Dit relais heeft nogal wat mogelijkheden, dus ik ben geneigd te zeggen : "Ja"
P-1 : After the signal is triggered, the relay turns on the OP time and then turns off; during the OP time, the following operation
- P1.1 : Signal is invalid again
- P1.2 : The signal triggers the re-timing again
- P1.3 : The signal triggers reset again , the relay is disconnected, and the timing is stopped
P-2 : to the trigger signal, the relay is open CL after time, the relay is turned OP time, after completion of timing, open the relay;
- P3.1 : To trigger the signal, after the relay turns on the OP time, the relay turns off the CL time, and then it circulates the above-mentioned action. The signal is given again in the cycle, the relay is disconnected, and the timer is stopped; the number of loops ( LOP ) can be set; - P3.2 : After the power is turned on, no trigger signal is needed. The relay turns on the OP time, the relay turns off the CL time, and the above cycle is repeated; the number of loops ( LOP ) can be set;
P-4 : Signal Hold Function If there is a trigger signal, the timer is cleared and the relay remains on. When the signal disappears, the relay is turned off after the timing OP . During the timer, there is another signal and the timer is cleared.
