Hierbij wat code, waarmee ik iets op het Display krijg.
Het probleem is echter dat het display regelmatig vast loopt, als ik regelmatig tekst naar het display stuur.
;** LCD Display initaliseren ***************************************************
CALL lcd_busyflag ;
MOVLW 0x20 ;set display op 4 bit mode
CALL lcd_commando_8_bit
MOVLW 0x0F ;curcor blink en underscore
CALL lcd_commando_4_bit
MOVLW 0x02 ;display home
MOVLW 0x01 ;display clear
MOVLW D'249' ;
CALL usec ;Korte Wachttijd
;** LCD Display routines *******************************************************
lcd_busyflag CLRF LCD_OUT ;Display Data
BSF STATUS,RP0 ;Bank 1 geactiveerd
MOVLW 0xF0 ;D4-D7 inputs
MOVWF TRISB ;LCD_OUT
BCF STATUS,RP0 ;Bank 0 geactiveerd
BCF LCD_OUT,LCD_RS ;Register Select = Commando
BSF LCD_OUT,LCD_RW ;Read/Write = Lezen van LCD
NOP ;
busy BSF LCD_OUT,LCD_E ;Enable
NOP ;
RLF LCD_OUT,w ;Bits 1 plaats naar Links (F*2),
BCF LCD_OUT,LCD_E ;Enable
NOP ;
BTFSC STATUS,C ;C laag dan jump
GOTO busy ;Hoog --> ga naar busy
CLRF LCD_OUT ;Laag --> Data = 0
MOVLW B'00000000' ;D0-D7 outputs
RETURN ;Einde
lcd_puls_e BSF LCD_OUT,LCD_E ;Enable = Hoog
NOP ;
BCF LCD_OUT,LCD_E ;Enable = Laag
RETURN ;
lcd_commando_4_bit
MOVWF lcddata ;Display Data
ANDLW B'11110000' ;Hoge bits doorlaten
MOVWF LCD_OUT ;Display Data
BCF LCD_OUT,LCD_RW ;Read/Write = Schrijven naar LCD
CALL lcd_puls_e ;Pulsje op 'Enable' ingang
SWAPF lcddata,w ;Hoge/Lage bits verwisselen
lcd_commando_8_bit
CALL lcd_busyflag ;
RETURN ;
lcd_karakter_4_bit
MOVWF lcddata ;
ANDLW 0xF0 ;
MOVWF LCD_OUT ;
BSF LCD_OUT,LCD_RS ;
CALL lcd_puls_e ;
swapf lcddata,w ;
andlw 0xF0 ;
movwf LCD_OUT ;
bsf LCD_OUT,LCD_RS ;
bcf LCD_OUT,LCD_RW ;
call lcd_puls_e ;
call lcd_busyflag ;
MOVLW D'249' ;
RETURN ;
;** Tekst naar Display *********************************************************
;LCD Display Tekst Plaatsen
MOVLW 0x80 ;Cursor positie
CALL lcd_commando_4_bit ;--> LCD Module
MOVLW '*' ;'
;* Delay routines. These routines need to be modified to work with the *
;* particular PIC configuration used. For test purposes, they are instruction *
;* count delays based on 4Mhz PIC. The delays are a little longer than *
;* advertised but close enough for testing. *
DELAY4100 ; 4.1ms delay
MOVLW D'252'
MOVWF R1
MOVLW 4
MOVWF R2
MOVLW 1
MOVWF R3
MOVLW 1
MOVWF R4
DELAY_LOOP
NOP
DECFSZ R1,F
GOTO DELAY_LOOP
DECFSZ R2,F
GOTO DELAY_LOOP
DECFSZ R3,F
GOTO DELAY_LOOP
DECFSZ R4,F
GOTO DELAY_LOOP
RETURN
DELAY100 ; 100µs delay
MOVLW D'44'
MOVWF R1
MOVLW 1
MOVWF R2
MOVLW 1
MOVWF R3
MOVLW 1
MOVWF R4
GOTO DELAY_LOOP
DELAY15000 ; 15ms delay
MOVLW D'156'
MOVWF R1
MOVLW 15
MOVWF R2
MOVLW 1
MOVWF R3
MOVLW 1
MOVWF R4
GOTO DELAY_LOOP
Wie ziet er een fout ?
