Bavelt
Fouten zijn het bewijs dat je het probeert..
Ik ben nu aan het testen met een 1,3"Oled display, 240 * 240 met SPI interface (IC: ST7789).
Ik heb geprobeerd om het programma van Arco om te te zetten naar een PIC16F887, maar lukt niet echt:
e MikroBasic code om te testen (past nog in de demo versie van de dsPic compiler):
pic basic code:
' Project name: Test_Oled              - CONFIG1 : 0x3F7F
' MCU:          PIC24FJ256GA106        - CONFIG2 : 0x92BE
' Oscillator:   HS, 8.0000 MHz         - CONFIG3 : 0xFFFF
program Test_Oled
Dim SSel         As sBit At LATD.9                              'Display select
    D_C          As sBit At LATF.5                              'Data/Command
const Char6x8 As Byte[570] = (       'Character table
0x00, 0x00, 0x00, 0x00, 0x00, 0x00,  ' sp
0x00, 0x00, 0x00, 0x2f, 0x00, 0x00,  ' !
0x00, 0x00, 0x07, 0x00, 0x07, 0x00,  ' "
0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14,  ' #
0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12,  ' $
0x00, 0x62, 0x64, 0x08, 0x13, 0x23,  ' %
0x00, 0x36, 0x49, 0x55, 0x22, 0x50,  ' &
0x00, 0x00, 0x05, 0x03, 0x00, 0x00,  ' '
0x00, 0x00, 0x1c, 0x22, 0x41, 0x00,  ' (
0x00, 0x00, 0x41, 0x22, 0x1c, 0x00,  ' )
0x00, 0x14, 0x08, 0x3E, 0x08, 0x14,  ' *
0x00, 0x08, 0x08, 0x3E, 0x08, 0x08,  ' +
0x00, 0x00, 0x00, 0xA0, 0x60, 0x00,  ' ,
0x00, 0x08, 0x08, 0x08, 0x08, 0x08,  ' -
0x00, 0x00, 0x60, 0x60, 0x00, 0x00,  ' .
0x00, 0x20, 0x10, 0x08, 0x04, 0x02,  ' /
0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E,  ' 0
0x00, 0x00, 0x42, 0x7F, 0x40, 0x00,  ' 1
0x00, 0x42, 0x61, 0x51, 0x49, 0x46,  ' 2
0x00, 0x21, 0x41, 0x45, 0x4B, 0x31,  ' 3
0x00, 0x18, 0x14, 0x12, 0x7F, 0x10,  ' 4
0x00, 0x27, 0x45, 0x45, 0x45, 0x39,  ' 5
0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30,  ' 6
0x00, 0x01, 0x71, 0x09, 0x05, 0x03,  ' 7
0x00, 0x36, 0x49, 0x49, 0x49, 0x36,  ' 8
0x00, 0x06, 0x49, 0x49, 0x29, 0x1E,  ' 9
0x00, 0x00, 0x36, 0x36, 0x00, 0x00,  ' :
0x00, 0x00, 0x56, 0x36, 0x00, 0x00,  ' ;
0x00, 0x08, 0x14, 0x22, 0x41, 0x00,  ' <
0x00, 0x14, 0x14, 0x14, 0x14, 0x14,  ' =
0x00, 0x00, 0x41, 0x22, 0x14, 0x08,  ' >
0x00, 0x02, 0x01, 0x51, 0x09, 0x06,  ' ?
