Does anyone recognise the part HYT 30002005 so I can get a replacement , all I know is HYT is a Taiwanese manufacturer but nothing else.
Thanks in advance
Thanks for answer so quick, in answer to your question if I can upload a photo unfortunately not as I don't have a working digital camera.
But I can tell it comes from a PSU board 12PW14-4 (For a picture of the board itself
use this link) http://www.chsinteractive.co.uk/electrical-components/misc/dvr3003-pcb… but the board is obsolete.
As you can see it has 5 radial inductors with diameter 7mm by 12mm length other than that I can't tell much more.
30002005 in this context is a Vestel part number. HYT is only the OEM and is probably of no use. Is this one of the radial inductors you mention? Are you sure that particular part is broke, as it is virtually impossible to destroy. Most of the time, semiconductors and electrolytic capacitors break down on boards like this.
P.S. It seems this part is known as "Choke Coil 65µH 3A K 8x12 RoHS" so it is indeed one of the radial inductors. Now you know it's a 65u 3A coil, so you can obtain one if it is indeed faulty.
