Wat data die ik vanop i-net verzamelde:
CENTER VAN DE KOOKPLAAT WITTE CONN/ NAAR CN2
BLAUWE DRAAD/ NAAR CN3
Out1-> buitenkant inductorcoil
Out2-> binnekant “
Grote print: FY20-M04
Kleinere met display: FYM20-55
Relay zwart: YX202-S-112DM
10A 250VAC
30VDC10240VAC
Van: YONGNENG D4F08
Is relay: http://www.datasheetspdf.com/PDF/YX202-S-112DM/1058871/1
Grote blauwe blokken: capaciteiten wellicht
8µF J 400V 275V MKP-X2
40/085/21
0.3µF J 630V (1200V) 50KHz
40/105/21 CQC10002045639
10µF J 275V (400V) MKP-X2
40/105/21
4µF J 275V (400V)) X2 MKP
40/105/21
CQC04001010677
CHIPS:
HIGHWAY09A
B508J0664G
16 PINS
VIPer12A
F81511
8PINS
http://html.alldatasheet.com/html-pdf/25601/STMICROELECTRONICS/VIPER12…
IS MOSFET EN pwm CONTROLLER
DESCRIPTION
The VIPer12A combines a dedicated current modePWM controller with a high voltage Power MOSFET on the same silicon chip.
Typical applications cover off line power supplies for battery charger adapters, standby power supplies for TV or monitors, auxiliary supplies for motor
control, etc. The internal control circuit offers the
following benefits:
– Large input voltage range on the VDD pin
accommodates changes in auxiliary supply
voltage. This feature is well adapted to battery
charger adapter configurations.
– Automatic burst mode in low load condition.
– Overvoltage protection in hiccup mode
En onder display:
Highway drv8
B511J0700G1
IC2: naast kleine trafo “EE10”
78L05
Is 5V regulator
