timmie
beste mensen ik heb een stukje van basic omgeschreven naar C:
basic code:
' Alias pins
Symbol SCL = PORTC.3 ' I2C clock input
Symbol SDA = PORTC.4 ' I2C data input
' Define used register flags
Symbol SSPIF PIR1.3 ' SSP (I2C) interrupt flag
Symbol BF SSPSTAT.0 ' SSP (I2C) Buffer Full
Symbol R_W SSPSTAT.2 ' SSP (I2C) Read/Write
Symbol D_A SSPSTAT.5 ' SSP (I2C) Data/Address
Symbol CKP SSPCON.4 ' SSP (I2C) SCK Release Control
Symbol SSPEN SSPCON.5 ' SSP (I2C) Enable
Symbol SSPOV SSPCON.6 ' SSP (I2C) Receive Overflow Indicator
Symbol WCOL SSPCON.7 ' SSP (I2C) Write Collision Detect
' Allocate RAM
Dim datain as Byte ' Data in
Dim dataout as Byte ' Data out
Goto main ' Jump over the subroutines
' I2C slave subroutine
i2cslave:
SSPIF = 0 ' Clear interrupt flag
If R_W = 1 Then i2Crd ' Read data from bus
If BF = 0 Then Return ' Nothing in buffer so exit
If D_A = 1 Then i2cwr ' Data for bus (not address)
If SSPBUF != 2 Then Return ' Clear the address from the buffer
Return
' I2C write data to bus
i2cwr: datain = SSPBUF ' Put data into datain
Return
' I2C read data from bus
i2crd: SSPBUF = datain ' Get data from datain
CKP = 1 ' Release SCL line
Return
' Main program loop
Main:
' Initialise ports and directions
ADCON1 = 7 ' All PORTA, PORTE pins to digital
' Initialise I2C slave mode
SSPADD = 2 ' Make our address 2
SSPCON2 = 0 ' General call address disabled
SSPCON = $36 ' Set to I2C slave with 7-bit address
Again: If SSPIF = 1 Then Gosub i2cslave ' Check for I2C interrupt
' Clear any I2C collisions or errors
SSPOV = 0
WCOL = 0
Goto Again ' Do it all forever
en dit is de C code geworden.
#define SCL = PORTC.3
#define SDA = PORTC.4
#define SSPIF PIR1.F3
#define BF SSPSTAT.F0
#define SSP (I2C) Read/Write
#define D_A SSPSTAT.F5
#define CKP SSPCON.F4
#define SSPEN SSPCON.F5
#define SSPOV SSPCON.F6
#define WCOL SSPCON.F7
void init(void)
PORTA = 0;
PORTB = 0;
PORTC = 0;
TRISA = 0;
TRISB = 0;
TRISC = 255;
ADCON1 = 7;
SSPADD = 2;
SSPCON2 = 0;
SSPCON = 0x36;
char datain;
char dataout;
void i2cwr(void)
datain = SSPBUF;
PORTA = 255;
void i2crd(void)
SSPBUF = datain;
CKP = 1;
PORTA = 255;
void i2cslave(void)
SSPIF = 0;
if(R_W == 1) i2crd;
if(BF == 0) return;
if(D_A == 1)i2cwr;
if(SSPBUF != 2) return;
void main(void)
init();
while(1)
if(SSPIF == 1) i2cslave;
SSPOV = 0;
WCOL = 0;
maar het werkt niet
wat kan er fout zijn.
het betreft een 16F737 die op zijn interne oscilator draait. de master is een gelijk type die ook op interne osc draait.
ik zal straks even de source van de master er ook bij zetten.
gebruikte compiler:
MikroC voor PIC
/edit
schakeling is opgebouwd op een breadboard
voeding is een labvoeding
ontkoppeling van de pic is aangedacht.
de i2c pinnen hebben pullup weerstanden zowel op sck als sda
picsels
Volgend project: 7-seg gaming displays; dan dec-1982 labvoeding afmaken, dan funcgen met ad9833 afmaken, dan...
timmie
dat was een van de sample codes van proton
en ik geen proton bij de hand heb kan ik dat dus ff niet checken.
timmie
basic code werkt ook niet
maar ik heb inmiddels wat nieuwe source gevonden die hoogst waarschijnlijk wel wekrt(ofwel ik moet hem nog aanpassen naar mijn wensen maar het heeft wel potentie).
http://www.mikroe.com/forum/viewtopic.php?t=8106&highlight=i2c+sla…
[Bericht gewijzigd door timmie op (16%)]
timmie
dat zou je zeggen inderdaad maar daar had ik al aan gedacht.
en maakte niks uit.
echter heb ik nog wel een vraagje over i2c
als ik het goed snap kan ik zolang ik geen stopconditie of herstart conditie verzend gewoon data naar 1 slave toe schuiven zonder continu het adress te moeten zenden toch?
F_E heeft flink wat geschreven over i2c. Zeker de moeite waard om eens te lezen
