Hoe pas ik deze demo Arduino sketch aan tot 'n werkende,om 'n accu te meten
c code:
#include <U8g2lib.h>
#include <U8x8lib.h>
// This is the display object. You will change this line if you are using pins
// other that 12, 11, 9 and 10.
U8G2_SSD1306_128X64_NONAME_F_4W_SW_SPI display(U8G2_R0, 12, 11, U8X8_PIN_NONE, 9, 10);
// This is the battery bitmap
static const PROGMEM unsigned char battery_bitmap[] = {
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xfe, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00,
0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00,
0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0x00, 0x00, 0x00, 0x00, 0xff, 0xff,
0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0x07, 0x00, 0x00,
0xff, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00 };
// This is the area inside the battery bitmap, in pixels
#define CHARGE_AREA_START_X 20
#define CHARGE_AREA_START_Y 18
#define CHARGE_AREA_WIDTH 83
#define CHARGE_AREA_HEIGHT 28
// This is the battery fill mode
// BATTERY_MODE_SOLID = 1 means the battery bitmap will be filled with
// a solid rectangle according to the battery charge.
// BATTERY_MODE_SOLID = 0 means the battery will be filled with a
// rectangle subdivided in 3. If the battery level is 66% or more, it will
// draw 3 rectangles. If it's 33% or more, it will draw 2 rectangles. It will
// draw 1 rectagle if the battery is less than 33%.
#define BATTERY_MODE_SOLID 1
// This is the main function, and the one you will want to transplant to your
// code. Pass the battery charge percent and it will draw the battery with
// the corresponding charge level.
void showBatteryLevel(uint8_t percent)
uint8_t width;
if (percent > 100)
percent = 100;
display.clearBuffer();
display.drawXBMP(0, 0, 128, 64, battery_bitmap);
if (BATTERY_MODE_SOLID)
width = (percent * CHARGE_AREA_WIDTH) / 100;
display.drawBox(CHARGE_AREA_START_X, CHARGE_AREA_START_Y, width, CHARGE_AREA_HEIGHT);
} else {
uint8_t bars;
if (percent >= 66)
// Show three bars
bars = 3;
} else if (percent >= 33)
// Show two bars
bars = 2;
} else if (percent > 0)
// Show one bar
bars = 1;
} else {
// Show nothing
bars = 0;
uint8_t offset = CHARGE_AREA_START_X;
for (uint8_t i = 0; i < bars; i++)
display.drawBox(offset, CHARGE_AREA_START_Y, 27, CHARGE_AREA_HEIGHT);
offset += 28;
display.sendBuffer();
void setup()
// Initialize the display object
display.begin();
// A variable to test our code.
uint8_t percent = 100;
void loop()
// Some test code to scan all the battery levels
showBatteryLevel(percent);
#include "U8glib.h" // U8glib library for the OLED
int analogInput = 0;
float vout = 0.0;
float vin = 0.0;
float R1 = 100000.0; // resistance of R1 (100K)
float R2 = 10000.0; // resistance of R2 (10K)
int value = 0;
U8GLIB_SH1106_128X64 u8g(13, 11, 10, 9, 8); // D0=13, D1=11, CS=10, DC=9, Reset=8
void draw(void)
void setup(){
pinMode(analogInput, INPUT);
void loop(){
// read the value at analog input
value = analogRead(analogInput);
vout = (value * 5.0) / 1024.0; // see text
vin = vout / (R2/(R1+R2));
if (vin<0.09) {
vin=0.0;//statement to quash undesired reading !
u8g.firstPage();
do
draw();
while( u8g.nextPage() );
delay(500);
else
percent = 100;
delay(50);
[Bericht gewijzigd door GJ_ op maandag 5 november 2018 12:44:41 (0%)
