capri
nogmaals de komplete sketch
#include <U8g2lib.h>
#include <U8x8lib.h>
// This is the display object. You will change this line if you are using pins
// other that 12, 11, 9 and 10.
U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
// This is the battery bitmap// This is the area inside the battery bitmap, in pixels
static const PROGMEM unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
#define CHARGE_AREA_START_X 20
#define CHARGE_AREA_START_Y 18
#define CHARGE_AREA_WIDTH 83
#define CHARGE_AREA_HEIGHT 28
// This is the battery fill mode
// BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
// a solid rectangle according to the battery charge.
// BATTERY_MODE_SOLID = 0 means the battery will be filled with a
// rectangle subdivided in 3. If the battery level is 66% or more, it will
// draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
// draw 1 rectagle if the battery is less than 33%.
#define BATTERY_MODE_SOLID 1
// This is the main function, and the one you will want to transplant to your
// code. Pass the battery charge percent and it will draw the battery with
// the corresponding charge level.
void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
display.clearBuffer();
display.drawXBMP(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
display.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 0; i < bars; i++)
display.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
display.sendBuffer();
float accuspanning = 0.0;
float accuvol = 13.5; //(volle accu 12,6V)
float acculeeg = 11.0; //(lege accu 10,0V)
int percent;
void setup()
// Initialize the display object
display.begin();
pinMode(A0, INPUT); //neem ingang A0
void loop()
// Some test code to scan all the battery levels
accuspanning = ((analogRead(A0) * 5.0) / 1024.0 ) *3;
percent = map(accuspanning, accuvol, acculeeg, 100, 0);
showBatteryLevel(percent);
delay(200);
