Hieronder vind je een tabel met daarin de 4000 serie IC's.
| Nummer | Pinnen | Omschrijving |
4000 4001 4002 4006 4007 4008 4009 4010 4011 4012 4013 4014 4015 4016 4017 4018 4019 4020 4021 4022 4023 4024 4025 4026 4027 4028 4029 4030 4031 4032 4033 4034 4035 4038 4040 4041 4042 4043 4044 4045 4046 4047 4048 4049 4050 4051 4052 4053 4054 4055 4056 4060 4063 4066 4067 4068 4069 4070 4071 4072 4073 4075 4076 4077 4078 4081 4082 4085 4086 4089 4093 4094 4095 4096 4097 4098 4099 4502 4503 4508 4510 4511 4512 4514 4515 4516 4517 4518 4520 4527 4529 4532 4536 4538 4541 4543 4555 4556 4582 4584 4585 4724 40085 40097 40098 40100 40101 40102 40103 40104 40105 40106 40107 40108 40109 40110 40147 40160 40161 40162 40163 40174 40175 40181 40182 40192 40193 40194 40257 |
14 14 14 14 14 16 16 16 14 14 14 16 16 14 16 16 16 16 16 16 14 14 14 16 16 16 16 14 16 16 16 24 16 16 16 14 16 16 16 16 16 14 16 16 16 16 16 16 16 16 16 16 16 14 24 14 14 14 14 14 14 14 16 14 14 14 14 14 14 16 14 16 14 14 24 16 16 16 16 24 16 16 16 24 24 16 16 16 16 16 16 16 16 16 14 16 16 16 16 14 16 16 16 16 16 16 14 16 16 16 16 14 8 24 16 16 16 16 16 16 16 16 16 24 16 16 16 16 16 |
Dual 3-Input Nor Gate
Plus Inverter Quad 2-Input Nor Gates Dual 4-Input Nor Gates 18-Bit Static Shift Register Dial Complimentary Pairs Plus Inverter 4-Bit Binary Ful Adder Hex Inverting Buffers Hex Buffers Quad 2-Input Nand Gates Dual 4-Imput Nand Gates Dual D Flip Flop With Set/Reset 8 Stage Static Shift Register Dual 4 Stage Static Shift Register Quad Bilateral Switches Decade Counter With 10 Outputs Presettable Divide-By-N Counter Quad And-Or Select Gates 14 Stage Binary Ripple Counter 8 Stage Static Shift Register Octal Counter With 8 Outputs Triple 3-Input Nand Gates 7-Stage Binary Counter Triple 3-Input Nor Gates Bcd Decade Counter, 7-Segment Decoder Dual J-K Master Slave Flip Flop Bcd To Decimal Decoder Presettable Up/Down Counter Quad Exclusive-Or Gates 64- Stage Shipt Register Triple Positive Logic Serial Adders Bcd Decade Counter, 7-Segment Decoder 8-Bit Bi-Directional Shift Register 4-Stage Parallel In/Out Shift Register Triple Negative Logic Serial Adders 12-Stage Binary/Ripple Counter Quad True/Complement Buffers Quad Clocked D-Latch Quad Nor R-S Latches (3-S) Quad Nand R-S Latches (3-S) 21-Stage Binary Counter/Divide W/Oscillator Micropower Phase-Locked Loop Monostable/Astable Multivibrator 8-Input Expandable Multifuntion Gate Hex Inverting Buffers/Converters Hex Buffers/Converters 8-Channel Mux/Demux Differential 4-Channel Multiplexer Triple 2'channel Multiplexer 4-Segment Lcd Driver Bcd To 7-Segment Decoder Lcd Bcd To 7-Segment Decoder Lcd Driver 14-Stage Binary Counter W/Osc. 4-Bit Magnitude Comparators Quad Bilateral Switches 16-Channel Analog Mux/Demux 8-Input Nand/And Gate Hex Inverters Quad 2-Input Exclusive-Or Gates Quad 2-Input Or Gates Dual 4-Input Of Gates Triple 3-Input And Gates Triple 3-Input Or Gates Quad D-Type Flip Flop Quad 2-Input Exclusive-Nor Gates 8-Input Nor/Or Gates Quad 2-Input And Gates Dual 4-Input And Gates Dual 2-Wide 2-Input And-Or-Invert Gates Expandable 4-Wide 2-Input And-Or-Invert Cascadable 4-Bit Binary Rate Multiplier Quad 2-Input Nand Schmitt Trigger Cascadable 4-Bit Binary Rate Multiplier Gated J-K Master Slave Flip-Flop Gated J-K Master Slave Flip-Flop Differential 8-Channel Mux/Demux Dual Monostable Multivibrators 8-Bit Addressable Latch Hex Strobed Inverting Buffers Hex Buffers (3-S) Dual 4-Bit Latchers Bcd Up/Down Counter Bcd To 7-Segment Latch/Decoder/Driver 8-Channel Data Selector/Multipexer 4-Bit Latch/4-To-16 Line Decoder/Demux 4-Bit Latch/4-To-16 Line Decoder/Demux Presettable 4-Bit Binary Up/Down Counter Dual 64-Stage Static Shift Register Dual Bcd Decade Counters Dual 4-Bit Binary Counters Cascadable Bcd Decade Rate Multiplier Dial 4-Channel Data Selector/Mux 8-To-3 Line Priority Encoder Programmable Timer Dual Retrig. Monostable Multivibrator Programmable Oscillator/Timer Bcd To 7-Segment Latch/Decoder/Lcd Driver Dual Binary To 1-Of-4 Decoder/Demux Dual Binary To 1-Of-4 Decoder/Demux Look-Ahead Carry Generator Hex Schmitt Trigger 4-Bit Magnitude Comparator 8-Bit Addressable Latch Cascadable 4-Bit Magnitude Comparator Hex Buffers Hex Inverting Buffers 32-Stage Static Left/Right Shift Register 9-Bit Parity Generator/Checker Presettable Sync. Bcd 2-Decade Down Conter Presettable Sync. 8-Bit Binary Down Counter 4-Bit Bidir. Univ. Shift Register 16-Word By 4-Bit Fifo Register Hex Schmitt Triggers Dual 2-Input Nand Buffers/Drivers 4x4 Multiport Register Quad Low-To-High Voltage Level Shifters Bcd Decade Up/Down Counter/Decoder 10-To-4 Bcd Priority Encoder Sync. Bcd Decade Counter W/Clear Sync 4-Bit Binary Counter W/Clear Sync. Bcd Decade Counter W/Sync. Clear Sync. 4-Bit Binary Counter W/Sync. Clear Hex D-Type Flip Flops Single Rail Output Quad D-Type Flip Flops Single Rail Output Arithmetic Logic Unit/Function Generator Look Ahead Carry Generator Sync. Bcd Decade Up/Down Couter Sync. 4-Bit Binary Up/Down Counter 4-Bit Bidir. Univ. Shift Register Quad 2-To -1 Line Data Selector/Mux |
