Ik wil met de JDM programmer van de site een 16F84A pic programmeren met Winpic maar ik krijg de volgende in het messages tabblad.
Programming...
Erasing ("bulk" or "chip") ...
Programming CODE, 0x000000..0x00027E
Verify Error: 000000: read 003FFF, wanted 002888
Verify Error: 000001: read 003FFF, wanted 003080
Verify Error: 000002: read 003FFF, wanted 00008D
Verify Error: 000003: read 003FFF, wanted 0030FE
Verify Error: 000004: read 003FFF, wanted 00205F
Verify Error: 000005: read 003FFF, wanted 003001
Verify Error: 000006: read 003FFF, wanted 00205F
Verify Error: 000007: read 003FFF, wanted 003075
Verify Error: 000008: read 003FFF, wanted 000092
Verify Error: 000009: read 003FFF, wanted 003030
Verify Error: 00000A: read 003FFF, wanted 00286F
Verify Error: 00000B: read 003FFF, wanted 00018D
Verify Error: 00000C: read 003FFF, wanted 00178D
Verify Error: 00000D: read 003FFF, wanted 000098
Verify Error: 00000E: read 003FFF, wanted 0030FE
Verify Error: 00000F: read 003FFF, wanted 00205F
Verify Error: 000010: read 003FFF, wanted 000818
Programming aborted after 17 errors.
Programming CONFIG, 0x002000..0x002007
Verify Error: 002007: read 003FFF, wanted 003FF1
ERROR: Programming FAILED !
Cannot verify at different voltages with this hardware.
Is er iemand die Mij kan helpen ?
Ook geeft ie weleen dit aan:
Programming...
Programming CODE, 0x000000..0x00006C
Verify Error: 000000: read 003FFF, wanted 003007
Verify Error: 000001: read 003FFF, wanted 00009F
Verify Error: 000002: read 003FFF, wanted 001683
Verify Error: 000003: read 003FFF, wanted 003000
Verify Error: 000004: read 003FFF, wanted 000086
Verify Error: 000005: read 003FFF, wanted 001283
Verify Error: 000006: read 003FFF, wanted 0001A0
Verify Error: 000007: read 003FFF, wanted 002026
Verify Error: 000008: read 003FFF, wanted 002029
Verify Error: 000009: read 003FFF, wanted 001805
Verify Error: 00000A: read 003FFF, wanted 002020
Verify Error: 00000B: read 003FFF, wanted 002026
Verify Error: 00000C: read 003FFF, wanted 002030
Verify Error: 00000D: read 003FFF, wanted 001805
Verify Error: 00000E: read 003FFF, wanted 002020
Verify Error: 00000F: read 003FFF, wanted 002026
Verify Error: 000010: read 003FFF, wanted 002037
En als je zeker wilt weten dat je een werkende programmer bouwt, bouw (of koop) dan een WISP of een PPWIN (heb zelf de laatste, werkt super)
Fripster
Hij heeft alle spanningen wel en tijdens het programmeren worden pen 17,13 en 11 ook wel even 5 V maar verder gebeurt er niks. Ik heb de print helemaal gecontroleerd.
Switching Power
Hobby, maar sample met mate. | BumbleBee plus pack | Weerstand calculator voor je PSP
je had het zonet over 5 volt. staat er nou 5 of 9 volt op VDD en wat is de spanning Vpp? (staat op MCLR pin) Deze moet 13V zijn.
Fripster
Met die 5 V is het programmeer spanningkje op pen 17,13 en 11 staat. Zonder PIC in schakeling is deze spanning 6,8 V zeg maar 7 V.
Klopt het dat op pin 12 en 16 een spanning 11,2 V staat.
DE spanning op Mclr pin 4 is 8,2 V.
DE spanning op de vss (pin 5) is nu 5,8 V maar het ook al eens 6,2 V en op zijn hoogtepunt was ie zelfs 10 V. Nou had ik gehoord dat de spanning op de poort weleens instabiel kan zijn klopt dat ?