0x00, 0x32, 0x49, 0x59, 0x51, 0x3E,  ' @
0x00, 0x7C, 0x12, 0x11, 0x12, 0x7C,  ' A
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,  ' B
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,  ' C
0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C,  ' D
0x00, 0x7F, 0x49, 0x49, 0x49, 0x41,  ' E
0x00, 0x7F, 0x09, 0x09, 0x09, 0x01,  ' F
0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A,  ' G
0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F,  ' H
0x00, 0x00, 0x41, 0x7F, 0x41, 0x00,  ' I
0x00, 0x20, 0x40, 0x41, 0x3F, 0x01,  ' J
0x00, 0x7F, 0x08, 0x14, 0x22, 0x41,  ' K
0x00, 0x7F, 0x40, 0x40, 0x40, 0x40,  ' L
0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F,  ' M
0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F,  ' N
0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E,  ' O
0x00, 0x7F, 0x09, 0x09, 0x09, 0x06,  ' P
0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E,  ' Q
0x00, 0x7F, 0x09, 0x19, 0x29, 0x46,  ' R
0x00, 0x46, 0x49, 0x49, 0x49, 0x31,  ' S
0x00, 0x01, 0x01, 0x7F, 0x01, 0x01,  ' T
0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F,  ' U
0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F,  ' V
0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F,  ' W
0x00, 0x63, 0x14, 0x08, 0x14, 0x63,  ' X
0x00, 0x07, 0x08, 0x70, 0x08, 0x07,  ' Y
0x00, 0x61, 0x51, 0x49, 0x45, 0x43,  ' Z
0x00, 0x00, 0x7F, 0x41, 0x41, 0x00,  ' [
0x00, 0x55, 0x2A, 0x55, 0x2A, 0x55,  ' \
0x00, 0x00, 0x41, 0x41, 0x7F, 0x00,  ' ]
0x00, 0x04, 0x02, 0x01, 0x02, 0x04,  ' ^
0x00, 0x40, 0x40, 0x40, 0x40, 0x40,  ' _
0x00, 0x00, 0x01, 0x02, 0x04, 0x00,  ' '
0x00, 0x20, 0x54, 0x54, 0x54, 0x78,  ' a
0x00, 0x7F, 0x48, 0x44, 0x44, 0x38,  ' b
0x00, 0x38, 0x44, 0x44, 0x44, 0x20,  ' c
0x00, 0x38, 0x44, 0x44, 0x48, 0x7F,  ' d
0x00, 0x38, 0x54, 0x54, 0x54, 0x18,  ' e
0x00, 0x08, 0x7E, 0x09, 0x01, 0x02,  ' f
0x00, 0x18, 0xA4, 0xA4, 0xA4, 0x7C,  ' g
0x00, 0x7F, 0x08, 0x04, 0x04, 0x78,  ' h
0x00, 0x00, 0x44, 0x7D, 0x40, 0x00,  ' i
0x00, 0x40, 0x80, 0x84, 0x7D, 0x00,  ' j
0x00, 0x7F, 0x10, 0x28, 0x44, 0x00,  ' k
0x00, 0x00, 0x41, 0x7F, 0x40, 0x00,  ' l
0x00, 0x7C, 0x04, 0x18, 0x04, 0x78,  ' m
0x00, 0x7C, 0x08, 0x04, 0x04, 0x78,  ' n
0x00, 0x38, 0x44, 0x44, 0x44, 0x38,  ' o
0x00, 0xFC, 0x24, 0x24, 0x24, 0x18,  ' p
0x00, 0x18, 0x24, 0x24, 0x18, 0xFC,  ' q
0x00, 0x7C, 0x08, 0x04, 0x04, 0x08,  ' r
0x00, 0x48, 0x54, 0x54, 0x54, 0x20,  ' s
0x00, 0x04, 0x3F, 0x44, 0x40, 0x20,  ' t
0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C,  ' u
0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C,  ' v
0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C,  ' w
0x00, 0x44, 0x28, 0x10, 0x28, 0x44,  ' x
0x00, 0x1C, 0xA0, 0xA0, 0xA0, 0x7C,  ' y
0x00, 0x44, 0x64, 0x54, 0x4C, 0x44,  ' z
0x00, 0x10, 0x6C, 0x82, 0x00, 0x00,  ' {
0x00, 0x00, 0x00, 0xFE, 0x00, 0x00,  ' |
0x00, 0x00, 0x00, 0x82, 0x6C, 0x10,  ' }
0x14, 0x14, 0x14, 0x14, 0x14, 0x14)  ' horiz lines
Sub Procedure Init_App()                                        'Initialize pillbox
  Dim lRet As Byte
  delay_ms(100)
  TRISD         = %0000000000001011                             '
  TRISF         = %0000000000000000                             '
  LATD          = %0000001000000010                             '
  LATF          = %0000000000000000                             '
  Unlock_IOLock()
  PPS_Mapping_NoLock( 3,_OUTPUT,_SDO1)                          'RP3  (= LATD.10 pin)
  PPS_Mapping_NoLock(12,_OUTPUT,_SCK1OUT)                       'RP12 (= LATD.11 pin)
