Jaja ZAQ, k voel die drang nu al :P De vonkbrug zo stellen dat ie ALLES geeft wat ie kan, net da laatste beetje exptra power er uit persen, maar da is niet genoeg! Meer! Beter! GROTER! LANGER! :9~
Maar, k ben nu ff uitgespeeld, mn mmc zei net KNAP! 1 van mn caps is open gebarsten als een rijpe kers... ;( Damn you MMC! Kga tog maar voor de goude oude onvernietigbare flessen :P
Oke.. keb net ff mijn geplande ontwerp ingevoerd in java TC.. MOT stack weet nog niet precies alle waarden (ook nog testen of hij het doet.. maar dat doen we zaterdag :Z).
J A V A T C v.10 - CONSOLIDATED OUTPUT
donderdag 12 januari 2006 16:00:13
Units = Centimeters
Ambient Temp = 20°C
Surrounding Inputs:
500 = Ground Plane Radius
500 = Wall Radius
500 = Wall Height
500 = Ceiling Radius
500 = Ceiling Height
Secondary Coil Inputs:
Current Profile = G.PROFILE_LOADED
6.25 = Radius 1
6.25 = Radius 2
0 = Height 1
63 = Height 2
1300 = Turns
0.0425 = Wire Diameter
Primary Coil Inputs:
8.25 = Radius 1
23.45 = Radius 2
0 = Height 1
0 = Height 2
10 = Turns
0.8 = Wire Diameter
0.0576 = Primary Cap (uF)
0 = Desired Coupling (k)
Top Load Object Inputs (dimensions & topload or ground connection):
Toroid #1: minor=12.5, major=40, height=70, topload
Secondary Outputs:
174.18 kHz = Secondary Resonant Frequency
90 deg° = Angle of Secondary
63 cm = Length of Winding
20.63 cm = Turns Per Unit
0.05962 mm = Space Between Turns (edge to edge)
510.51 m = Length of Wire
5.04:1 = H/D Aspect Ratio
62.04 ohms = DC Resistance
38927 ohms = Forward Transfer Impedance
38541 ohms = Reactance at Resonance
0.644 kg = Weight of Wire
35.217 mH = Les-Effective Series Inductance
32.531 mH = Lee-Equivalent Energy Inductance
38.393 mH = Ldc-Low Frequency Inductance
23.708 pF = Ces-Effective Shunt Capacitance
21.468 pF = Cee-Equivalent Energy Capacitance
48.298 pF = Cdc-Low Frequency Capacitance
0.1796 mm = Skin Depth
16.797 pF = Topload Effective Capacitance
146.5 ohms = Effective AC Resistance
263 = Q
Primary Outputs:
115.18 kHz = Primary Resonant Frequency
33.87 % high = Percent Detuned
0 deg° = Angle of Primary
995.88 cm = Length of Wire
0.72 cm = Average spacing between turns (edge to edge)
2 cm = Primary to Secondary Clearance
33.149 µH = Ldc-Low Frequency Inductance
0.02519 µF = Cap size needed with Primary L (reference)
153.229 µH = Lm-Mutual Inductance
0.136 k = Coupling Coefficient
7.35  = Number of half cycles for energy transfer at K
31.55 µs = Time for total energy transfer (ideal quench time)
Transformer Inputs:
230 [volts] = Transformer Rated Input Voltage
8700 [volts] = Transformer Rated Output Voltage
105 [mA] = Transformer Rated Output Current
50 [Hz] = Mains Frequency
230 [volts] = Transformer Applied Voltage
0 [amps] = Transformer Ballast Current
0 [ohms] = Measured Primary Resistance
0 [ohms] = Measured Secondary Resistance
Transformer Outputs:
914 [volt*amps] = Rated Transformer VA
82857 [ohms] = Transformer Impedence
8700 [rms volts] = Effective Output Voltage
4 [rms amps] = Effective Input Current
914 [volt*amps] = Effective Input VA
0.0384 [uF] = Resonant Cap Size
0.0576 [uF] = Static gap LTR Cap Size
0.1002 [uF] = SRSG LTR Cap Size
55 [uF] = Power Factor Cap Size
12302 [peak volts] = Voltage Across Cap
43487 [peak volts] = Recommended Cap Voltage Rating
4.36 [joules] = Primary Cap Energy
432.2 [peak amps] = Primary Instantaneous Current
117.5 [cm] = Spark Length (JF equation using Resonance Research Corp. factors)
Static Spark Gap Inputs:
