Ik ben al een tijdje met PIC's aan het stoeien, en kom hierbij regelmatig het commando ERRORLEVEL tegen.
Waarvoor dient dit precies ?
errorlevel {0|1|2|+msgnum|-msgnum} [, ...]
Sets the types of messages that are printed in the listing file and error file.
 Setting  Affect
0  Messages, warnings, and errors printed
1  Warnings and errors printed
2  Errors printed
-msgnum  Inhibits printing of message msgnum
+msgnum  Enables printing of message msgnum
Usage
This directive is used in the following types of code: absolute or relocatable.
For information on types of code, see Assembler Operation.
Errors cannot be disabled. Warnings may be disabled using setting 2.
Messages may be disabled using settings 1 or 2.
Also, messages may be disabled individually.
However, the setting of 0, 1, or 2 overrides individual message disabling or enabling.
Be careful about disabling warnings and messages,
as this can make debugging of your code more difficult.
The most common usage for this directive is to suppress "MESSAGE 302 - Operand Not in bank 0,
 check to ensure bank bits are correct".
See the Simple Example for how to do this.
Simple Example
errorlevel -302 ; Turn off banking message
                ; known tested (good) code
errorlevel +302 ; Enable banking message
                ; untested code
end
Of gebruik gewoon de "Help" van MPASM Assembler waar je dit mooi geformatteerd krijgt met meer voorbeelden erbij.
Bedankt !
(mocht iemand een nederlandstalige uitleg hebben, dan was het nog mooier).
