hallo iedereen,
Voor school moet ik een opdracht maken over verschillende µC's, hoe je ze moet programmeren en welke toepassingen er bestaan voor die specifieke µC.
Een hiervan is de EPLD, na lang zoeken op google en wikipedia heb ik nog altijd niet genoeg info.
Enkel dat je hem kan wissen dmv UV-licht.
Hebben jullie nog links/info over deze?
Dank op voorbaat
lau931
Short for electrically programmable logic device, an integrated circuit that is comprised of an array of programmable logic devices that do not come pre-connected; the connections are programmed electrically by the user.
Dan klik je verder op programmable logic devices en krijg je.
Short for programmable logic device, a generic term for an integrated circuit that can be programmed in a laboratory to perform complex functions. A PLD consists of arrays of AND and OR gates. A system designer implements a logic design with a device programmer that blows fuses on the PLD to control gate operation.
System designers can use development software that converts basic code into instructions a device programmer needs to implement a design.
PLD types can classified into the following groups
# PROMs (Programmable Read Only Memory) - offer high speed and low cost for relatively small designs
# PLAs (Programmable Logic Array) - offer flexible features for more complex designs
# PAL/GALs (Programmable Array Logic/Generic Array Logic) - offer good flexibility and are faster and less expensive than PLAs
Was de 1e link op google. Alleen nog even naar het nederlands vertalen enklaar.