2 = Number of Electrodes
0.8 [cm] = Electrode Diameter
0.45 [cm] = Total Gap Spacing
Static Spark Gap Outputs:
0.45 [cm] = Gap Spacing Between Each Electrode
12302 [peak volts] = Charging Voltage
11569 [peak volts] = Arc Voltage
36395 [volts] = Voltage Gradient at Electrode
25708 [volts/cm] = Arc Voltage per unit
94 [%] = Percent Cp Charged When Gap Fires
10.311 [ms] = Time To Arc Voltage
97 [BPS] = Breaks Per Second
3.85 [joules] = Effective Cap Energy
604775 [peak volts] = Terminal Voltage
374 [power] = Energy Across Gap
132 [cm] = Static Gap Spark Length (using energy equation)
Auto Tuned:
donderdag 12 januari 2006 16:06:24
Units = Centimeters
Ambient Temp = 20°C
Surrounding Inputs:
500 = Wall Radius
500 = Wall Height
6.25 = Radius 1
6.25 = Radius 2
0 = Height 1
63 = Height 2
1300 = Turns
8.25 = Radius 1
18.918 = Radius 2
0 = Height 1
0 = Height 2
6.67 = Turns
0.8 = Wire Diameter
Secondary Outputs:
177.6 kHz = Secondary Resonant Frequency
41066 ohms = Forward Transfer Impedance
40456 ohms = Reactance at Resonance
36.254 mH = Les-Effective Series Inductance
34.615 mH = Lee-Equivalent Energy Inductance
22.151 pF = Ces-Effective Shunt Capacitance
20.526 pF = Cee-Equivalent Energy Capacitance
45.344 pF = Cdc-Low Frequency Capacitance
0.1779 mm = Skin Depth
16.202 pF = Topload Effective Capacitance
148.2 ohms = Effective AC Resistance
273 = Q
Primary Outputs:
177.6 kHz = Primary Resonant Frequency
0 % = Percent Detuned
569.11 cm = Length of Wire
0.8 cm = Average spacing between turns (edge to edge)
14.008 µH = Ldc-Low Frequency Inductance
0.05756 µF = Cap size needed with Primary L (reference)
103.05 µH = Lm-Mutual Inductance
0.141 k = Coupling Coefficient
7.09  = Number of half cycles for energy transfer at K
19.72 µs = Time for total energy transfer (ideal quench time)
Transformer Inputs:
Ik neem denk ik wat ruimte in zo :+ (zeg maar als ik wat overbodigs hierboven weg moet halen).
Is die coupling beetje goed? tussen 1 en 2.. dus dat zal wel...
En die spark gap lijkt mij klein >_< en verder, zou ik deze condensator kunnen maken als een MMC, met leuke CDE'tjes of zo? Verder, getuned komt hij er zo uit te zien:
@ Pim
Ziet er kickuh uit man!!! Ik moet nu toch maar eens heel snel weer gaan doorwerken. Ik moet eerlijk bekennen dat ik deze vakantie allemaal plannen had, maar dus gewoon nergens tijd voor helaas :(
Ik wil ook eindelijk eens first-light! :P
Trouwens, hoe aard jij je coil, zo binnen?
Aansluiten op de gewone huisaarding is opzich vrij dodelijk voor al je elektronische aparatuuur dat er op aangesloten staat, toch?
Ik was namelijk van plan die van mij buiten te laten lopen, en voor de aarding gewoon een dikke pin van een meter ofzo de grond in boren.
Edit: Trouwens Pim, heb je niet een foto waar je coil uit staat en waar alleen de onderdelen op te zien zijn. Ben ik ook wel benieuwd naar! :)
Chris
[Bericht gewijzigd door coaster_chris op ]
Op 12 januari 2006 16:40:47 schreef coaster_chris:
@ Pim
Ziet er kickuh uit man!!! (...)
Trouwens, hoe aard jij je coil, zo binnen? (...)
Chris
Thnx, ben er heel trots op :D Niet dat t veel is, maar er is een begin :D
Enne, aarding... Doe k niet egt aan :P Enige aarding die ik had was mn strike-rail, maar die fikte door naar mn prim, dus heb k em maar gewoon aan mn prim geaard :P Vervloek mij allemaal maar, maar t werkt!
En k zal straks wel ff paar fototjes schieten van alles, t ziet er beetje gammel uit, maar t doet zn werk :) Fotos, coming soon!
