hi,
i´m new in rotterdam and was wondering, if there are some people who can help me by providing etching facility for ordinary one-sided one-layer print? i was used to do it by myself but i don´t have any clue where i can make my own printed circuit boards? i already asked the guys from DIL, but they couldnt help me!
thank you very much!
bye
do you want to go to a amateur or by a professional firm?
No professional firm! I am working as an independent researcher developing different kind of interfaces. the pcbs are just to experiment for builiding prototypes! i have no problems in garage amateur etching ;) as long as the prints are somehow exact!
thanks a lot! bedankt!
Weekban voor knuppel de kleuter...
Sorry Ritzdank, it's wednesday, a day when little kids have free from school...
Hej ritzdank,
There is a store in rotterdam, called DIL,
they sell al kind of supply's for etching. (printed circuit board's in different sizes, the chemicall's to develop and etch with.
you can buy an etch tank there if you'd like, or build such a facility yourselve. Plastic boxes, a pair of plastic tweezers and a bit of patience will do just fine.
then there are devices, witch I can't find the correct english term for, most of the time women use is for there face to get a little brown color on there cheeks...? erm, well, you'll probably understand. in dutch it is called a 'gezichtsbruiner' and for sell for about 5 to 10 euro's on the internet.
check out www.dil.nl for the electronic store, location, and info, and don't hesitate to ask a few things.
greetings an succes! Madthijs
hej,
thanks for your instructions. yep, i know DIL already. i was just looking, if someone has these facilities in his leisure-room lying around ;)
i did it also like you described but the results were not that convincing, at least not, if you start to bother with SMD parts and layouts.
so, the call is still open, if someone (private person) has a "ets-bad" at home?
your help will be appreciated
Why not used Print Service Dordrecht. They are not that expensive and the quality is somehow simular to the PCB's you can make at home. However I hope all your PCB's are drilled completly. When I ordered I need to take out my own drill stand to drill some holes because they were forgotten.
Are you searching for somebody with the etch-facilities you need, in the neighbourhood, or some-one who can explain a few things? so you can upgrade your own skills?
I have a quite good etch facillity, in my opinion, for a hobbyist. I've done some iny-tiny smd pcb's now, witch I still etch by hand, they where about 20*20 mm.
Most of the time my 'normal' sized pcb's come out just fine, I think.
Be aware, there is a lot of trial and error in the proces, and that might scares you off...
For example, different brands of PCB base material brings different 'illumination'( ?) times.
The way youre 'illuminator' is build brings different times of illumination.
Different pcb-base materials bring different etch times, a stronger or weaker solution of etch chemicals bring different times etc etc etc.
as you see, lot's and lot's of things to learn to control when etching.
'practice teaches' Is my opinion.
greetings,
madthijs
