vergeten
NTE2060 zou compatibel moeten zijn: https://www.farnell.com/datasheets/1648543.pdf
Zie ook https://www.radiomuseum.org/tubes/tube_tms1951.html
[Bericht gewijzigd door deKees op (28%)]
vergeten
Ik vind wel dit (misschien even door een vertaalmachine sturen?):
https://www.elektroda.pl/rtvforum/topic658364.html
Met daarin deze info. Het is geen volledige datasheet, maar bevat wel veel informatie & volledige pinout:
Pinout and notes for the vintage TMS 1951NL clock chip
Pinout (40-pin DIL package)
+-------o-------+
AM --+ 1 40 +-- PM
10 hours b+c --+ 2 39 +-- 1 Hz
1 hours f --+ 3 38 +-- Select 24 Hours
1 hours g --+ 4 37 +-- NC
1 hours a --+ 5 36 +-- 50 Hz Select
1 hours b --+ 6 35 +-- 50 Hz
1 hours d --+ 7 34 +-- SET Fast
1 hours c --+ 8 33 +-- SET Slow
1 hours e --+ 9 32 +-- Display seconds
10 minutes f --+ 10 31 +-- Display alarm
10 minutes g --+ 11 30 +-- Display sleep
10 minutes a+d --+ 12 29 +-- VDD
10 minutes b --+ 13 28 +-- VSS
10 minutes e --+ 14 27 +-- Sleep out
10 minutes c --+ 15 26 +-- Alarm off
1 minute f --+ 16 25 +-- Alarm out
1 minute g --+ 17 24 +-- Snooze
1 minute a --+ 18 23 +-- OCS
1 minute b --+ 19 22 +-- 1 minute c
1 minute e --+ 20 21 +-- 1 minute d
Connection notes (incomplete notes, may be of use):
pin 1 AM: Connect to anode of AM indicator LED
pins 2-22 7-segment LED segments: use common cathode LED's.
Segments are driven high from the 12V supply. The
cathode voltage must be appropriate for the correct
voltage drop across the LED segments. A voltage
regulator can be used for this or individual
series resistors at each segment output
pin 23 OCS: Connect to +12V
pin 24 Snooze: Connect to +12V via a push button. Pushing
the button when the alarm sounds silences the alarm
for a period of about 9 minutes, whereupon it sounds
again
pin 25 Alarm out: driven high (+12V) when the alarm activates
pin 26 Alarm off: connect via a switch and pushbutton to +12V.
When the switch is closed, the alarm is disabled.
When the switch is open, the alarm sounds and the
pushbutton momentarily connects to +12V, the alarm
is silenced
pin 27 Sleep out: driven high (+12V) when in sleep mode
pin 28 VSS: +12V power supply
pin 29 VDD: 0V ground
pin 30 Display sleep: Switch to +12V to show and set
the sleep period on the display
pin 31 Display alarm: Switch to +12V to show and set
the alarm time on the display
pin 32 Display seconds: Switch to +12V to show seconds
pin 33 SET Slow: push button to +12V for slow setting
pin 34 SET Fast: push button to +12V for fast setting
pin 35 50 Hz input: This is the main clocking input for
the MM5387. The 50 Hz signal can be obtained from
the 50 Hz mains frequency, or by division of a
cyrstal oscillator. 3.2768 MHz is a convenient
power of two, a simple counter circuit can divide
this down to 50 Hz. 3.2768 MHz crystals are used
in almost all digital watches and clocks, and are
very commonly available
pin 36 50 Hz: Connect to +12V for 50 Hz operation
pin 38 Leave unconnected for 12 hour display
pin 39 1 Hz: output signal produced by dividers in the MM5387
pin 40 PM: Connect to anode of PM indicator LED
Mogelijk dat de MM5387 en de TMS1951 identiek zijn, of in elk geval overeenkomsten vertonen? Stukje vertaling van die Poolse website:
"Description of the device design:
The main component of the clock is a vintage Texas Instruments TMS 1951NL specialized chip whose counterparts are LM8361 (Sanyo), MM5387 (Mitsubishi) and NTE2060 of which only the latter is still in production today. This chip was developed in the mid-1970s, and is made using P-MOS technology. The only difference that can be observed between the counterpart and the TI original is the resistance of the original's output ports to the ~30V needed to properly drive the VFD display. The timing pattern is taken directly from the electrical grid. Admittedly, it is possible to use an external generator, but I didn't want to do that.
The visualization element of this device is a Vaccum Fluorescent Display (VFD) made by the Japan [...]"
Hm. De copy/paste van de ASCII pinout van het IC komt er in mijn antwoord onleesbaar uit, ondanks dat het er in antwoord-formulier goed uitziet. Maar op de Poolse site ook goed terug te vinden, en ook in een text-editor goed leesbaar.
En zie ook https://www.radiomuseum.org/forum/modell_form_100a_beschreibung_und_re…
(zoek op die pagina naar '1951', er wordt veel aan dat IC gerefereerd op die pagina.)
Volgens mij moet u met die info er wel uit kunnen komen hoe het zaakje werkt.
Op zaterdag 1 februari 2025 00:41:05 schreef vergeten:
Dat vage schema bedoelde ik dus, niet leesbaar.
Het gaat mij om de application note.
Dat schema is prima leesbaar, maar je moet er even op klikken. Kan me wel voorstellen dat je niet voor 1 klein schema lid wilt worden als je dat nog niet bent.
Heb je ook doorgeklikt naar https://www.radiomuseum.org/forum/modell_form_100a_beschreibung_und_re…
Het gaat daar vooral over de AMI-variant van het IC maar er staat erg veel informatie bij.
EDIT: nonius was me voor.
vergeten