  Lock_IOLock()
  Spi1_Init_Advanced(_SPI_MASTER,
                     _SPI_8_BIT,
                     _SPI_PRESCALE_SEC_1,
                     _SPI_PRESCALE_PRI_16,
                     _SPI_SS_DISABLE,
                     _SPI_DATA_SAMPLE_MIDDLE,
                     _SPI_CLK_IDLE_HIGH,
                     _SPI_IDLE_2_ACTIVE)
  Delay_ms(100)
End Sub
Sub Procedure Lcd_WrCmd(Dim pCmd As Byte)                       'Write command to display
  D_C = 0
  Spi1_Write(pCmd)
End Sub
Sub Procedure Lcd_WrDat(Dim pDat As Byte)                       'Write data to display
  Dim lCnt As Byte
  D_C = 1
  Spi1_Write(pDat)
End Sub
Sub Procedure Lcd_SetPos(Dim px, py as Byte)                    'Set write position on display
  delay_us(1)
  Lcd_WrCmd(0xB0 + py)
  Lcd_WrCmd((px  >> 4) Or 0x10)
  Lcd_WrCmd((px And 0x0F))
  delay_us(1)
End Sub
Sub Procedure LCD_Fill(Dim pFill As Byte)                       'Fill display with character pFill
  Dim lx, ly As Byte
  For ly = 0 To 8
    Lcd_WrCmd(0xB0+ly)
    Lcd_WrCmd(0x01)
    Lcd_WrCmd(0x10)
    For lx = 0 to 131
      Lcd_WrDat(pFill)
    Next lx
  Next ly
End Sub
Sub Procedure Lcd_Char_6x8(Dim px, py, pchar As Byte)           'Write one character
  Dim lIndex As Word
  Lcd_SetPos(px, py)
  lIndex = pChar - 0x20
  lIndex = (lIndex << 2) + (lIndex << 1)
  Lcd_WrDat(Char6x8[lIndex+0])
  Lcd_WrDat(Char6x8[lIndex+1])
  Lcd_WrDat(Char6x8[lIndex+2])
  Lcd_WrDat(Char6x8[lIndex+3])
  Lcd_WrDat(Char6x8[lIndex+4])
  Lcd_WrDat(Char6x8[lIndex+5])
End Sub
Sub Procedure Lcd_String_6x8(Dim px, py As Byte, Dim ByRef pDisp As String) ' Write string
  Dim lLen, lCnt As Byte
  lLen = Length(pDisp)
  For lCnt = 0 To (lLen-1)
    If px >= 124 Then px = 0 py = py+1 End If
    Lcd_Char_6x8(px, py, pDisp[lCnt])
    px = px + 6
  Next lCnt
End Sub
Main:                                                           'Main program
    SSel = 0
    delay_ms(500)
    SSEL = 1                     'Only for 0.96", for 1.3" remove it
    delay_ms(500)
    Lcd_WrCmd(0xAE)              'Turn OLED panel off
    Lcd_WrCmd(0xA8)              'Multiplex ratio set to
    Lcd_WrCmd(0x3F)              '63
    Lcd_WrCmd(0xD3)              'Display offset RAM counter
    Lcd_WrCmd(0x00)              'none
    Lcd_WrCmd(0x40)              'Start line address
    Lcd_WrCmd(0xA1)              'Set segment remap rotation to left
    Lcd_WrCmd(0xC8)              'Common output scan direction
    Lcd_WrCmd(0xDA)              'Common signals pad
    Lcd_WrCmd(0x12)              'value
    Lcd_WrCmd(0x81)              'Contrast control
    Lcd_WrCmd(0xFF)              'value
    Lcd_WrCmd(0xA4)
    Lcd_WrCmd(0xA6)              'Normal display
    Lcd_WrCmd(0xD5)              'Clock ratio:oscillator frequency
    Lcd_WrCmd(0x80)              'oooo:rrrr
    Lcd_WrCmd(0x8D)
    Lcd_WrCmd(0x14)
    Lcd_WrCmd(0x00)              'Set lower column address
    Lcd_WrCmd(0x10)              'Set higher column address
    Lcd_WrCmd(0xD9)              '15 clocks, discharge 1 clock
    Lcd_WrCmd(0xF1)              'dddd:pppp
    Lcd_WrCmd(0xDB)              'Common output voltage
    Lcd_WrCmd(0x40)              'level
    Lcd_WrCmd(0x20)              'Addressing mode
    Lcd_WrCmd(0x02)              'value
'    Lcd_WrCmd(0xA7)
    Lcd_Fill(0x00)
    Lcd_SetPos(0,0)
    Lcd_String_6x8(0,0,"Dit is een test van")
    Lcd_String_6x8(0,1,"een 128x64 pixel gra-")
    Lcd_String_6x8(0,2,"fisch OLED display.")
