Hi~all,thank you for taking time to read my post,my trouble is about "The PIC16F690 occurs error in the AD changing ".
The following is a part of the wrong program:
        INTCON=0XC0;//??????
        TMR1IE=1;//????
        TMR1L=(65536-2000)%256;//?????????
        TMR1H=(65536-2000)/256;//?????????
        T1CON=0X01;//??????????2ms????
          g=getad1();//????
          r=getad();//????
        while((r>80&&r<180)&&(g>4&&g<89))
                g=getad1();//????
                  r=getad();//????
        PORTB=0;
void reset()
        OSCCON=0x61; //????4M ????????
        TRISA=0XFF; //A????????
        TRISB=0X30;        //RB6\RB7???????RB4\RB5?AD??????B??????4??????
        TRISC=0; //C??RC4\RC5\RC6\RC7??????????????
        PORTB=0;//???????????????????????
        ADRESH=0;         //AD????????
        ADRESL=0;   //AD????????
        ANSELH=0X0C;//AN10?AN11?????xxxx1111?XXXX AN11\AN10\AN9\AN8
void delay(uint x)
        uint a,b;
        for(a=x;a>0;a--)
                for(b=108;b>0;b--);
void delayus(uint x ,uchar y)
        uint i;
        uchar j;
        for(i=x;i>0;i--);
        for(j=y;j>0;j--);
uchar getad1()//????????
        uchar adval;
        ADCON1=0X10;//ADCON1=0X10;//??fosc/8   //ADCON1=0X50;fosc/16??????
        ADCON0=0X29;//??AN10 ADCON0=0X29;??AN11 ADCON0=0X2D;??????
        delay(1);//????????
        GO=1;//????
        while(GO);//???????
        adval=ADRESH;//??????
        ADON=0;//??AD???
        return(adval);
uchar getad()//????????
        uchar adval;
        ADCON0=0X2D;//??AN10 ADCON0=0X29;??AN11 ADCON0=0X2D;
        delay(1);//????????
        GO=1;//????
        while(GO);//???????
        ADON=0;//??AD???
        return(adval);
void interrupt kk()//????
        T1IF=0;//????????
        TMR1L=(65536-2000)%256;//????2ms
        PORTC=~PORTC;//??????
The phenomenon is if I use my own two AD changing program,the output level of PORTB will change when PORTB = 0X40. AD changing will influence other pins? The open circuit and short circuit is normal ,and PORTB changed even it didn’t trigger protection. In another situation,when I isolate the AD changing in order to realizing the function,and the using also will be changed while PORTB is changing. Can you help me?
Thank you in advance!