Edit:
Waarschijnlijk moet ik de 'lcd_busyflag' gebruiken !
Maar hoe gebruik ik deze ?
[Bericht gewijzigd door MMSoft op ]
Ik begin maar eens helemaal vooraan.
In alle datasheets zie ik:
Instruction RS R/: DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0
Clear display 0 0 0 0 0 0 0 0 0 1
Dus als ik het Display wil wissen moet ik Datalijn 0 hoog maken.
Maar omdat ik volgens het 4 Bits systeem werk kan ik deze niet Hoog maken (DB0 is niet aangesloten).
Wie ?
Marcel
AVR C tutorial http://expand.xs4all.nl/avr
Dat kan wel, in het 4-bits systeem splits je de byte op in 2 stukken. Je stuurt eerst de 4 MSB bits en daarna de 4 LSB bits. Zou ook net andersom kunnen zijn, maar dat valt wel te achterhalen in een HD44780 datasheet.
Ik kan helaas geen datasheet vinden van het display dat ik heb. Is er een standaard waarde voor onderstaande zaken:
FUNCTION_SET ; Send the function set command 4-bit I/F, Font, Number of lines
DISP_OFF
DISP_ON
ENTRY_INC
Zoals Marcel hier al zegt: zoek eens een datasheet van de HD44780, de meest-gebruikte controller voor karakter LCD modules.
FullPower
De grootste moeilijkheden liggen daar waar we ze niet zoeken. [Goethe]
Ik zie één punt waarop het soms verkeerd KAN gaan, en dat is het direct na elkaar gebruiken van BCF en BSF instructies op dezelfde poort. Deze instructies maken gebruik van zgn. Read-Modify-Write. Er kunnen meer pennen veranderen dan dat je zou verwachten.
Ik zou minimaal een NOP instructie tussen de opeenvolgende BCF en BSF commando's plaatsen, afh. van de klokfrequentie. Deze plaatsen, ook al hoeft het niet om aan de timing specificaties van het display te voldoen. Ik heb al heeeeel veeeel van dit soort vage problemen gehad!
FullPower: PIC werkt op 4 Mhz
Op 5 februari 2006 21:06:10 schreef Bliksem:
Wat wil je hebben? Gewoon een stukje asm die in 4 bit een lcd aanstuurt? Dat heb ik nog wel liggen voor een 16F628.
Stuur maar als je wilt, dan probeer ik of dat wel goed werkt....
Ik heb nog eens goed gezocht naar de gegevens van het LCD display en heb deze gevonden:
Zie PDF bestand bij Bestel nummer: 71.52.20210 www.display.nl
Welke codes moet ik nu precies opgeven ?
Het display is volgens de 4 bits mode aangesloten,
dus de vraag hoe moet dat precies ?
Ik heb al het een en ander geprobeerd, maar zonder succes.
;LCD Display initaliseren
MOVLW 0x?? ;FUNCTION_SET: 4 bits, 2 lines
CALL SEND_CMD ;
MOVLW 0x?? ;Display off
CALL SEND_CMD
MOVLW 0x?? ;Display ON
CALL SEND_CMD
MOVLW 0x?? ;ENTRY_INC
CALL SEND_CMD
Voor iedere opdracht moet je toch 8bits sturen, dat is dus 2x 4 bits achter elkaar, met dus ook 2 'Enable' pulsen. Deze commando's zijn vaak in HEX en binaire code terug te vinden in de datasheet, deze moet je dus opsplitsen, eerst stuur je 4 van de 8 bits, daaran de andere 4. Of de hoogste of laagste 4 bits eerst moeten, weet ik niet, dat staat ook wel in de datasheet. Voor de 4-bit interface moet je ook een andere initalisatie-opdracht geven dan bij een 8bit interface. De RS pin geeft aan of het om text of een opdracht gaat, de R/W pin is meestal overbodig, omdat er toch niemand leest, en die Busy flag controle wil volgens mij ook weleens uCs vast laten lopen, dus daar zou je gewoon een korte vertraging in kunnen voeren.
Ik heb deze code uit een 4 bits voorbeeld.
Dit werkt bij mij echter niet.
Ik krijg niets op het display !
