Zo,
Nu heb ik het
Dit zegt hij
code:
Import Netlist Info: CIRCUIT2.PCB
TimeStamp: Thursday, March 15, 2007 07:54:02
Updating project
Load Calay Componentslist: C:\Documents and Settings\ \Bureaublad\Circuit2.CMP
Shape not Found: 0 0 0, BAT85 D1 DIO_DO34,
Shape not Found: 0 0 0, BAT85 D2 DIO_DO34,
Shape not Found: 0 0 0, HDR1X4 J1 HDR1X4,
Shape not Found: 0, DIP8 U2 DIP8 0 0,
Shape not Found: 4R7_5 0 0 0, 1.0kOhm_5% R1 R020,
Shape not Found: R7_5 0 0 0, 33kOhm_5% R2 R0204,
Shape not Found: 5 0 0 0, 1.0nF C4 KERKO5X4R,
Shape not Found: 0R5 0 0 0, 470uF-POL C5 ELKO1,
Shape not Found: 0R5 0 0 0, 220uF-POL C1 ELKO1,
Shape not Found: 0R5 0 0 0, 220uF-POL C2 ELKO1,
Shape not Found: 0 0 0, 10nF C3 KERKO6X5R5,
Load Calay Netlist: C:\DOCUMENTS AND SETTINGS\\BUREAUBLAD\CIRCUIT2.NET
Add Net: 6
Netlist Error Net: 2 Comp: D1 Pin: 0
Netlist Error Net: 2 Comp: D2 Pin: 0
Netlist Error Net: 2 Comp: C2 Pin: 0
Add Net: 9
Netlist Error Net: 3 Comp: D1 Pin: 0
Netlist Error Net: 3 Comp: J1 Pin: 4
Netlist Error Net: 3 Comp: U2 Pin: 4
Netlist Error Net: 3 Comp: U2 Pin: 8
Netlist Error Net: 3 Comp: R1 Pin: 1
Netlist Error Net: 3 Comp: C5 Pin: 0
Add Net: 4
Netlist Error Net: 4 Comp: D2 Pin: 0
Netlist Error Net: 4 Comp: J1 Pin: 2
Netlist Error Net: 4 Comp: C1 Pin: 0
Add Net: 3
Netlist Error Net: 5 Comp: J1 Pin: 1
Netlist Error Net: 5 Comp: J1 Pin: 3
Netlist Error Net: 5 Comp: U2 Pin: 1
Netlist Error Net: 5 Comp: C4 Pin: 2
Netlist Error Net: 5 Comp: C5 Pin: 0
Netlist Error Net: 5 Comp: C1 Pin: 0
Netlist Error Net: 5 Comp: C3 Pin: 2
Add Net: 2
Netlist Error Net: 6 Comp: U2 Pin: 2
Netlist Error Net: 6 Comp: U2 Pin: 6
Netlist Error Net: 6 Comp: R2 Pin: 2
Netlist Error Net: 6 Comp: C4 Pin: 1
Add Net: 1
Netlist Error Net: 7 Comp: U2 Pin: 3
Netlist Error Net: 7 Comp: C2 Pin: 0
Add Net: 5
Netlist Error Net: 8 Comp: U2 Pin: 5
Netlist Error Net: 8 Comp: C3 Pin: 1
Add Net: 8
Netlist Error Net: 9 Comp: U2 Pin: 7
Netlist Error Net: 9 Comp: R1 Pin: 2
Netlist Error Net: 9 Comp: R2 Pin: 1
Maar er komen verder ook geen componenten op mn beeld te staan..
Als jullie hier even naar willen kijken..
Ik heb eerst een schema getekend in multisim
daarna geexporteerd,
en dan geeft hij dede foutmelding
Wat is er mis?
En Frirs wat is er niet?
