Hoi
Ik heb een programma van internet, voor de arduino hier lees ik sensor ds18b20 uit
en geef waarde weer via com poort.
Het programma geeft nu twee cijfers achter de comma. 24,18
hoe kan ik dit aanpassen dat dit maar een cijfer wordt
en dit afrond 24.18 moet 24.2 worden.
Hier de code
// DS18B20_1 - Arduino
#define TEMP_PIN 3
void OneWireReset(int Pin);
void OneWireOutByte(int Pin, byte d);
byte OneWireInByte(int Pin);
void setup()
digitalWrite(TEMP_PIN, LOW);
pinMode(TEMP_PIN, INPUT); // sets the digital pin as input (logic 1)
Serial.begin(9600);
delay(100);
Serial.print("temperature measurement:\n");
void loop()
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
OneWireReset(TEMP_PIN);
OneWireOutByte(TEMP_PIN, 0xcc);
OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
OneWireOutByte(TEMP_PIN, 0xbe);
LowByte = OneWireInByte(TEMP_PIN);
HighByte = OneWireInByte(TEMP_PIN);
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print("\n");
delay(5000); // 5 second delay. Adjust as necessary
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse
digitalWrite(Pin, LOW);
pinMode(Pin, OUTPUT); // bring low for 500 us
delayMicroseconds(500);
pinMode(Pin, INPUT);
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
byte n;
for(n=8; n!=0; n--)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds(5);
delayMicroseconds(60);
else
d=d>>1; // now the next bit is in the least sig bit position.
byte OneWireInByte(int Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead(Pin);
delayMicroseconds(50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return(d);
Groetjes Lowa1
