STATO INIZIALE
      INIZIO();
      break;
    case 1:    // VAI ALLA FUNZIONE: EDIT TEMPO
      EDIT_TEMPO();
      break;
    case 2:    // VAI ALLA FUNZIONE: CONTO ALLA ROVESCIA
      COUNT_DOWN();
      break;
    case 3:    // VAI ALLA FUNZIONE: TEMPO SCADUTO
      TEMPO_SCADUTO();
      break;
//---------------------- FUNZIONE: INIZIO ---------------------- ----------------------------
void INIZIO() {
  lcd.print("   PREMI START  ");
  lcd.setCursor(4, 1);
  if (ore < 10) lcd.print("0");     // SE LE ORE SONO MENO DI 10, SCRIVI LO ZERO A SINISTRA.
  lcd.print(ore);                   // STAMPA LE ORE
  lcd.print(":");                   // STAMPA I DUE PUNTI
  if (minuti < 10) lcd.print("0");  // SE I MINUTI SONO MENO DI 10, SCRIVI LO ZERO A SINISTRA.
  lcd.print(minuti);                // STAMPA I MINUTI
  if (secondi < 10) lcd.print("0");  // SE I SECONDI SONO MENO DI 10, SCRIVI LO ZERO A SINISTRA.
  lcd.print(secondi);                // STAMPA I SECONDI
  //  VAI A SETTA TEMPO - - - - - - - - - - - - - - - - - - -
  int buttonState = digitalRead(pushButton);  //// PER ACCEDERE AL MENU EDITOR CON IL MANTENIMENTO DEL PULSANTE ENCODER
  if (buttonState == LOW) {
    delay (1000);
    Serial.println(timeSEC);
    timeSEC++;
  else {
    timeSEC = 0; //  AZZERAMENTO VARIABILE SEI SECONDI
  delay(100);
  if (timeSEC >= 2) {   //   VAI A EDITOR
    lcd.clear();
    timeSEC = 0;
    step_funzione = 1;
  //// ALLA PRESSIONE DEL PULSANTE START, VAI ALLA FUNZIONE: COUNT DOWN
  int pushButtonSTARTstate = digitalRead(pushButtonSTART);
  if (pushButtonSTARTstate == LOW) {
    lcd.clear();
    lcd.print("Partenza tempo");
    lcd.clear();
    timeSEC = 0;
    secondiTotali = secondi + (minuti * 60) + (ore * 60 * 60);  //Convierte el tiempo elegido en segundos!!
    digitalWrite (rele, HIGH);
    step_funzione = 2;
//---------------------- FUNZIONE: EDIT TEMPO ---------------------- ------------------------
void EDIT_TEMPO() {
  lcd.print("h");
  lcd.setCursor(1, 1);
  if (encoderValue < 10) lcd.print("0");
  if (encoderValue < 0) {
    encoderValue = 0;
    encoder0Pos = 0;
  if (timeSEC >= 2) {
    lcd.clear();
    timeSEC = 0;
    HorMinSec = 0;
    step_funzione = 0;
  if (HorMinSec >= 3) HorMinSec = 0;   //// AZZERA LA VARIABILE PER LO STEP  ORA MINUTI  SECONDI.
  //  FAI IN MODO CHE L' ENCODER NON SUPERI I 59
  if (encoderValue > 59) {
    encoderValue = 59;
    encoder0Pos = 59;
  lcd.print(encoderValue, DEC);
  lcd.print(":");
  lcd.print("m");
  if (encoderValue2 < 10) lcd.print("0");
  if (encoderValue2 < 0) {
    encoderValue2 = 0;
    encoder0Pos = 0;
  if (encoderValue2 > 59) {
    encoderValue2 = 59;
    encoder0Pos = 59;
  lcd.print(encoderValue2, DEC);
  lcd.print(":");
  lcd.setCursor(8, 1);
  lcd.print("s");
  if (encoderValue3 < 10) lcd.print("0");
  if (encoderValue3 < 0) {
    encoderValue3 = 0;
    encoder0Pos = 0;
  if (encoderValue3 > 59) {
    encoderValue3 = 59;
    encoder0Pos = 59;
  lcd.print(encoderValue3, DEC);
  lcd.print(" ");
  // VISUALIZZA LO STATO SE STIAMO SETTANDO LE ORE, I MINUTI OPPURE I SECONDI
  switch (HorMinSec) {
    case 0:    // ore
      lcd.print("Set ora");
      lcd.print((char)0);
      break;
    case 1:    // minuti
      lcd.print("Set minuti");
      lcd.print((char)0);
      break;
    case 2:    // secondi
      lcd.print("Set secondi");
      lcd.print((char)0);
      break;
    case 3:    // funzione  eccitazione / diseccitazione
      // lcd.setCursor(0, 0);
