Dear all,
my Philips Matchline 100Hz TV, Model No. 32PW9611/01 stwitches off automatically after 15 Min of operation. The red LED is flashing. I need to switch off the main connector and wait a few minutes until I can switch it back on.
Somewhere else in the internet I found that it might have the chassis GFL2.20E (but I dont't know if this is correct).
Also I found something about a status menu which displays error codes, which could be entered by pressing MENU + MUTE, but this does not work.
Unfortunately the Philips Support site says "no documentation available for COLOUR TV 32 INCH 32PW9611/01".
Does anyone has any idea what to do?
Thanks in advance!
Kind regards, Agfa
Zoef de Haas.
Most likely bad connections on the print-board. Driver transformers, coils and the east/west transformers have frequently loose connection pins. Also the fly-back capacitor will loose her capacity, is mostly either 8.2 or 9.6 Nf. This will trigger the protection circuits and after resetting by switching off than the unit works again for a while.
Greetings Hans.