    Lcd_String_6x8(0,3,"Met 't 6x8 pixel font")
    Lcd_String_6x8(0,4,"gaat er heel wat in-")
    Lcd_String_6x8(0,5,"formatie op zo'n mini")
    Lcd_String_6x8(0,6,"scherm van 1.1x2.2cm")
    Lcd_String_6x8(0,7,"(en toch nog scherp!)")
    Lcd_WrCmd(0xAF)    'Turn OLED panel on
    delay_ms(500)
    SSel = 1
    While True
    Wend
End.
Deze routines
 Unlock_IOLock()
  Lock_IOLock()
                     _SPI_8_BIT,
                     _SPI_SS_DISABLE,
                     _SPI_CLK_IDLE_HIGH,
                     _SPI_IDLE_2_ACTIVE)
lopen sowieso al niet (kunnen ws dus niet bij de 887).
Ik heb de poorten aangepast, maar zonder resultaat (display doet niks)
Zou gewoon moeten werken. (als die ST7789 tenminste gelijk is aan de SSD1306)
Alleen de poorten en de SPI init aanpassen.
  Spi1_Init_Advanced(_SPI_MASTER_OSC_DIV4,
                     _SPI_CLK_IDLE_HIGH,
                     _SPI_HIGH_2_LOW)
De lock/unlock sectie moet weg, de 887 heeft geen PPS...
De ST7789 zie ik net is een compleet andere chip dus dat gaat zeker niet werken...
(is voor een color-TFT, niet voor een OLED)
Bavelt
Is inderdaad een color-led. Wilde ik ook eens mee stoeien.
Er zijn wel voorbeelden te vinden, maar ja, dan kom je uit Op Arduino of C...
Terwijl ik net zo lekker bezig ben met MikroBasic.
Voor een TFT moet minimaal 4x zoveel data verstuurd worden. (data, en RGB informatie voor elke pixel)
Bavelt
Ik ben al blij als ik het in zwart wit aan de praat krijg...
KGE
Misschien kun je hier de initialisatieparameters uit halen:
https://github.com/adafruit/Adafruit-ST7735-Library/blob/master/Adafruit_ST7789.cpp
En het is dus geen OLED scherm maar een TFT met LED backlight, het werkt alleen maar op 3,3 Volt, op 5 Volt gaat de boel stuk...
Kleur of zwart/wit maakt voor de data die naar het scherm moet niet uit, dat blijft RGB, in dit geval 16 bit per pixel.
Dat MikroBasic ziet er al erg 'C' achtig uit dus de overstap naar Arduino is niet zo moeilijk denk ik. Is ook de programma grootte geen probleem meer.
Bavelt
Ok, Ik parkeer het TFT schermpje even. Daar ben ik dan nog niet aan toe vrees ik.
Dan even terug naar een 'echte' OLED, nu een 1,3 Inch met I2C protocol.
Daar gebeurt ook iets waar ik de vinger nog niet achter krijg.
Ik toon een byte, die steeds met 1 wordt opgehoogd. Op het scherm moet je dan de pixels 'binair' zien tellen. Dat gebeurt ook.
Maar het vreemde is, dat de eerste 'write' niet wordt getoond. En verder zie ik dat naast de binaire waarde op rij 8 ook steeds een pixel wordt getoond, maar dan op een positie tussen de getoonde andere.
Hier gebeurt dus iets vreemds of ik doe iets fout.