      // lcd.print("Set funzione");
      // lcd.setCursor(8, 1);
      // lcd.print((char)0);
      break;
  //  PASSA DA ORE A MINUTI A SECONDI QUANDO SI PREME IL PULSANTE DEL' ENCODER
  if (buttonState != lastButtonState)
    { HorMinSec++;
      lcd.clear();
  delay(100);
  lastButtonState = buttonState;
  // ESCI DALLA FUNZIONE EDITOR TEMPI PER ANDARE AD INIZIO CON IL TEMPO AGGIORNATO AL' EDITOR
    lcd.clear();
    lcd.clear();
    timeSEC = 0;
    lastencoderValue3 = encoderValue3;
    lastencoderValue2 = encoderValue2;
    lastencoderValue = encoderValue;
    EEPROM.write(1, lastencoderValue3);  // salvataggio su slot il valore
    EEPROM.write(2, lastencoderValue2);  // salvataggio su slot il valore
    EEPROM.write(3, lastencoderValue);  // salvataggio su slot il valore
    delay(500);
    step_funzione = 0;
//---------------------- CONTO ALLA ROVESCIA ---------------------- ----------------------
void COUNT_DOWN() {
  // PARTENZA CONTEGGIO SE LA VARIABILE secondiTotali è maggiore di 0
  while (secondiTotali > 0)
    //   RESET FORZATO SE MANTENIAMO PREMUTO IL TASTO START PER 3 SECONDI E RITORNA AD INIZIO
    int pushButtonSTARTstate = digitalRead(pushButtonSTART);  //// START   START   START    START   START
      timeSEC++;
    if (timeSEC >= 3) {
      lcd.clear();
      lcd.print(" reset forzato  ");
      lcd.print("xxxxxxxxxxxxxxxx");
      digitalWrite (rele, LOW);  // SPEGNE IL RELè
      delay(2000);
      lcd.clear();
      timeSEC = 0;
      step_funzione = 0;
      break;
    lcd.print(" Tempo residuo: ");
    delay (1000);         // DELAY PER CONTARE STEP DI UN SECONDO...NON TOCCARE
    secondiTotali--;
    ore = ((secondiTotali / 60) / 60);  // converte i secondi totali in ore
    minuti = (secondiTotali / 60) % 60; // converte i secondi totali in minuti
    secondi = secondiTotali % 60;       // converte i secondi totali in secondi
    lcd.print(ore);
    lcd.print(":");
    lcd.print(minuti);
    lcd.print(":");
    lcd.print(secondi);
    // VAI A FUNZIONE FINE TEMPO quando i secondi totali raggiungono il valore =0
    if (secondiTotali == 0)
      step_funzione = 3;  //  VAI AL' ULTIMO STADIO...TEMPO CHE RAGGIUNGE LO ZERO
      break;
//---------------------- TEMPO ESAURITO ---------------------- ------------------
void TEMPO_SCADUTO() {
  // AZZERA ALLA PRESSIONE DEL TASTO START E VAI AD INIZIO PRIMA DEL TEMPO DI 10 SECONDI
    lcd.clear();
    lcd.print("   ripristino   ");
    delay(1000);
    lcd.clear();
    timeSEC = 0;
    step_funzione = 0;
  lcd.print("   Fine tempo   ");
  lcd.print("Start=Ripristina");
  digitalWrite(buzzer, HIGH);
  delay(500);
  digitalWrite(buzzer, LOW);
  lcd.print("                ");
  contatoreFineTempo++;
  delay(500);
  lcd.clear();
// VAI A INIZIO LIVELLO QUANDO IL TEMPO DI 10 SECONDI è SCADUTO
  if (contatoreFineTempo >= 10) {
    contatoreFineTempo = 0;
    timeSEC = 0;
    step_funzione = 0;
//---------------------- INTERRUPT ENCODER LETTURA  ---------------------- ------------------
// PARAMETRI LEGATI ALLE LETTURE ENCODE TRAMITE INTERRUPT
void doEncoderB()
  PastB = (boolean)digitalRead(encoder0PinA);
  update = true;
  if (HorMinSec == 2)encoderValue3 = encoder0Pos;
  if (HorMinSec == 1)encoderValue2 = encoder0Pos;
  if (HorMinSec == 0)encoderValue = encoder0Pos;
Je library verwacht 3 parameters bij de begin() call, je geeft er 0.
Er is een LiquidCrystal_I2C library in de library manager van Arduino. Waarom die niet gebruikt?
