Ik heb problemen met het programmeren van de beruchte Busy Flag. De code met een normale wachtfunctie heeft geen problemen, echter als ik ipv het wachten er een busy flag functie in zet gaat het fout en doet ie niks meer. Wie heeft enig idee waar de fout in de code zit:
list P=16F684a
include "F:\Program Files (x86)\VELLEMAN\LCD\P16F84a.INC"
__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
EN EQU 0
RW EQU 1
RS EQU 2
DB0 EQU 0
DB1 EQU 1
DB2 EQU 2
DB3 EQU 3
DB4 EQU 4
DB5 EQU 5
DB6 EQU 6
DB7 EQU 7
TEMP EQU 0x0C0
TEMP1 EQU 0x0C1
TEMP2 EQU 0x0C2
TEMP3 EQU 0x0C3
ORG 0
START CLRF STATUS
CLRF OPTION_REG
CLRF INTCON
CLRF PCLATH
BCF PORTA,RS
BCF PORTA,RW
BCF PORTA,EN
BCF PORTB,DB1
BCF PORTB,DB2
BCF PORTB,DB3
BCF PORTB,DB4
BCF PORTB,DB5
BCF PORTB,DB6
BCF PORTB,DB7
MOVLW 0x000 ; 00000000B
TRIS PORTA
TRIS PORTB
MAIN CALL LCD_UNIT
CALL CLEAR_LCD
MOVLW '1'
CALL WRITE_TEXT
MOVLW '2'
CALL WRITE_TEXT
MOVLW '3'
CALL WRITE_TEXT
MOVLW '4'
CALL WRITE_TEXT
MOVLW '5'
CALL WRITE_TEXT
MOVLW '6'
CALL WRITE_TEXT
MOVLW '7'
CALL WRITE_TEXT
MOVLW '8'
CALL WRITE_TEXT
MOVLW 0x0C0
CALL CURSOR
MOVLW '9'
CALL WRITE_TEXT
MOVLW '8'
CALL WRITE_TEXT
MOVLW '7'
CALL WRITE_TEXT
MOVLW '6'
CALL WRITE_TEXT
MOVLW '5'
CALL WRITE_TEXT
MOVLW '4'
CALL WRITE_TEXT
MOVLW '3'
CALL WRITE_TEXT
MOVLW '2'
CALL WRITE_TEXT
STOP GOTO STOP
LCD_UNIT BCF PORTA,RS
BCF PORTA,RW
BCF PORTA,EN
MOVLW 0x038 ;Function Set 00111000B
MOVWF PORTB
CALL BUSY_CHECK
BSF PORTA,EN
BCF PORTA,EN
BCF PORTA,RS
BCF PORTA,RW
BCF PORTA,EN
MOVLW 0x00E ;Display ON/OFF Control 00001110B
MOVWF PORTB
CALL BUSY_CHECK
BSF PORTA,EN
BCF PORTA,EN
CALL CLEAR_LCD
BCF PORTA,RS
BCF PORTA,RW
BCF PORTA,EN
MOVLW 0x006 ;Entry Mode Set 00000110B
MOVWF PORTB
CALL BUSY_CHECK
BSF PORTA,EN
BCF PORTA,EN
RETURN
CURSOR BCF PORTA,RS
BCF PORTA,RW
BCF PORTA,EN
MOVWF PORTB
CALL BUSY_CHECK
BSF PORTA,EN
BCF PORTA,EN
RETURN
CLEAR_LCD BCF PORTA,RS
BCF PORTA,RW
BCF PORTA,EN
MOVLW 0x001 ;00000001B
MOVWF PORTB
CALL BUSY_CHECK
BSF PORTA,EN
BCF PORTA,EN
RETURN
WRITE_TEXT MOVWF PORTB
BCF PORTA,RS
BCF PORTA,EN
BSF PORTA,RS
CALL BUSY_CHECK
BSF PORTA,EN
BCF PORTA,EN
RETURN
BUSY_CHECK BCF PORTA,EN
BcF PORTA,RS
BSF PORTA,RW
MOVLW 0x0FF ;11111111B
TRIS PORTB
MOVLW 0x0FF
MOVWF PORTB
BSF PORTA,EN
MOVLW PORTB
MOVWF TEMP
BCF PORTA,EN
BTFSC TEMP,DB7
GOTO BUSY_CHECK
BCF PORTA,RS
MOVLW 0x000 ;00000000B
TRIS PORTB
RETURN
END
Videomodulator
AKA Naftebakje @Tweakers.net --- Zonder dwarsliggers geen spoor
Ik kan me wel voorstellen dat om te besparen, el-cheapo fabrikanten die busy flag gewoon weglaten. Ik zou niet weten of het inderdaad zo is, maar meten is weten, hang eens een scoop aan de busy flag en kijk wat ie doet (handigst mss als je nog met normale wachtfunctie's werkt).
