Potentiometer
Hello,
I'm making a circuit however I'm struggling to find any cheap 470k Dual Gang Potentiometers would It be ok for me to use a 500k Potentiometer Instead.
Thanks,
Digital.
This depends on the circuit and the context.
.... but most often such a difference is not an issue. Most often the ratios matter and those will be the same for the 470k and the 500k pots.
big_fat_mama
Zie Paulinha_B
Het is belangrijker erop te letten of het een lineaire moet zijn dan wel een logaritmische. Het verschil 470k <=> 500k zal zelden relevant zijn, inderdaad.
Op 12 augustus 2020 21:03:07 schreef big_fat_mama:
An Attempted translation:
It is more important to verify if you need a liniair Potentiometer or a logarithmic Potentiometer.
The differenced 470k <=> 500k will indeed seldon be relevant.
(Added)
Audio circuitry normally uses Logarithmic Potentiometers.
Neovo.
Slechtziend aan linker oog, Blind aan rechter oog. Hosting van Forumbestanden: https://drive.google.com/drive/folders Meetarsenaal welke ik heb: https://drive.google.com/file/d/1vx54QxPe6YS3pJhybK_y0a380MYUFGyb/view
Hello,
It Is for a tone control the pot needs to be dual gang (stereo) and linear sorry for the very late response.
Thanks
