Tijdens het zoeken naar referentie waarden voor audio signalen kwam ik deze site tegen:
http://www.soundonsound.com/sos/jun00/articles/metring.htm
PPMs are also characterised by a slow fallback from displayed peaks, which is intended to make it easier to register the peak level visually — Type I meters should take between 1.4 and 2.0 seconds to fall 20dB whereas Type II meters should fall 24dB within 2.5 to 3.1 seconds. Furthermore, Type II meters also incorporate a delay of between 75mS and 150mS before the fallback occurs — effectively a peak-hold condition — which helps reduce eye fatigue
In Europe 0dBu has been standardised by the EBU to be -18dBFS, in order that a signal peaking in analogue equipment at the top of the EBU-standard PPM scale — and therefore with true peaks at around +16dBu — remains a little below the digital full scale value. Just to be awkward, though, the American SMPTE organisation set their standard for 0dBu at -20dBFS instead...
Nuttig artikel wat de diverse audio signaal normen toelicht
