Ik heb zo'n lcd (Powertip PG320240D), maar ik krijg hem niet goed aan de gang
Heeft iemand met zo'n (soortgelijk) lcd gewerkt.
Ik wil hem aansturen met CCS-C
Dit is de source code:
#ifndef S1D13305
#define S1D13305
#ifndef GLCD_WIDTH
#define GLCD_WIDTH 320
#endif
#ifndef GLCD_HEIGHT
#define GLCD_HEIGHT 240
#endif
#ifndef GLCD_CHAR_WIDTH
#define GLCD_CHAR_WIDTH 8
#endif
#ifndef GLCD_CHAR_HEIGHT
#define GLCD_CHAR_HEIGHT 8
#endif
#ifndef GLCD_RST
#define GLCD_RST PIN_D4
#endif
#ifndef GLCD_RD
#define GLCD_RD PIN_D0
#endif
#ifndef GLCD_WR
#define GLCD_WR PIN_D1
#endif
#ifndef GLCD_CS
#define GLCD_CS PIN_D3
#endif
#ifndef GLCD_A0
#define GLCD_A0 PIN_D2
#endif
#ifndef ON
#define ON 1
#endif
#ifndef OFF
#define OFF 0
#endif
// The following defines setup the memory used by different regions
// Currenty one text area is defined at the beginning of memory
// and a graphics area follows immediately after
#define GLCD_TEXT_ADDR 0x0000
#define GLCD_GRAPHICS_ADDR GLCD_WIDTH*GLCD_HEIGHT/64
#define GLCD_GRAPHICS_ADDR_END GLCD_GRAPHICS_ADDR+(GLCD_WIDTH*GLCD_HEIGHT/8)
#if GLCD_CHAR_WIDTH<9
#define GLCD_CR (GLCD_WIDTH/8-1)
#else
#define GLCD_CR (GLCD_WIDTH/4-2)
#endif
#define TGLCD_COMMAND output_high(GLCD_A0);
#define TGLCD_DATA output_low(GLCD_A0);
int8 glcd_readByte();
void glcd_sendByte(int8 data);
void glcd_fillScreen(int1 color);
void glcd_fillScreenText(char c);
void setCursorAddress(int16 addr);
void glcd_pixel(int16 x,int16 y,int1 color);
int8 getData(int16 addr);
void glcd_sendCMD(int8 cmd);
void glcd_systemSetup();
void glcd_scrollSetup();
void glcd_overlaySetup();
void glcd_power(int1 mode);
void glcd_cursorDirection(int8 dir);
void glcd_cursorForm(int8 width,int8 height);
void setData(int16 addr,int8 data);
#define GLCD_CMD_SYSTEM 0x40 // General system settings
#define GLCD_CMD_SLEEP 0x53 // Enter into standy mode
#define GLCD_CMD_DISP_OFF 0x58 // Turn the display off
#define GLCD_CMD_DISP_ON 0x59 // Turn the display on
#define GLCD_CMD_SCROLL 0x44 // Setup text and graphics address regions
#define GLCD_CMD_CSR_FORM 0x5D // Set cursor size
#define GLCD_CMD_CGRAM_ADDR 0x5C // Configure character generator RAM address
#define GLCD_CMD_CSRDIR_RIGHT 0x4C // Cursor moves right after write to display memory
#define GLCD_CMD_CSRDIR_LEFT 0x4D // Cursor moves left after write to display memory
#define GLCD_CMD_CSRDIR_UP 0x4E // Cursor moves up after write to display memory
#define GLCD_CMD_CSRDIR_DN 0x4F // Cursor moves down after write to display memory
#define GLCD_CMD_HDOT_SCR 0x5A // Set horizontal scroll rate
#define GLCD_CMD_OVERLAY 0x5B // Configure how layers overlay
#define GLCD_CMD_SET_CSR_ADDR 0x46 // Set the cursor address
#define GLCD_CMD_GET_CSR_ADDR 0x47 // Read the cursor address
#define GLCD_CMD_DISPLAY_WRITE 0x42 // Write to display memory
#define GLCD_CMD_DISPLAY_READ 0x43 // Read from display memory
// Purpose: Initialize the controller