; Modified to only use 4 bit interface and to not destroy the
; contents of the lower portion of the output register and the
; output register TRIS. Changed the examples to include a table
; definition using the "dt" compiler directive. Added delay
; subroutines for testing. Changed CHECK_BUSY to WAIT_BUSY and
; added a CHECK_BUSY that returns 0 if not busy, ff if busy.
;* The LCD 4-bit Module Subroutines *
;*SendChar - Sends character to LCD *
;*This routine splits the character into the upper and lower *
;*nibbles and sends them to the LCD, upper nibble first. *
SEND_CHAR
MOVWF CHAR ; Character to be sent is in W
CALL WAIT_BUSY ; Wait for LCD to be ready
MOVLW 0x0F
ANDWF LCD_DATA,F ; Clear the upper nibble
MOVF CHAR,W
ANDLW 0xF0 ; Get upper nibble
IORWF LCD_DATA,F ; Send data to LCD
BCF LCD_CNTL,1 ; Set LCD to write
BSF LCD_CNTL,0 ; Set LCD to data mode
BSF LCD_CNTL,2 ; Toggle E for LCD
BCF LCD_CNTL,2
MOVLW 0x0F
SWAPF CHAR,W
ANDLW 0xF0 ; Get lower nibble
BCF LCD_CNTL,2
RETURN
;* SEND_CMD - Sends command to LCD *
;* This routine splits the command into the upper and lower *
;* nibbles and sends them to the LCD, upper nibble first. *
SEND_CMD
MOVLW 0x0F
MOVF CHAR,W
BCF LCD_CNTL,0 ; Set LCD to command mode
BCF LCD_CNTL,2
MOVLW 0x0F
SWAPF CHAR,W
BCF LCD_CNTL,2
RETURN
;* This routine checks the busy flag, returns when not busy *
;* Affects: *
;* LCD_TEMP - Returned with busy/address *
WAIT_BUSY
BSF STATUS,RP0 ; Select Register page 1
MOVLW 0xF0 ; Set port to input
IORWF LCD_DATA_TRIS,W ; Only set upper half of port
MOVWF LCD_DATA_TRIS
BCF STATUS,RP0 ; Select Register page 0
BCF LCD_CNTL,0 ; Set LCD for Command mode
BSF LCD_CNTL,1 ; Setup to read busy flag
BSF LCD_CNTL,2 ; Set E high
BCF LCD_CNTL,2 ; Set E low
MOVF LCD_DATA,W ; Read upper nibble busy flag, DDRam address
ANDLW 0xF0 ; Mask out lower nibble
MOVWF LCD_TEMP
BSF LCD_CNTL,2 ; Toggle E to get lower nibble
BCF LCD_CNTL,2
SWAPF LCD_DATA,W ; Read lower nibble busy flag, DDRam address
ANDLW 0x0F ; Mask out upper nibble
IORWF LCD_TEMP,W ; Combine nibbles
BTFSC LCD_TEMP,7 ; Check busy flag, high = busy
GOTO WAIT_BUSY ; If busy, check again
BCF LCD_CNTL,1
MOVLW 0x0F
ANDWF LCD_DATA_TRIS,W
MOVWF LCD_DATA_TRIS ; Set Port for output
BCF STATUS, RP0 ; Select Register page 0
RETURN
;* This routine checks the busy flag, returns FF if busy, 00 if *
;* not busy. LCD_TEMP will contain the current address. *
;* Affects: *
CHECK_BUSY
MOVWF LCD_DATA_TRIS
MOVWF LCD_TEMP
BCF LCD_CNTL,2
GOTO BUSY_EXIT ; If busy exit with busy flag set
BCF LCD_CNTL,1
MOVLW 0x0F
RETLW 0x00
BUSY_EXIT
BCF LCD_CNTL,1
MOVLW 0x0F
RETLW 0xFF
;* - Initilize the LCD Display Module *
LCD_INIT
BCF LCD_CNTL,2 ; Clear all controll lines
BCF LCD_CNTL,0
BCF LCD_CNTL,1
CALL DELAY15000 ; Wait for 15ms for LCD to get powered up
CALL DELAY15000
CALL DELAY15000
MOVLW 0x0F
MOVLW 0x30 ; Command for 4-bit interface high nibble
MOVLW 0x0F
BSF LCD_CNTL,2 ; Clock the initalize command to LCD module
BCF LCD_CNTL,2
CALL DELAY4100 ; Delay for at least 4.1ms before continuing
BCF LCD_CNTL,2
CALL DELAY100 ; Delay for at least 100usec before continuing
BCF LCD_CNTL,2
CALL WAIT_BUSY ; From here on, the Busy Bit will be valid.
