c code verdwijnt
als ik deze blok code
code:
#include <U8g2lib.h>
 #include <U8x8lib.h>
 // This is the display object. You will change this line if you are using pins
 // other that 12, 11, 9 and 10.
 U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
 // This is the battery bitmap// This is the area inside the battery bitmap, in pixels
 static const PROGMEM unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
 #define CHARGE_AREA_START_X 20
 #define CHARGE_AREA_START_Y 18
 #define CHARGE_AREA_WIDTH 83
 #define CHARGE_AREA_HEIGHT 28
 // This is the battery fill mode
 // BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
 // a solid rectangle according to the battery charge.
 // BATTERY_MODE_SOLID = 0 means the battery will be filled with a
 // rectangle subdivided in 3. If the battery level is 66% or more, it will
 // draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
 // draw 1 rectagle if the battery is less than 33%.
 #define BATTERY_MODE_SOLID 1
 // This is the main function, and the one you will want to transplant to your
 // code. Pass the battery charge percent and it will draw the battery with
 // the corresponding charge level.
 void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
display.clearBuffer();
display.drawXBMP(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
display.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 0; i < bars; i++)
display.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
display.sendBuffer();
float accuspanning = 0.0;
int accuvol = 135; //(volle accu 13,5V)
int acculeeg = 110; //(lege accu 11,0V)
int percentage;
void setup()
// Initialize the display object
display.begin();
pinMode(A0, INPUT); //neem ingang A0
void loop()
// Some test code to scan all the battery levels
// *3 is de spanningsdeler van de weerstanden
// *10 omdat de map niet met kommagetallen werkt. 13,5V => 135
accuspanning = ((analogRead(A0) * 5.0) / 1024.0 ) *3 *10;
percentage = map(accuspanning, accuvol, acculeeg, 100, 0);
if (percentage < 0) {  percentage = 0;}
if (percentage > 100) { percentage = 100;}
showBatteryLevel(percentage);
delay(200);
hier ingeef op de website, en ik kies programmeertaal C, dan verdwijnt er een heel stuk in het begin (die bitmap)
c code:
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
offset += 28;
int percentage;
void setup()
display.begin();
void loop()
delay(200);
het probleem is dus dat ik die code fysiek niet kan testen, maar als ik dus mijn code hier post tussen code=C tags, dan verdwijnen er regels en kan de topicstarter niet compileren...
zit ik dus al 3paginas lang naar code te zoeken die niet werkt bij TS, terwijl de website hier gewoon stukken verwijderd.
vanaf de eerste post van TS, was die code al verdwenen
https://www.circuitsonline.net/forum/view/142873/1
op de 8e regel had die blok hex code moeten staan. ik ben van daaruit gestart en had al hopen ellende om te compileren
Frederick E. Terman
Het gekke is dat die bitmap er wel is. Als ik je post quote, dan zit de bitmap in zowel het eerste, als in het tweede blok code.
De code is dus niet weg, maar wordt bij lezen van je bericht in het tweede blok niet mee afgebeeld.
Uit de post waarnaar je verwijst kan ik hem ook gewoon weer kopiëren:
(et cetera)
yep, maar ik kopieer die blok (en TS ook altijd) en plak die in mijn arduino software. en daar loopt het dan fout want is niet mee gekopieerd.
dat hele stuk wordt verborgen gezet.
code:
de vraag is WAAROM de website een 'static const' eruit gooit. als die dat met andere arduino code ook begint te doen...
en vooral, is er nog code die zo gefilterd wordt?
Hewlett
:+ het kan wel
c code:
//iets
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
offset += 28;
int percentage;
void setup()
display.begin();
void loop()
delay(200);
ja, het kan, maar als ik telkens al mijn code moet gaan nalezen omdat er iets verdwenen kan zijn....
De parser zal wel een maximale regellengte hebben. (hij ziet die bitmap als één regel...)
GJ_
Mijn schuld ook nog: ik heb die code tags gezet omdat de code zo in de post gezet was.
Hoe het komt weet ik niet, dat is iets voor onze geliefde opperCO.
Hewlett
Ja, het is overflow gerelateerd, de parser heeft een max lengte voor iets. Als ik in mijn post de //iets weghaal dan verdwijnt het hele array. Lege regels in de array definitie hebben geen effect. Kennelijk gaat bij het zien van de commentaar regel de parser in een andere state en wordt het complete array wel weergegeven.
Heel irritant want je kunt er niet op vertrouwen dat je post de complete code bevat.
EricP
mét CE
Afgezien van dat het een bug op de site lijkt (oei oei... overflows in 2018... ouch!) :+, is het natuurlijk ook niet echt handig om dat soort complete lappen code te posten. Hang het dan gewoon als attachment ergens. Als iemand het wel compileren is dat minder gedoe. En om een specifiek probleem aan te geven is een snippet van zeg 10 regels doorgaans voldoende...
Dat is op z'n minst controversieel....