// Inputs: The initialization mode
// OFF - Turns the LCD off
// ON - Turns the LCD on
void glcd_init(int1 mode) {
output_high(GLCD_RST);
output_high(GLCD_CS);
output_high(GLCD_RD);
output_high(GLCD_WR);
glcd_systemSetup();
glcd_scrollSetup();
glcd_power(OFF);
glcd_cursorForm(4,6);
glcd_fillScreen(OFF);
glcd_fillScreenText(' ');
glcd_power(mode);
glcd_cursorDirection(GLCD_CMD_CSRDIR_RIGHT);
// Purpose: Turn a pixel on a graphic LCD on or off
// Inputs: x - the x coordinate of the pixel
// y - the y coordinate of the pixel
// color - ON or OFF
void glcd_pixel(int16 x,int16 y,int1 color) {
int8 data;
int16 addr;
addr=GLCD_GRAPHICS_ADDR+(GLCD_WIDTH/8*y+x/8);
data=getData(addr);
if(color==ON)
bit_set(data,7-x%8);
else
bit_clear(data,7-x%8);
setData(addr,data);
// Purpose: Initialize the display environment
void glcd_systemSetup() {
glcd_sendCMD(GLCD_CMD_SYSTEM); // Setup the system
TGLCD_DATA // Set for data
glcd_sendByte(0x30); // No offset
glcd_sendByte(0x7F+GLCD_CHAR_WIDTH); // Set character width
glcd_sendByte(GLCD_CHAR_HEIGHT-1); // Set character height
glcd_sendByte(GLCD_CR); // Display line address range
glcd_sendByte(0x2F); // TC/R
glcd_sendByte(GLCD_HEIGHT-1); // Number of lines per frame
glcd_sendByte(GLCD_CR+1); // Horizontal address range LSB (APL)
glcd_sendByte((GLCD_CR+1)/0xFF); // Horizontal address range MSB (APH)
// Purpose: Set the scroll start address and
// the size of a scroll block
void glcd_scrollSetup() {
glcd_sendCMD(GLCD_CMD_SCROLL); // Setup scrolling
glcd_sendByte(GLCD_TEXT_ADDR); // SAD1L
glcd_sendByte(GLCD_TEXT_ADDR/0xFF); // SAD1H
glcd_sendByte(GLCD_HEIGHT-1); // SL1
glcd_sendByte(GLCD_GRAPHICS_ADDR); // SAD2L
glcd_sendByte(GLCD_GRAPHICS_ADDR/0xFF); // SAD2H
glcd_sendByte(GLCD_HEIGHT-1); // SL2
glcd_sendByte(0x00); // SAD3L
glcd_sendByte(0x00); // SAD3H
glcd_sendByte(0x00); // SAD4L
glcd_sendByte(0x00); // SAD4H
glcd_sendCMD(GLCD_CMD_HDOT_SCR); // Horizontal scroll rate
glcd_sendByte(0x00); // Horizontal pixel shift is 0
// Purpose: Setup the overlay functionality for combining
// layers of text and graphics, or multiple
// graphics layers
void glcd_overlaySetup() {
glcd_sendCMD(GLCD_CMD_OVERLAY); // Text/graphic overlay mode
glcd_sendByte(0x09); // Area 1 text, others graphics
// Text XOR Graphics
// Purpose: Turn the display on or off
// Inputs: ON to turn on or OFF to turn off
void glcd_power(int1 mode) {
if(mode==ON) {
glcd_sendCMD(GLCD_CMD_DISP_ON);
else {
glcd_sendCMD(GLCD_CMD_DISP_OFF);
TGLCD_DATA
glcd_sendByte(0x14);
// Purpose: Set the direction the cursor moves after
// writing to dispaly memory
// Inputs: Use one of the following to set the direction:
// GLCD_CMD_CSRDIR_RIGHT
// GLCD_CMD_CSRDIR_LEFT
// GLCD_CMD_CSRDIR_UP
// GLCD_CMD_CSRDIR_DOWN
void glcd_cursorDirection(int8 dir) {
glcd_sendCMD(dir);
// Purpose: Set the size of the cursor
// Inputs: 1) The width in pixels - 1 Valid numbers: (0 - 15)
// 2) The height in pixels - 1 Valid numbers: (1 - 15)
