I have new a brand new PTA style 1mm diameter tip Antex bit 56 http://http://www.antex.co.uk/product.asp?strParents=183&CAT_ID=195&P_… that I cannot tin to keep clean.
To date I have used a chisel tip with no problems, if I explain the sequence of events to clean and tin it hopefully someone could help.
Firstly solder is applied right up to the shoulder, secondly it is wiped on a damp sponge using a stroking motion whilst rotating the iron and therefore the bit but it is as before. Any ideas
I use brass shavings when the sponge is not enough anymore.
Like this: http://cgi.ebay.nl/ws/eBayISAPI.dll?ViewItem&item=350291630403
It brought old tips back to life that I thought were unusable. It seems that especially the finer tips gather more filth than the bigger ones. This brass stuff cleans then nicely. Just stab the iron in there a couple of times.
You can use a tip cleaner. (Like this one: http://nl.rs-online.com/web/search/searchBrowseAction.html?method=getP… )
It removes stubborn residues from the tip. Also it's best to apply leaded solder at the initial use.
(Lead-free gives a much less cleaner result)
