hier een stukje van Roman Black
De hogere frequenties moeten ook een hogere amplitude hebben ( twist compensated )
(code below is an updated example; 6 Mar 2011, it is "twist compenstaed" to better match telephone system specs.
// 24bit DDS algorithm for dual simultaneous sinewaves on one PWM module
// this is an example for DTMF generation
// 8 MHz xtal (8 MIPS on PIC 18F PLL)
#define Frow0 46775 // 697 Hz DTMF rows
#define Frow1 51674 // 770 Hz
#define Frow2 57177 // 852 Hz
#define Frow3 63149 // 941 Hz
#define Fcol0 81135 // 1209 Hz DTMF columns
#define Fcol1 89657 // 1336 Hz
#define Fcol2 99120 // 1477 Hz
#define Fcol3 109589 // 1633 Hz
unsigned long waveA absolute 0x15; // 32bit accumulator for the sinewaves
unsigned char waveA_2 absolute 0x17; // overload for fast access to byte 2
unsigned long waveB absolute 0x19;
unsigned char waveB_2 absolute 0x1B;
unsigned char pwm;
// This uses dual sinewaves of 28% different amplitudes, to match the spec for "twist" in
// telephone DTMF to ensure the higher freq has a higher amplitude, to cope with line losses.
const unsigned char sine64low[64] = {
39,42,46,50,53,57,60,63,66,68,71,72,74,75,76,77,77,77,76,75,74,72,71,68,66,63,60,57,53,50,46,42
39,35,31,27,24,20,17,14,11,9,6,5,3,2,1,0,0,0,1,2,3,5,6,9,11,14,17,20,24,27,31,35};
const unsigned char sine64high[64] = {
50,54,59,64,68,73,77,81,85,88,91,93,95,97,98,99,99,99,98,97,95,93,91,88,85,81,77,73,68,64,59,54,
50,45,40,35,31,26,22,18,14,11,8,6,4,2,1,0,0,0,1,2,4,6,8,11,14,18,22,26,31,35,40,45};
// loop and generate dual sinewave DTMF tone
PR2 = (128-1); // PWM at period = 128
while(1)
while(!PIR1.TMR2IF); // sync to start of PWM cycle
PIR1.TMR2IF = 0;
// calc the A sinewave,
waveA += Frow0; // zero error Accumulation
pwm = sine64low[waveA_2 & 0x3F]; // Binary Divide output (/65536) and keep 6 bits
// calc the B sinewave, and ADD the 2 waves together
waveB += Fcol0;
pwm += sine64high[waveB_2 & 0x3F];
pwm = (pwm >> 1); // scale 0-200 back to 0-100 for PWM
CCPR2L = pwm; // load added sinewaves into PWM module