program Oled_I2C_013
Dim i1 as byte
Sub Procedure Lcd_WrCmd(Dim pCmd As Byte)                       'Write data to display
  while Not (i2c1_Is_Idle) wend
  i2c1_Start()
  i2c1_Wr(0x78)
  i2c1_Wr(0x80)
  i2c1_Wr(pCmd)
  i2c1_Stop()
End Sub
  i2c1_Start()
  i2c1_Wr(0x78)
  i2c1_Wr(0x40)
  i2c1_Wr(pDat)
  Delay_ms(1)
  i2c1_Stop()
End Sub
  Lcd_WrCmd(px And 0x0F)
End Sub
  Dim lx, ly As Byte
  For ly = 0 To 8
  LCD_wrCmd(0xB0 + ly)
  LCD_wrCmd(0x01)
  LCD_wrCmd(0x10)
    For lx = 0 to 131
      Lcd_wrDat(pFill)
    Next lx
  Next ly
End Sub
Sub Procedure Display_Init()
  Lcd_WrCmd(0x3F)                                 '63
  Lcd_WrCmd(0xA4)
  Lcd_WrCmd(0x8D)
  Lcd_WrCmd(0x14)
End Sub
main:
  TRISC = %00000000
  Delay_ms(50)
  i2c1_init(100000)                              'Init i2c port 100kHz
  Display_Init()
  LCD_wrCmd(0xAF)                                'Turn Oled Panel on
 LCD_Fill(0x00)
 LCD_Setpos(0,0)
  i2c1_Start()
  i2c1_Wr(0x78)
  for i1 = 1 to 32
    i2c1_Wr(0x40)
    i2c1_Wr(i1)
    Delay_ms(1000)
  next i1
  i2c1_Stop()
 While True Wend
end.
Bavelt
zie foto (krijg hem niet goed scherp op kleine afstand)
[Bericht gewijzigd door Bavelt op maandag 23 december 2019 12:50:11 (51%)]
Die pixel steek je zelf aan met I2C1_Wr(0x40)... ;)
Lcd_WrDat() is wat netter, dan houd je ook niet de i2c bus voor een halve minuut open...
  for i1 = 1 to 32
    Lcd_WrDat(i1)
    LCD_WrDat(0x00)   'Als je er een spatie tussen wilt
    Delay_ms(1000)
  next i1
[Bericht gewijzigd door Arco op maandag 23 december 2019 13:09:09 (11%)]
Bavelt
Ik zie het. Die 0x40 is de Control Byte, die aangeeft dat de volgende byte data is.
Ik had hem als data weggestuurd en inderdaad, stak ik de pixel aan.. 8)7
Blijft alleen waarom de allereerste write geen resultaat geeft. Heeft dat wellicht te maken met de startpositie?
Die wordt toch bepaald door
 LCD_Setpos(0,0)
De allereerste 0x40 na het startadres wordt als commando ontvangen. ("hierna komt data")
De volgende keer dat 0x40 wordt ontvangen wordt dat netjes als data behandeld en naar het display geschreven...
Daarom wordt de eerste 0x40 niet naar het display geschreven en alle volgende wel...
Bavelt
vergeef me.. ;(, maar ik vat het nog even niet.
 for i1 = 1 to 32
    Lcd_WrDat(i1)
    Delay_ms(1000)
  next i1
Eerst wordt 0x78 weggeschreven (Slave Adress)
Dan komt 0x40 (volgende byte is data)
Dan komt de eerste data %00000001 (i1 gaat van 1 tot 32).
maar deze toont hij dus niet.
Het kan zijn dat de display kolommen bij '1' beginnen te tellen.
Ligt aan de displaymaker, van die kleine OLED display-tjes is bar weinig bekend op de prijs na... ;)
Bavelt
Dat zou heel goed kunnen, want bij de 0,96"versie toont hij wél de eerste.
Die dingen kosten inderdaad heel erg weinig. Hoe kunnen ze het er voor maken...
Maar wel reuze handig als je een schakeling hebt waarbij je wat zichtbaar wilt hebben.
Je kan ze op een printje kwijt en van alles en nog wat tonen.
Als je het hele scherm wit maakt, kun je wel zien dat ze bar slecht zijn eigenlijk... ;)
(als je met een vergrootglas kijkt zie je al gauw 50...100 beschadigde pixels. Vooral aan de randen vaak 'gerafelde' pixels)
https://www.circuitsonline.net/forum/file/3874
[Bericht gewijzigd door Arco op maandag 23 december 2019 15:29:30 (12%)]
Bavelt
om de eerste pixel te tonen moet je hiermee beginnen:
LCD_Setpos(2,0)
Met 2 horizontaal dus.
Bavelt
Nou, dat valt hier eigenlijk reuze mee. Ik heb hem ook onder het vergrootglas gelegd en zie niet echt kapotte pixels.
(En dan is er ook nog een bureaulamp op gevallen... ;()
Ik kan er geen goede foto van maken; er lopen dan balken door het beeld en krijg geen focus.
