klok pic16f628
Lambiek
Op 23 september 2019 13:17:49 schreef MGP:
@Lambiek, misschien kun je mij ook vertellen of Proton de hardware I2C ondersteund?
Zo als ik al zei, I2C wordt gewoon ondersteund.
code:
I2Cin
Syntax
I2Cin Dpin, Cpin, Control, { Address }, [ Variable {, Variable…} ]
Overview
Receives a value from the I2C bus, and places it into variable/s.
Operators
Dpin is a Port.Pin constant that specifies the I/O pin that will be connected to the I2C device's
data line (SDA). This pin's I/O direction will be changed to input and will remain in that state after
the instruction is completed.
Cpin is a Port.Pin constant that specifies the I/O pin that will be connected to the I2C device's
clock line (SCL). This pin's I/O direction will be changed to output.
Variable is a user defined variable of type Bit, Byte, Word, Dword, Float, Array.
Control is a constant value or a byte sized variable expression.
Address is an optional constant value or a variable expression.
The I2Cin command operates as an I2C master, and may be used to interface with any device
that complies with the 2-wire I2C protocol. The most significant 7-bits of control byte contain the
control code and the slave address of the device being interfaced with. Bit-0 is the flag that indicates
whether a read or write command is being implemented.
For example, if we were interfacing to an external eeprom such as the 24LC32, the control
code would be %10100001 or $A1. The most significant 4-bits (1010) are the eeprom's unique
slave address. Bits 1 to 3 reflect the three address pins of the eeprom. And bit-0 is set to signify
that we wish to read from the eeprom. Note that this bit is automatically set by the I2Cin command,
regardless of its initial setting.
code:
I2Cout
Syntax
I2Cout Control, { Address }, [ OutputData ]
Overview
Transmit a value to the I2C bus, by first sending the control and optional address out of the
clock pin (SCL), and data pin (SDA).
Operators
Address is an optional constant, variable, or expression.
OutputData is a list of variables, constants, expressions and modifiers that informs I2Cout how
to format outgoing data. I2Cout can transmit individual or repeating bytes, convert values into
decimal, hex or binary text representations, or transmit strings of bytes from variable arrays.
These actions can be combined in any order in the OutputData list.
The I2Cout command operates as an I2C master and may be used to interface with any device
code would be %10100000 or $A0. The most significant 4-bits (1010) are the eeprom's unique
slave address. Bits 1 to 3 reflect the three address pins of the eeprom. And Bit-0 is clear to signify
that we wish to write to the eeprom. Note that this bit is automatically cleared by the I2Cout
command, regardless of its initial value.
Dat bedoel ik nou met wazig: bij die i2cin/out commando's staat nergens duidelijk of het hardware of een software implementatie is...
(ik vermoed het laatste)
Maar hardware i2c aansturen kan altijd: direct de betreffende registers aansturen. (niet echt ingewikkeld)
Lambiek
Op 23 september 2019 14:15:34 schreef Arco:
Ja, echt duidelijk is het niet. :)
Ik doe het altijd met de daarvoor bestemde pinnen met dit commando.
pic basic code:
Declare SCL_Pin PORTC.3           ; I2C klok pin
Declare SDA_Pin PORTC.4           ; I2C data pin
Declare I2C_SLOW_BUS 1            ; I2C bus op 100KHz
En dan gewoon de juiste data versturen.
Zoals ik al vermoedde is alles software aangezien je elke pin kunt kiezen als SDA of SCL wat bij hardware I2C niet mogelijk is.
Bij MikroBasic heb je meer mogelijkheden volgens zien, maar voor gewone toepassingen is software I2C meer dan voldoende.
Op 23 september 2019 14:01:22 schreef Lambiek:
Dat was de vraag niet ;)
LDmicro user.
Ik heb toch liever hardware i2c voor betrouwbare toepassingen.
Met softwarimplementaties weet je nooit hoe errors worden afgevangen. (veel software blijft gewoon hangen als er iets onverwachts gebeurt...)
Als het toch softwarematig moet, dan zou ik de library zeker zelf schrijven. Geldt trouwens ook voor de hardware library hoor...
(ook die hangen meestal bij onverwarchte gebeurtenissen.)
Dat een systeem hangt bij een i2c fout is volstrekt onacceptabel.