De mensen die de problemen hebben, weten altijd de code te quoten die het, mits de rest goed is, gewoon zou moeten werken. Dus vaak het advies om de HELE code te posten.
Als iemand dan een GROTE lap code post dan zou de "code viewer" van CO in actie moeten komen. Het belangrijkste stuk, direct zichtbaar zoals jij voorstelt, maar de rest beschikbaar achter 1 click voor degenen die de rest willen zien of de boel zelf willen copieren om te compileren.
Bij het invoeren zou dan gevraagd moeten worden: "wijs 10-15 regels aan die het belangrijkste zijn".
Maar ja. De code daarvoor moet nog helemaal geschreven worden. Wie daar tijd voor heeft mag z'n vinger opsteken.
EricP
mét CE
Maar waarom moet dat 'inline'?
Net zoals dat bij beeld- en geluidsbestanden het opstarten van een viewer scheelt.
Jeroen
Er werd een limiet bereikt waardoor inderdaad een deel van de code verdween. Ik heb nu een instelling aangepast waardoor dat niet meer voor zou moeten komen. Ik ga wel op zoek naar een andere manier om code te highlighten, want de library die we nu gebruiken is niet ideaal.
Ik ben het eens met EricP dat het niet handig is om hele lappen code te posten. Los van dat het onoverzichtelijk wordt bij het bewerken van je post, moeten bezoekers ook nog flink scrollen (mobiel vooral). Een bijlage aan je post toevoegen is dan handiger.
Om code te posten kun je ook gebruik maken van gist.github.com (Al is dat wat ingewikkelder dan gewoon de tekst copy-pasten, voor lange lappen is het overzichtelijker)
Ik erger me ook aan andere sites waar ik door een "letterbox" naar de geposte code moet kijken. Dus een klein scroll window waar ik geen overzicht heb.
Dus misschien is het makkelijk om zo'n scrollende box te maken, die default niet te groot staat. Maar dan een button er bij die floep het hele ding uitvouwt?
Zo'n 'letterbox' kan best handig zijn, als 'ie niet al te klein is en ook over de volle breedte.
(sommige sites hebben een heel korte en smalle box wat heel ergerlijk is. Je scrollt dan continu van boven naar beneden en van links naar rechts... :( )
Wat je soms ook ziet is dat je in zo'n codebox de inhoud kunt selecteren (copy) met [shift] + [rechter muistoets], heel erg handig...
EricP
mét CE
Maar... wat is nou eigenlijk het probleem wat opgelost moet worden? Afgezien van dat lengte-issue...
Als je naar de (voorbeeld?) code van fcapri kijkt... die hele bitmap is al niet zo relevant.
Als je de hele code gewoon beschikbaar stelt en alleen het stukje waar het om gaat inline zet... Dan zijn we er toch? Wil je de hele code... klik-klik op de link. Klaar. (nou ja, bij mij doet dat een 'save', maar dat wil ik zelf zo). Minste werk voor Jeroen. En hoe vaak zul je de inline code als het een hele lap is ook echt bekijken?
Op 22 november 2018 12:10:16 schreef EricP:
...alleen het stukje waar het om gaat inline zet...
Jep! Maar dat beoordelen waar het om gaat dat vertrouw ik JOU wel toe, maar de gemiddelde bezoeker hier niet.
Als je "aanwijzingen" gaat geven in de FAQ van: "post de volledige sourcecode op gits.github, zet de relevante code hier", dan kan je er van op aan dat het niet opgevolgd wordt. Is er een niewe
code:
 tag, dan kan je promoten dat die gebruikt wordt. Deels doordat moderators de postings editen en ze toevoegen. En als een voorstel niet bevalt, dan kan je de boel aanpassen om de boel op een andere manier te renderen.
Een ander nadeel van "zet de boel extern" is dat het forum dan na enkele jaren niet meer compleet is. Iemand post: "ik heb problemen met ... ", antwoord: Laat je code eens zien?, de TS post z'n code met link naar gist. Er wordt wat gedisscussiered en het probleem wordt opgelost. Met als conclusie een link naar een gist met de werkende code. En een jaar later is die link dood. Iemand die dan het topic ziet heeft er niets meer aan. Veel beter om de boel binnen CO te houden.
EricP
mét CE
Waarom moet dat op github? Terwijl ik dit zit te tikken, zie ik hieronder een button 'upload' staan. Daar kun je dat source file prima in plakken.
Overigens is dat ongeveer de werkwijze die ik 20 jaar geleden met mijn collegae had: ik heb ellende met een stuk code. De volledige source staat <hier> (clearcase tree, versie nummer). Volgens mij gaat het hier fout. Wie kent deze API en vertelt me ff waar ik de Fine Manual niet goed gelezen heb (dat is doorgaans het probleem... soms in bug in de software waar je tegen aan kletst). Klein groepje. Wat nu een forum heet, ging daar gewoon per email. Werkte geweldig...
[Bericht gewijzigd door maartenbakker op donderdag 22 november 2018 16:53:28 (100%)