void glcd_cursorForm(int8 width,int8 height) {
glcd_sendCMD(GLCD_CMD_CSR_FORM);
TGLCD_DATA
glcd_sendByte(width);
glcd_sendByte(0x80+height);
// Purpose: Fill a graphics layer passed in color
// Works much faster than drawing a rectangle to fill the screen
// Inputs: ON - turn all the pixels on
// OFF - turn all the pixels off
void glcd_fillScreen(int1 color) {
int16 i;
setCursorAddress(GLCD_GRAPHICS_ADDR);
glcd_sendCMD(GLCD_CMD_DISPLAY_WRITE);
TGLCD_DATA
for(i=GLCD_GRAPHICS_ADDR;i<GLCD_GRAPHICS_ADDR_END;++i) {
glcd_sendByte(0xFF*color);
// Purpose: Fill a text layer with a the passed in character
void glcd_fillScreenText(char c) {
int16 i;
setCursorAddress(GLCD_TEXT_ADDR);
TGLCD_DATA
for(i=GLCD_TEXT_ADDR;i<GLCD_GRAPHICS_ADDR;++i) {
glcd_sendByte(c);
// Purpose: Write a byte of data
// Inputs: The byte of data to write
void glcd_sendByte(byte data) {
output_c((data));
output_low(GLCD_CS);
delay_cycles(1);
output_low(GLCD_WR);
delay_cycles(2);
// Purpose: Read a byte of data
// Outputs: The byte of data
int8 glcd_readByte() {
int8 data;
set_tris_c(0xFF);
delay_cycles(1);
output_low(GLCD_RD);
delay_cycles(2);
data=input_c();
return data;
// Purpose: Get the status
// Outputs: The status in an 8 bit integer
int8 getStatus() {
int8 status;
TGLCD_DATA
set_tris_c(0xFF);
delay_us(1);
status=input_c();
return status;
// Purpose: Get the current address of the cursor
// Outputs: A 16 bit integer containing the cursor address
int16 getCursorAddress() {
int16 addr;
glcd_sendCMD(GLCD_CMD_GET_CSR_ADDR);
TGLCD_DATA
*(int8*)(&addr)=glcd_readByte();
*(int8*)(&addr+1)=glcd_readByte();
return addr;
// Purpose: Set the cursor address
// Inputs: A 16 bit integer containing the new cursor address
void setCursorAddress(int16 addr) {
glcd_sendCMD(GLCD_CMD_SET_CSR_ADDR);
TGLCD_DATA
glcd_sendByte(*(int8*)(&addr));
glcd_sendByte(*(int8*)(&addr+1));
// Purpose: Get a byte of data from the display at the address
// Inputs: A 16 bit integer containing the address
// Outputs: An 8 bit integer with the read data
int8 getData(int16 addr) {
setCursorAddress(addr);
glcd_sendCMD(GLCD_CMD_DISPLAY_READ);
TGLCD_DATA
return glcd_readByte();
// Purpose: Set a byte of display data at an address
// Inputs: 1) A 16 bit address
// 2) 8 bits worth
void setData(int16 addr, int8 data) {
TGLCD_DATA
glcd_sendByte(data);
// Purpose: Send an 8 bit command
// Inputs: The command to send
void glcd_sendCMD(int8 cmd) {
TGLCD_COMMAND
glcd_sendByte(cmd);
#endif
#include <18F4620.h>
#use delay(clock=20000000)
#fuses HS,NOWDT,NOBROWNOUT,NOPUT,NOLVP,DEBUG,NOSTVREN,NOPROTECT
#include <s1d13305.h>
#include <graphics.h>
void main() {
glcd_init(ON);
while(true) {
glcd_fillScreenText('A');
delay_ms(4000);
glcd_fillScreenText('B');
delay_ms(4000);
Dit zou eerst het hele scherm met een 'A' moeten zetten en daarna met een 'B'
Maar ik krijg alleen maar willekeurige pixel op het lcd
Wie kan helpen?
