ik heb de 0,6 diameter maal 1100 windingen gedaan en dat als sec. hoogte ingevuld,
dus geen 41 maar 70 cm
en dan kom ik op:
sorry edit
weer mislukt, java pakt geen komma
effe wachten:
J A V A T C v.10 - CONSOLIDATED OUTPUT
zondag 23 oktober 2005 13:53:32
Units = Centimeters
Surrounding Inputs:
0 = Ground Plane Radius
0 = Wall Radius
0 = Wall Height
0 = Ceiling Radius
0 = Ceiling Height
Secondary Coil Inputs:
Current Profile = G.PROFILE_BARE
4.1 = Radius 1
4.1 = Radius 2
0 = Height 1
70 = Height 2
1100 = Turns
0.06 = Wire Diameter
Primary Coil Inputs:
0 = Radius 1
0 = Radius 2
0 = Height 1
0 = Height 2
0 = Turns
0 = Wire Diameter
0 = Primary Cap (uF)
0 = Desired Coupling (k)
Top Load Object Inputs (dimensions & topload or ground connection):
Secondary Outputs:
696.86 [kHz] = Secondary Resonant Frequency
90 [deg°] = Angle of Secondary
340 [cm] = Length of Winding
3.24 = Turns Per cm
2.49091 [cm] = Space Between Turns (edge to edge)
31 [awg] = Recommended Wire Size
283.37 [meters] = Length of Wire
41.46 = H/D Aspect Ratio
17.28 [ohms] = DC Resistance
8233 [ohms] = Reactance at Resonance
8234 [ohms] = Forward Transfer Impedance
0.712 [kg] = Weight of Wire
1.88 [mH] = Les-Effective Series Inductance
1.575 [mH] = Lee-Equivalent Energy Inductance
2.762 [mH] = Ldc-Low Frequency Inductance
27.739 [pF] = Ces-Effective Shunt Capacitance
23.228 [pF] = Cee-Equivalent Energy Capacitance
46.06 [pF] = Cdc-Low Frequency Capacitance
0.079 [mm] = Skin Depth
0 [pF] = Topload Effective Capacitance
Primary Outputs:
[kHz] = Primary Resonant Frequency
[%] = Percent Detuned
[deg°] = Angle of Primary
[cm] = Length of Wire
[cm] = Average spacing between turns (edge to edge)
[cm] = Primary to Secondary Clearance
[uH] = Ldc-Low Frequency Inductance
[uH] = Lm-Mutual Inductance
[k] = Coupling Coefficient
= Number of half cycles for energy transfer at K
[uS] = Time for total energy transfer (ideal quench time)
Transformer Inputs:
220 [volts] = Transformer Rated Input Voltage
8000 [volts] = Transformer Rated Output Voltage
50 [mA] = Transformer Rated Output Current
50 [Hz] = Mains Frequency
240 [volts] = Transformer Applied Voltage
0 [amps] = Transformer Ballast Current
0 [ohms] = Measured Primary Resistance
0 [ohms] = Measured Secondary Resistance
Transformer Outputs:
400 [volt*amps] = Rated Transformer VA
160000 [ohms] = Transformer Impedence
8727.3 [rms volts] = Effective Output Voltage
2 [rms amps] = Effective Input Current
476 [volt*amps] = Effective Input VA
0.0199 [uF] = Resonant Cap Size
0.0298 [uF] = Static gap LTR Cap Size
0.0519 [uF] = SRSG LTR Cap Size
26 [uF] = Power Factor Cap Size
12340 [peak volts] = Voltage Across Cap
43623 [peak volts] = Recommended Cap Voltage Rating
0 [joules] = Primary Cap Energy
[peak amps] = Primary Instantaneous Current
80.1 [cm] = Spark Length (JF equation using Resonance Research Corp. factors)
[Bericht gewijzigd door
tritium
op zondag 23 oktober 2005 13:54:12