Edit: Nog meer foto's! Beetje groot alleen, allemaal ruim een meg per stuk, mja, dat moet tegenwoordig geen probleem meer zijn hoor ;)
Eerst nog 2 van hem in operation:
http://www.lekenlinge.nl/~pimV/DSCF0167.JPG
http://www.lekenlinge.nl/~pimV/DSCF0168.JPG
En een paar van hoe t allemaal aan elkaar hangt :P
http://www.lekenlinge.nl/~pimV/DSCF0170.JPG
- Bij deze foto zie je de prim en sec, en de groen/gele draad is mijn "aarding" :P Gewoon aan de prim, k kon even niks anders verzinnen, en zo doet ie het tenminste!
http://www.lekenlinge.nl/~pimV/DSCF0171.JPG
Mijn MMC, waar zoals jullie vast al zien 1 cap uit ontbreekt! Dat is de klotecap die ging ontploffen! Grr! Maar, alles doet het nog :)
http://www.lekenlinge.nl/~pimV/DSCF0174.JPG
Vage en onscherpe foto van mn sg, maar duidelijk hoe het opgesteld is. Ik blus hem met een stofzuiger.
http://www.lekenlinge.nl/~pimV/DSCF0175.JPG
En een foto van mn NST, ben k heel blij mee :D
[Bericht gewijzigd door Anoniem op ]
Op 12 januari 2006 17:46:08 schreef Lil Pimmetje:
hehe, hmmm... :P
Hoe heb je dat met de onderkant van je sec dan gedaan trouwens?
Edit: Haha, ik zie t! :P Maar je hebt het aantal wikkelingen van je prim dus gewoon "vast" zitten? Als je aan de aansluiting van je primaire schuift kan je het aantal wikkelingen veranderen waarmee ook de resonante frequentie van je primaire veranderd. Voor het beste resultaat moet de frequenties van je primaire en secundaire resonant aan elkaar zijn. Maargoed dan moet je wel een pulsgenerator en scope hebben liggen om het te kunnen meten, anders is het maar hopen dat al je ingevulde waardes in java tc kloppen! ;)
Ziet er verder wel leuk uit man! Ook die gratis NST is wel kickuh hoor! *kuch kuch* ;)
Chris
wow Pim! :D je bent me al voorbij! ik blijf op 11 cm:P en ik heb nog nooit een streamer ofzo gehad:( weet iemand wat ik fout doe?
Jah, heb gewoon gewikkeld, en hem vast gesoldeerd :P Lekker solide, en volgens JavaTC zou het zo goed als 100% resoneren, dus k maak me daar nie druk om. Model 2 ga k wel helemaal "tunen", maar die bouw k ook op school, als profielwerkstuk, dus daar hebben we alle fancy apparatuur enzo. Had k maar een scope en een pulsgen!
En die gratis NST is gewoon super bluh! :P 8kV, 65mA, 500VA & gratis? Daar gaat iedereen het mee eens zijn, das een super deal! ;)
EDIT:
Op 12 januari 2006 18:48:47 schreef soldeerbout:
Naja, fout is weer een zo'n groot woord ;) Maar, staan je tech specs hier al ergens op CO? Anders kan denk ik niemand echt iets zeggen over hoe of wat. Post anders ook paar foto's enzo. Ziet er leuk uit, EN de mensen hier kunnen je helpen ;)
Edit: Sorry mods! Dubbelpost, pleur maar weg!
ff een post zodat ik niet iedre keer moet zoeken :P
Op 12 januari 2006 19:09:12 schreef Bobbyb:
he bobbyb! dat was een tijd geleden:P
BTW als je alle topics over tcs leest zie je dat er steeds minder coilers 'overblijven'. leven jullie nog? :P
niet perongeluk ff met je tong gevoeld of er nog stroom op je motstack stond...
Op 12 januari 2006 18:49:00 schreef Lil Pimmetje:
oke ik zal kijken of in vanavond wat foto's kan posten:)
Mooi lil pimmetje ! Het lijkt erop dat je serieus gevallen bent voor het steeds langere streamer syndroom :) Dat ding doet het leuk.
Als je nog wat verder wil expirimenteren om nog wat verder tekomen. Je topload is nu eigenlijk een schijf met een redelijk scherpe rand. Daardoor heb je nu een stuk ofwat streamers tergelijke tijd. Ziet er ook leuk uit maar die zijn minder lang als dat je een enkele streamer hebt. Ik zou een wat dikkere topoad maken als ik jouw was. Een kleine donut of een afgeronde dikke schijf, iets van 4 cm dik ofzo. Zou al een hoop kunnen schelen. Misschien dat je de primaire een tikje groter moet maken dan.