Dan heb je geluk gehad (of de fabrikant heeft zijn leven gebeterd... ;) ).
Ik had ze van verschillende leveranciers, allemaal min of meer beschadigd...
(heb 1 keer gereclameerd, kreeg toen een vervanger die net zo rot was, dus dat was ook geen oplossing...)
Bavelt
Tja,
Deze was $3,63 bij 'tante Alie'.
Bavelt
Maar hij doet het leuk. Verschillende fonten..
Bavelt
Ik ben nog weer even aan het stoeien met een OLED display, 128 * 64
In het programma heb ik :
  Dim lx, ly As Byte
  For ly = 0 To 7
  LCD_wrCmd(0x01)
  LCD_wrCmd(0x10)
    For lx = 0 to 127
      Lcd_wrDat(pFill)
    Next lx
  Next ly
End Sub
Waar ik even mee zit: het commando
 LCD_wrCmd(0x01)
Dit veroorzaakt op de eerste kolom (segment0) op een aantal rijen (niet allemaal) op kolom 1 oplichtende pixels.
Daardoor krijg je een 'sliertje' in beeld.
Als ik het commando weglaat, gaat het goed.
Ik snap niet goed wat de bedoeling van dit commando was.
Daarnaast: uit de sheet haal ik dat er 8 Blokken (Pages) zijn en 128 Segmenten (kolommen).
Dan is ly 0 to 7 en lx 0 to 127 toch goed voor deze display?
(er stond nl 0 to 8 en 0 to 131).
Bavelt
Ik heb inmiddels een "Gewone" SPI-OLed (dus geen TFT).
Met een SSD1306 chip.
Het dingetje heeft de volgende pinnen:
Ik ben er al achter dat D0 = SCK, D1 = SDO.
Ik maak gebruik van de uc PIC16F1847, deze heeft een SPI aan boord.
(SDO op LATB.2, SCK op LATB.4)
Voor D/C heb ik LATB.0 gekozen en CS LATB.1
Wat ik met de RES moet weet ik niet precies.
Maar het displaytje doet niks. Ik doe ongetwijfeld iets fout...
Het programma:
Dim SSel         As sBit At LATB.1                              'Display select
    D_C          As sBit At LATB.0                              'Data/Command
  Dim lRet As Byte
  Delay_ms(100)
  ANSELB = 0                                                     'All Port B digital
  TRISB  = %11110100                                             'PortB.0, PortB.1  and B.3 Output
  OSCCON = %01111000                                             '16Mhz internal
                     _SPI_CLK_IDLE_HIGH,
                     _SPI_HIGH_2_LOW)
  Delay_ms(100)
End Sub
  D_C = 0
  Spi1_Write(pCmd)
End Sub
  Dim lCnt As Byte
  D_C = 1
  Spi1_Write(pDat)
End Sub
  delay_us(1)
  delay_us(1)
End Sub
  Dim lx, ly As Byte
  For ly = 0 To 8
    Lcd_WrCmd(0xB0+ly)
    Lcd_WrCmd(0x01)
    Lcd_WrCmd(0x10)
    For lx = 0 to 131
      Lcd_WrDat(pFill)
    Next lx
  Next ly
End Sub
  Dim lIndex As Word
  Lcd_SetPos(px, py)
End Sub
    px = px + 6
  Next lCnt
End Sub
Main:                                                           'Main program
    SSel = 0
    delay_ms(500)
    delay_ms(500)
    Lcd_WrCmd(0x3F)              '63
    Lcd_WrCmd(0xA4)
    Lcd_WrCmd(0x8D)
    Lcd_WrCmd(0x14)
'    Lcd_WrCmd(0xA7)
    Lcd_Fill(0x00)
    Lcd_SetPos(0,0)
    delay_ms(500)
    SSel = 1
    While True Wend
End.
Ik heb nog nooit problemen met die displays gehad... (wel nooit met de 1847 gebruikt, want met zo weinig geheugen heeft 't weinig zin...)
Maar zou wel moeten werken. Reset pin moet hoog zijn.
Bavelt
Tja, het geheurgen zal misschien niet erg groot zijn, maar 8K van deze 1847 is toch ook niet héél klein.
Als ik naar de Report View kijk, zit er nog ruimte voldoende met dit programaatje.