Library's schrijven is niet voor iedereen weggelegd en als die dan nog uitgebreid moeten getest worden al zeker niet.
Op 23 september 2019 18:10:36 schreef Arco:
Over doemscenario's gesproken ..
Het zou toch heel jammer zijn moesten de software I2C implementatie's in Picbasic of Mikrobasic nog altijd niet goed werken.
LDmicro user.
Lambiek
Op 23 september 2019 17:58:27 schreef MGP:
Ik had het de hele tijd al over de hardware toepassing, ik gebruik de I2C toepassing nooit.
En bij de hardware toepassing zijn er maar een paar pinnen die je kunt gebruiken.
Als bijv. om een of andere reden de SDA of SCL lijn laag blijven (da's geen doemscenario: het gebeurt), dan hangen de meeste libraries (hard of software).
En dat is onacceptabel.
Op 23 september 2019 18:27:20 schreef Lambiek:
Heb je zelf die library geschreven? volgens de handleiding kun je elke pin kiezen en dat is dus software I2C of BUScontrol.
@Arco, Tja ..wat kun je daar tegen doen? ik zou het niet weten en met een zelfgeschreven library ben je ook nooit 100% zeker.
Om nog niet te spreken over programmeerfouten... :S
LDmicro user.
Alle punten waar je moet wachten op iets voorzien van een time-out. Iets meer code, maar de boel blokkeert nooit meer.
(je kunt dan de gebruiker in ieder geval nog informeren over het defect. Bij 'hangen' kan dat niet meer)
Bavelt
Binnen enkele dagen ontvang ik de PIC 16F1826's. Die hebben een hardwarematige I2C en dan maar weer verder gaan.
Ik ben pas begonnen met de microcontrollers, maar ik merk dat er erg veel bij komt kijken en je rolt van het een in het ander.
Ledjes aansturen, geluidje maken lukt nu prima. De volgende stap in mijn 'leergang'is nu het geluid afhankelijk te maken van de datum (bv op verjaardag ander toontje). Daarvoor had ik de RTC DS3231 aangeschaft, die met I2C werkt.
Daarmee wilde ik de datum en/of tijd uitlezen (die je natuurlijk ook moet 'setten').
Ik heb een hele dag allerlei voorbeelden geprobeerd. Veel zijn in C geschreven. Dus dan maar de C-compiler van MPLAb geïnstalleerd. Voor je die aan de praat hebt ben je zomaar een paar uur verder.
De voorbeelden geven in veel gevallen dan ook compilatie errors omdat er variabelen zijn die hij niet kent of dat er wordt gerefereerd aan 'include's' die er niet zijn.
Nu kan ik me wel in C gaan verdiepen, maar na het volgen van de PICBasic cursus (die op enkele fronten ook weer wat verouderd schijnt te zijn) is dat toch een stap te ver.
Ik probeer het langzaam op te bouwen.
Ik heb nog gezocht naar conversieprogramma's van C naar PicBasic maar kon ze niet vinden.
Vallen en opstaan dus. Dat hoort nu eenmaal bij hobby's.
Gelukkig is dit forum er en ik heb al veel hulp ervaren!
Fouten zijn het bewijs dat je het probeert..
Start dan maar tegelijk een nieuw topic want ik heb u al de ganse tijd als TS aangewezen wat je natuurlijk niet bent ;)
LDmicro user.
Bavelt
En ik maar denken: wat is TS...
Op 23 september 2019 14:22:53 schreef Lambiek:
Ik heb nog eens de handleiding van Proton picbasic doorgenomen en ook die heeft 2 soorten I2C instructies.
-De "software" instructies zoals I2Cin, I2Cout, Busin, Busout kunnen gebruikt worden op PIC's die geen ingebouwd MSSP module hebben zoals een 16F628A en natuurlijk ook op alle andere pic's.
Daar kun je zelf de SDA en SCL pinnen kiezen.
-De "hardware" I2C instructies zoals Hbusin, Hbusout .. worden gebruikt op PIC's met ingebouwde MSSP module en daar liggen de SDA, SCL pinnen vast.
Bij deze pic's kun je ook die module gebruiken voor SPI data transferts.
Hiermee is een klein stukje van de discussie opgehelderd ;)
LDmicro user.