Hoe glader een hoe flauwer de rondingen deste hoger kan de spanning opbouwen vordat je een streamer krijgt....
Succes in iedergeval !
En de rest ook trouwens, gaat lekker met die VTTC's ! mooie foto's en filmpjes ook.
Edit: Mocht iemand nog cde's gaan bestellen. Wil ik wel meedoen voor 10 :)
Mijn topload voor vttc 2 is onderweg.
Heb een paar wikkelingen op mijn primaire erbij gezet (5 a 6)
omdat ik drie van de acht caps voor mijn tankcap gemold heb.
Electrisch kunnen ze een hoop hebben maar mechanisch tjonge tjonge.
Dus nu kom ik een cap te kort (680pF) vandaar die extra wikkelingen.
Morgenavond komt er hopelijk een of twee filmpjes, waarvan er een in stacato mode is :)
Mooi zaq we wachten weer in spanning op foto's danwel video's.
Wat was er met die caps dan bij het aandraaien van de boutjes het moertje uit de cap gedraait ofzo?
Ik hoop dat de toroid naar wens is.
Eigenlijk hoef je hem geeneens te slijpen denk ik maar ja then again het oog wil ook wat.
Ik heb vandaag gepresteerd om een zwart gat te openen met mijn vttc het type waardoor het zwarte gedeelte van een diode verdwijnt.
Spanning verviervoudigen ging niet helemaal goed zeg maar.
Het liep even goed maar binnen de kortste keren pang pang weg mot diodes.
daarna nog eens geprobeert met gewone diode's daarbij drie in serie maar vergat een ceetje tegen het hf paf weer 9 diodes naar de bliksem :P
Vooralsnog beste resultaat rond de 40 cm.
volgende stap als ik dat nog red voor de sleuteloverdracht worden twee mots in serie met een verdubbelaar.
Sigh.. ik zou bijna de moed opgeven. Er is volgens mij echt iets mis met mijn MOT stack. Als ik hem aangesloten heb, meet ik 15V uit de variac (gewoon parallel met stekkertjes van MOT stack) en zie totaal geen vonken of wat dan ook bij simpele jacobs ladder. Als ik de knop met de klok mee draai, gaat hij meer trillen, en meet ik ook een hogere spanning (richting 30V, maar nooit 230).
Zonder MOT stack doet die variac het gewoon, 230V en 4A (hoor je hem trillen). Ik snap er echt niks meer van :|
[Bericht gewijzigd door dj_tjerk op ]
zou het zo kunnen zijn dat je motstack meer trekt dan de variac kan leveren.
mijn motstack trok onbelast 7 ampere.
Op 14 januari 2006 13:44:50 schreef Sparks:
Ik denk dat als ik de MOT stack los in stopcontact douw, de stoppen er zeker weten uitslaan. Ik wil het wel proberen, maar vorige keren trok hij ruim over de 10-15A.
En anders neem ik een dagje vrij van school en laat mijn ouders me brengen naar Fry of zo :+
Ik denk dat ik zo nog ff alle connecties van de motstack ff doormeet.. stel je voor dat er eentje kapot is of zo.
EDIT:
Laat dat maar zitten :Z Keb mijn meter net opgeblazen (nummer 2 alweer.. sigh)
Het nieuwe jaar is weer begonnen, en ik heb besloten om een tweede TC te gaan bouwen. Zeker na het tragische einde van de vorige.
Die heeft na een paar weken het loodje gelegd.;(
Resultaat van een verbouwing van mijn kamer.
http://home.casema.nl/milord/V
Het enige foto die ik ervan heb is een onduidelijke van de testopstelling.
Maar ja, hij heeft het goed gedaan dus het wordt tijd voor een grotere.
Dipswitch
Hier nog een filmpje, streamers zijn 55+ cm.
Stacato mode wil maar niet goed lukken :(
@ Sparks
Ik ga aan mijn topload niet slijpen, werk van een vakman, bedankt. Idd heb ik iets te lange boutjes in 3 van mijn caps gedraaid en.......... kapot. (een ezel enz..)
Ik kan ook maar korte runs doen (zie lengte filmpje) en daarna moeten mijn mots,buisje en lekweerstand serieus afkoelen, de rest kan het behoorlijk aan.
