Hoe pas ik deze demo Arduino sketch aan tot 'n werkende,om 'n accu te meten
#include <U8g2lib.h>
#include <U8x8lib.h>
// This is the display object. You will change this line if you are using pins
// other that 12, 11, 9 and 10.
U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
// This is the battery bitmap
static const PROGMEM unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
// This is the area inside the battery bitmap, in pixels
#define CHARGE_AREA_START_X 20
#define CHARGE_AREA_START_Y 18
#define CHARGE_AREA_WIDTH 83
#define CHARGE_AREA_HEIGHT 28
// This is the battery fill mode
// BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
// a solid rectangle according to the battery charge.
// BATTERY_MODE_SOLID = 0 means the battery will be filled with a
// rectangle subdivided in 3. If the battery level is 66% or more, it will
// draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
// draw 1 rectagle if the battery is less than 33%.
#define BATTERY_MODE_SOLID 1
// This is the main function, and the one you will want to transplant to your
// code. Pass the battery charge percent and it will draw the battery with
// the corresponding charge level.
void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
display.clearBuffer();
display.drawXBMP(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
display.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 0; i < bars; i++)
display.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
display.sendBuffer();
void setup()
// Initialize the display object
display.begin();
// A variable to test our code.
uint8_t percent = 100;
void loop()
// Some test code to scan all the battery levels
showBatteryLevel(percent);
#include "U8glib.h" // U8glib library for the OLED
int analogInput = 0;
float vout = 0.0;
float vin = 0.0;
float R1 = 100000.0; // resistance of R1 (100K)
float R2 = 10000.0; // resistance of R2 (10K)
int value = 0;
U8GLIB_SH1106_128X64 u8g(13, 11, 10, 9, 8); // D0=13, D1=11, CS=10, DC=9, Reset=8
void draw(void)
void setup(){
pinMode(analogInput, INPUT);
void loop(){
// read the value at analog input
value = analogRead(analogInput);
vout = (value * 5.0) / 1024.0; // see text
vin = vout / (R2/(R1+R2));
if (vin<0.09) {
vin=0.0;//statement to quash undesired reading !
u8g.firstPage();
do
draw();
while( u8g.nextPage() );
delay(500);
else
percent = 100;
delay(50);
}[Bericht gewijzigd door GJ_ op (0%)]
Anoniem
Heb even in mijn glazen bol gekeken.... maar nee....
Wellicht dat het handig is waarom de huidige sketch niet werkt. Heb je de header files niet? Voldoet het type niet ... of ... of ... of.
Zonder meer info kunnen we niet zoveel.
Heb je wel de juiste sourcecode headers?
Volgens mij is dat de code voor een lader en niet om te kijken hoe vol je accu is, of mis ik nu iets.
ik wil een accu meten en dus 'n weerstand brugje aansluiten op de Arduino Nano en de sketch aanpassen zodat ik kan zien wanneer de /'n accu leeg is, net zoals bv met 'n GSM accu indicatie.
hoop dat het zo duidelijker is
hier gebeurt de meting en de berekening. ze gebruiken ingang 0 (A0 denk ik dan).
spanningsdeler R1/R2 moet je dan zelf maken aan die ingang 0 (100K/10K volgens de code)
float vout = 0.0;
float vin = 0.0;
[Bericht gewijzigd door fcapri op (20%)]
Want ik krijg 'n fout melding
Arduino:1.8.6 (Windows 10), Board:"Arduino Nano, ATmega328P (Old Bootloader)"
In file included from C:\Users\Toon\Documents\Arduino\libraries\U8glib\src/U8glib.h:42:0,
from C:\Users\Toon\Documents\Test_van_battery_indictor\Test_van_battery_indictor.ino:175:
C:\Users\Toon\Documents\Arduino\libraries\U8glib\src/clib/u8g.h: In function 'void loop()':
C:\Users\Toon\Documents\Arduino\libraries\U8glib\src/clib/u8g.h:70:8: error: expected unqualified-id before string constant
extern "C" {
Test_van_battery_indictor:213:1: error: expected '}' at end of input
exit status 1
Dit rapport zou meer informatie bevatten met
"Uitgebreide uitvoer weergeven tijden compilatie"
optie aan in Bestand -> Voorkeuren.
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
offset += 28;
void setup()
display.begin();
void loop()
float vout = 0.0;
float vin = 0.0;
int value = 0;
void draw(void)
void setup(){
void loop(){
if (vin<0.09) {
u8g.firstPage();
do
draw();
delay(500);
else
percent = 100;
delay(50);
Nog 'n keer dan de goede ( sorry teveel test sketches )en deze werkt bij mij op 'n breadboard
uint8_t width;
if (percent > 100)
percent = 100;
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
// Show two bars
bars = 2;
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
offset += 28;
void setup()
display.begin();
void loop()
if (percent)
percent--;
else
percent = 100;
delay(50);
ik kan de code niet testen omdat ik de library's niet heb.
ik heb nu al 3 verschillende U8x8 en U8g2lib versies gedownload en nog krijg ik fouten van missende files
fcapri
die kun je zo downloaden;
ga naar Schets in Arduino
Bibliotheek gebruiken
Bibliotheek beheren
boven in ( filter je zoek resultaten )
invullen u8g2
Instaleren
Dan zal het wel lukken
Gr
Roland van Leusden
dit topic heeft naar mijn idee ook een beetje een hoog "werkt niet, hier 1000 regels code copy paste, waarom niet?"
je scope haken kloppen niet. loop die eerst allemaal maar eens na.
de demo doet het tenslotte zeg je zelf
Roland van Leusden
@Stijnos, exact mijn idee. Dergelijke simpele dingen koop je beter kant en klaar. Vaak zit daar een uC van ST (STM8F003) op die je zou kunnen herprogrammeren.
Dus... pak het projectmatig aan.
Programma van eisen:
* Klein
* moet batterij status aangeven.
Plan van aanpak:
* Arduino ...
Stand van zaken:
* ... Wat heb je, wat doet het en wat doet het niet, wat wil je. ...
gaat niet om de hardware maar software die moet aangepast worden zodat het werkt om de status van de accu aan te geven net als bij jullie GSM'.
dus accu aansluiten via weerstand brugje aansluiten op Arduino Nano
en met aangepaste sketch battery indicatie weergeven
daarbij vraag ik hulp aan jullie
Ik heb de hardware werkende op 'n breadboard als demo
Arduino Nano en 'n oled display 1016 128 x 64
het display geeft nu 'n langzaam leeg lopend accutje aan en begint opnieuw
Gr
MGP
LDmicro user.
Het probleem met software is dat als je zelf niet kunt proberen wat je verandert het zeer moeilijk is.
Fcapri is heel goed thuis in Arduino maar als hij het niet kan proberen zal het moeilijk blijven.
Trouwens, over welke batterijen gaat het?
Als je Li-ions gebruikt is deze goed en autoranging en kleiner dan een nano, elders is dat goedkoper, het is maar een voorbeeld.