MOVLW 0x0F
MOVLW 0x20 ; Command for 4-bit interface high nibble (Really an 8bit command but
; lower 4 bits are don't care at this point)
BCF LCD_CNTL,2
MOVLW 0x28 ;FUNCTION_SET: 4 bits, 2 lines, 5x7 font
CALL SEND_CMD ;Can now use the SEND_CMD routine since Busy Bit Valid and in 4bit mode.
MOVLW 0x08 ;Display off
CALL SEND_CMD
MOVLW 0x0C ;Display ON
CALL SEND_CMD
MOVLW 0x06 ;ENTRY_INC
CALL SEND_CMD
; LCD Module is now initalized
RETURN
MOVLW D'252'
MOVWF R1
MOVLW 4
MOVWF R2
MOVLW 1
MOVWF R3
MOVLW 1
MOVWF R4
DELAY_LOOP
NOP
DECFSZ R1,F
GOTO DELAY_LOOP
DECFSZ R2,F
GOTO DELAY_LOOP
DECFSZ R3,F
GOTO DELAY_LOOP
DECFSZ R4,F
GOTO DELAY_LOOP
RETURN
MOVLW D'44'
MOVWF R1
MOVLW 1
MOVWF R2
MOVLW 1
MOVWF R3
MOVLW 1
MOVWF R4
GOTO DELAY_LOOP
MOVLW D'156'
MOVWF R1
MOVLW 15
MOVWF R2
MOVLW 1
MOVWF R3
MOVLW 1
MOVWF R4
GOTO DELAY_LOOP
En zo roep ik deze code op:
Aan het einde van het Initaliseren:
CALL LCD_INIT ;LCD Display initaliseren
Tijdens programma:
MOVLW 0x83 ;Select address of character to display
CALL SEND_CMD ;Cursor positie DDRAM address, first character
MOVLW '*' ;
CALL SEND_CHAR ;Display "*" character
Turbokeu
Mario,
De code die je gepost hebt is de 4bits-code die ik gebruik voor al mijn LCD en LCD-compatibele VFD projecten, dus ik weet zeker dat ze werkt.
Zoals ik in een mailtje naar jou zei moet het bestand LCD.H in dezelfde map staan als je ASM bestand.
LCD.H:
nolist
_ResetVector set 0x00
_IntVector set 0x04
; LCD4 Module commands
LINE1 EQU 0x80 ; Set display to line 1 character 0
LINE2 EQU 0xC0 ; Set display to line 2 character 0
FUNCTION_SET EQU 0x28 ; 4 bits, 2 lines, 5x7 font
DISP_ON EQU 0x0C ; Display on
DISP_ON_C EQU 0x0E ; Display on, Cursor on
DISP_ON_B EQU 0x0F ; Display on, Cursor on, Blink cursor
DISP_OFF EQU 0x08 ; Display off
CLR_DISP EQU 0x01 ; Clear the Display
ENTRY_INC EQU 0x06 ;
ENTRY_INC_S EQU 0x07 ;
ENTRY_DEC EQU 0x04 ;
ENTRY_DEC_S EQU 0x05 ;
DD_RAM_ADDR EQU 0x80 ; Least Significant 7-bit are for address
HOME EQU 0x80 ; Upper Left corner of the Display
list
LCD.H declareer je zo in je ASM bestand:
Processor 16F628A
LIST P=PIC16F628A
#INCLUDE "P16F628A.INC"
RADIX HEX
EXPAND
#INCLUDE <LCD.H>
__CONFIG _CP_OFF & _MCLRE_OFF & _WDT_OFF & _INTOSC_OSC_NOCLKOUT & _LVP_OFF & _PWRTE_ON & _BOREN_OFF & _DATA_CP_OFF
Hier een fotootje van een Noritake 2x20 LCD-compatibel VFD display werkend met deze code (er zijn zelfs een aantal user defined karakters in CGRAM gebruikt):
Als je alle bestanden die ik je opgestuurd heb in dezelfde map plaatst en compileert en hetzelfde aansluitschema gebruikt moet je LCD exact weergeven zoals op de foto.