Filmpje ftp://86.84.49.142/Tesla_4_big_vttc/meerdan.wmv
Mijn camera geeft het niet goed weer, streamers zijn veel feller en witter.
Edit: Zit nu over de 60 cm, heb een cap uit mijn tankcap. gehaald.
Yay, ik kan wikkeldraad krijgen bij een bedrijf in de buurt. Voor de mensen die ook geinteresseerd zijn:
http://www.opijnenconsultants.nl
Anyway, tussen de 6.80 en 7.80 euro per kg, is dat beetje een redelijke prijs? Ik had gevraagd om diameters van .3 tot .7 mm. K denk dat k er wel voor ga iig. Word wel ene duur geintje, maja :P Dat moet maar!
Edit: tussen de 6.80 en 7.80 per kilo... 6.80 koeien? :+ :P Ff 'euro' er bij gezet!
@ZAQ
Ziet er zeer goed uit :).
Al een idee wat er mis is met je stattaco ? Nog steeds problemen met de aardlek ?
@Lil Pimmetje
Dat is een mooie prijs ik betaal hier 10 euro per kilo voor wikkeldraad dus.
Hier mijn nieuwe "flyback" Het is een 10 KW ferriet kern met daarop een secondaire van 400 windingen. Wat waarschijnlijk nog veel te veel is. Een 300 windingen moet goed zijn voor 12 kv ac dus. Maar een nieuwe secondaire is zo te wikkelen. Ik wil zo rond de 12 kv DC over houden na gelijkrichten dus ik zit te denken aan zo'n 200 windingen ofzo met 0.5 mm draad. Maar eerst maar is testen met deze secondaire.
Plaatje, de 9 volt batterij is voor formaat vergelijking.
Foto is belabberde kwaliteit maar de digitale camera hebben mijn ouders mee nu dus.
http://home.hccnet.nl/g.heus/ccps.jpg
edit:
@Fry,
Je pakketje is vrijdag op de post gegaan.
@Jorrit
Dat ziet er serieus uit!!
Mijn stacato heeft denk ik problemen met rf rotzooi van mijn coil, ik ga al dat Si spul maar eens een heel eind uit de buurt van de coil zetten en dan nog eens proberen.
@ZAQ
Bedankt :) Hoop dat het een beetje wil gaan werken maar dat zien we nog wel.
Heb je trouwens je stattaco in een metalen behuizing of plastic ? Ik had ook problemen met mijn interupter toen ik hem in plastic behuizing had zitten. Hij ging nogal storen als een coil aanstond. Nu zit hij in een metalen behuizing en zit op de ingang van de driver een optocoupler. Nu heb ik geen last meer van storing.
Ik krijg binnenkort weer onderdelen voor mijn grote drsstc binnen. Ik ben op dit moment nog bezig met een voeding voor de gate drivers. Deze heeft 4 gescheiden secondaire's wie elk 2 mosfets voeden wie de igbt's aansturen.
Het probleem in mijn eerste drsstc heb ik ook gevonden. Had eindelijk weer een functiegenerator om de boel door te meten. Nu alleen nog tijd vinden om het te verbeteren.
ZO Zaq dat zijn serieuse vonken daar kan ik nog een puntje aan zuigen met mijn vttc.
Maar als de tijd daar is gaat dat zeker gebeuren ;)
Ben blij dat je de toroid mooi vond delassen zijn nog wat ruw naar mijn standaard maar jah ik dacht dat je hem toch ging slijpen :P
Jorrit das wel een serieuse flyback zou dat ding niet graag zijn gang laten gaan in mijn tv
Na een half uurtjes gtst met m'n vriendin zo'n sjagerijnig skelet op het behang geprojecteerd ;)
Ik ben benieuwd hoe dat kerntje gaat presteren heb je hem al eens getest met een h-brugje op een simpele driver of ben je daar nu mee aan het bedraden?
@Sparks.
Nee ik heb hem nog niet gedraait. Ik heb op het moment problemen met mijn h-brug. Dus daar moet ik eerst maar is na kijken. De primaire zit er al wel op dus als de h-brug weer werkt kan ik hem zo testen.
@RC-A
Hier alsnog de link. Ik heb hem zonet weergevonden hoop dat je er nog wat aan hebt.
http://home.att.net/~allencoilpage/xformproj.htm
Op 15 januari 2006 20:06:35 schreef Jorrit:
@RC-A
Bedankt voor de link naar de site. Deze kende ik nog niet! Heel interressant en duidelijk over het wikkelen van hoogspanningstrafo's.
