als ik deze blok code
code:
#include <U8g2lib.h>
#include <U8x8lib.h>
// This is the display object. You will change this line if you are using pins
// other that 12, 11, 9 and 10.
U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
// This is the battery bitmap// This is the area inside the battery bitmap, in pixels
static const PROGMEM unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
#define CHARGE_AREA_START_X 20
#define CHARGE_AREA_START_Y 18
#define CHARGE_AREA_WIDTH 83
#define CHARGE_AREA_HEIGHT 28
// This is the battery fill mode
// BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
// a solid rectangle according to the battery charge.
// BATTERY_MODE_SOLID = 0 means the battery will be filled with a
// rectangle subdivided in 3. If the battery level is 66% or more, it will
// draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
// draw 1 rectagle if the battery is less than 33%.
#define BATTERY_MODE_SOLID 1
// This is the main function, and the one you will want to transplant to your
// code. Pass the battery charge percent and it will draw the battery with
// the corresponding charge level.
void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
display.clearBuffer();
display.drawXBMP(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
display.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 0; i < bars; i++)
display.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
display.sendBuffer();
float accuspanning = 0.0;
int accuvol = 135; //(volle accu 13,5V)
int acculeeg = 110; //(lege accu 11,0V)
int percentage;
void setup()
// Initialize the display object
display.begin();
pinMode(A0, INPUT); //neem ingang A0
void loop()
// Some test code to scan all the battery levels
// *3 is de spanningsdeler van de weerstanden
// *10 omdat de map niet met kommagetallen werkt. 13,5V => 135
accuspanning = ((analogRead(A0) * 5.0) / 1024.0 ) *3 *10;
percentage = map(accuspanning, accuvol, acculeeg, 100, 0);
if (percentage < 0) { percentage = 0;}
if (percentage > 100) { percentage = 100;}
showBatteryLevel(percentage);
delay(200);
hier ingeef op de website, en ik kies programmeertaal C, dan verdwijnt er een heel stuk in het begin (die bitmap)
c code:
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
offset += 28;
int percentage;
void setup()
display.begin();
void loop()
delay(200);
het probleem is dus dat ik die code fysiek niet kan testen, maar als ik dus mijn code hier post tussen code=C tags, dan verdwijnen er regels en kan de topicstarter niet compileren...
zit ik dus al 3paginas lang naar code te zoeken die niet werkt bij TS, terwijl de website hier gewoon stukken verwijderd.
vanaf de eerste post van TS, was die code al verdwenen
https://www.circuitsonline.net/forum/view/142873/1
op de 8e regel had die blok hex code moeten staan. ik ben van daaruit gestart en had al hopen ellende om te compileren