CD
PS: Misschien een stomme vraag: Het contrast van je LCD staat toch goed?
Contrast staat goed !
Dan zit er niet andes op dan dat ik een slecht display heb (ik weet het niet meer) ....
Ik heb ook al een nieuwe PIC geprobeerd, maar het probleem blijft !
Ook als ik alles bestanden die ik van je (Turbokeu) ontvangen heb compileer, dan krijg ik helemaal niets op het scherm.
Daarom probeer ik de juiste code (volgens de datasheet van mijn display) te plaatsen in de initalisering.
Ik begrijp echter nog niet hoe ik dit aanpak, met het oog op 8 bits code (die in de datasheet staat) plaatsen in deze code.
Het vreemde is dat het display wel werkt met de code van Ganzz !
Helaas is dat geen asm code...
Zucht... Als dat LCD met een ander z'n code wel werkt, ligt het dus niet aan de LCD.
Zo spannend is een 44780 nou ook weer niet - heb je de datasheet wel eens goed gelezen? Staan voorbeeldjes in tot op bit niveau, met timing diagrams en alles. Zo vreselijk moeilijk kan het in assembly dan toch niet meer zijn??
Had je nou met een AVR gewerkt, had je wat aan mijn assembly library gehad
Wie wil er eens in de datasheet kijken, omdat dit voor mij het eerste (en als het zo daargaat tevens het laatste
) LCDtje is, kan ik niets vergelijken.
Turbokeu
Op 11 februari 2006 11:13:25 schreef MMSoft:
Contrast staat goed !Dan zit er niet andes op dan dat ik een slecht display heb (ik weet het niet meer) ....
Ik begrijp echter nog niet hoe ik dit aanpak, met het oog op 8 bits code (die in de datasheet staat) plaatsen in deze code.Het vreemde is dat het display wel werkt met de code van Ganzz !
OK...
Je PIC draait toch aan 4MHz? (de delays in mijn LCD routines zijn voorzien voor een clock van 4MHz)
Op de tientallen LCD's die ik bezit heb ik ook ééntje die niet werkt met deze code, ligt dus aan het LCD zelf in mijn geval.
Heb je geen ander LCD'eetje om te testen?
CD
PIC draait op 4MHz (Kristal).
Tientallen LCD's ?
Wat ben jij van plan
Omdat ik pas begonnen ben met LCDtjes heb ik er maar 1.
Bij Voti zijn ze tijdelijk op, dus maar een dure besteld bij Display.
Terug sturen is lastig omdat hij het (soms) wel doet !
Je kan ze ook goedkoop bij www.world-led.com kopen, daar heb ik ook nog een voorraadje van liggen. Ik zal ook als ik het niet vergeet straks even die code mailen, die staat alleen op een andere pc dan deze, en omdat ik door de week in delft zit had ik ook toen de mogelijkheid niet, maar hij komt eraan.
Turbokeu
Op 11 februari 2006 12:55:10 schreef MMSoft:
Tientallen LCD's ?
Gewoon wat reserve...
Gekocht op het goede moment, 't kan altijd van pas komen.
Mijn LCD-VFD collectie:
2x16, 2x20, 4x16, 4x20, 2x40.
Bovenaan een blauwe grafische 240x128, onderaan links een blauwe grafische 340x240, en helemaal links onderaan een 2x20 OLED.
Rechts al mijn VFD's waaronder één grafische en twee 16-segments, 1x20, 2x20, 2x24, 2x40, 4x20 en twee enorme 1x20 VFD's van IEE -"The Moose".
CD
PS: Er ontbreekt nog een Seetron 120x32 grafisch LCD maar die zit in mijn desktop.
Geen wonder dat bijna overal die Displays zijn uitverkocht
Bliksem: Alvast bedankt !
Op 11 februari 2006 13:38:36 schreef Bliksem:
Nog niets gezien
Een 16x2tje heb ik evt. ook nog wel voor je. Als je geen haast hebt, wil ik 'm ook nog wel even voor je testen (zal wel goed zijn, maar om je probleem nou niet ingewikkelder te maken dan het is...). Mocht je interesse hebben, probeer dan per mail.