Ik meen me ook te herinneren dat het een lange tijd (tot 500ms ofzo) kan duren tussen het opkomen van de spanning, en dat de LCD klaar is om instructie's te ontvangen. Misschien toch een lange vertraging insteken bij het opstarten, je weet nooit dat het lukt.
ben geen assembly pro,
maar heb je gecontroleerd of:
-je de r/w pin omzet van schrijven naar lezen?
-heb je voldoende wacht tijd (in trand van 2 ms ofzo, zie hiervoor de datasheet) om te checken of de busy hoog wordt, niet dat je dit moment mist.
-een poll loop om te kijken wanneer de busy flag weer laag gaat
-zet je de r/w pin weer op goede niveau om te schrijven?
@VM: het is geen harde pin naar buiten, maar een bit in een register. Gaat met een scoop niet zo opschieten.
Ik spreek geen pic-ding assembly, maar kijk eens naar de voorbeelden in de datasheet. Je R/nW zet je goed?
pros
Een andere aanpak bestaat er in, in de datasheet de maximum instructietijden van de lcd-module op te zoeken, en softwarematig vertragingen in te schakelen waar nodig. Buiten de instucties "clear display" en "cursor at home", die elk een 1.64mS duren, zijn er geen lange wachttijden nodig - de rest duurt max 40uS. Voor mensen die op hun pic of avr geen tijdskritieke taken afhandelen, is dat best te doen.
Weg met die Busy Flag!
Xenobinol
Technology is dominated by two types of people: those who understand what they do not manage and those who manage what they do not understand
Ik wil best wel ff kijken hoor... maar PIC asm. is al een tijdje geleden voor mij.
Zou je niet eerst eens even wat tekst bij je code plaatsen?
Zo kan ik er zo snel niks van bakken.
Zet je het data directie register wel om?
Op 11 september 2006 19:57:10 schreef pros:
Ik gebruik hem altijd, zodoende hoef ik nooit rekenschap te houden met de timing van de LCD module, handshaking is daar tenslotte voor bedoelt.
[Bericht gewijzigd door Xenobinol op ]
picsels
Volgend project: 7-seg gaming displays; dan dec-1982 labvoeding afmaken, dan funcgen met ad9833 afmaken, dan...
VIP,
Ik had onlangs toevallig iets soortgelijks en jij loopt tegen hetzelfde aan. De initialisatie van de display gaat fout.
Twee dingen:
- De LCD moet tijd krijgen om op te starten. Ik zie in je code niet de 'verplichte' 40 ms wachttijd. Hiervoor kun je dus niet de busy flag gebruiken.
- Vervolgens moet je de function set functie aanroepen (wat je ook doet). Maar weer mag je nu nog niet de busy flag gebruiken. Hier moet je eerst weer tenminste 4ms wachten.
- Tot slot nog eens de function set met de instelling of je 4 of 8 bits wilt gebruiken. Vanaf nu kun je de busy flag gebruiken.
In de datasheet staat een mooie 'proces flow' waar deze stappen precies in staan. Dit loste tenminste mijn probleem op.
Omdat je nu nergens meer gebruik maakt van een wachtfunctie, gaat de initialisatie fout. Dat los je op door toch twee keer te wachten, zoals hierboven beschreven.
Hoop dat dit helpt.
Ik gebruik zelf ook altijd de busy flag, maar meer uit estetisch oogpunt.
