wss wel wat aan de late kant maar als jij er niets meer aan hebt kan de volgende die dit leest er maar goed mee zijn
gaat voor de meetste 2000/master 486 dx4 systemen al kan er links en rechts een zaak minder op je bios staan !
Standaard Cmos Setup
Primary Master Auto Normaal
Rest None
Drive A None
Drive B None
Video EGA/VGA
Halt on All, but Keyboard
Bios Feature Setup
Virus Warning Disabled
CPU int. Cach Enabled
External cache Enabled
Quick pos Enabled
Boot seq. C.A
Swap floppy Disabled
Boot up floppy Disabled
Boot up Num On
Boot up Sys High
Gate A20 Fast
Typematic Disabled
Typematic 6
Typematic 250
Security Setup
PCI/VGA Disabled
OS sel Non-os2
Video Bios Enabled
C8000 Disabled
D0000 Disabled
D8000 Disabled
Chipset Feature Setup
Auto Config Disabled
ISA bus 7,159mhz
LBD End of T2
Cache Write 2 CCLK
Cache Burst 2 CCLK
L2 Cache 2 CCLK
Dram Ras 3 CCLK
Dram Write 1 WS
Dram Write 2 CCLK
Dram Cas 1 CCLK
Dram Ras 2 CCLK
Dram Speed Faster
Dram Slow Refresh Disabled
L2 Cache Policy Write Back
L2 Cache Tag Bits 8 Bits
On Board 496B Primary
IDE 0 Master mode 2
IDE 0 Slave mode Auto
IDE 1 Master mode Auto
IDE 1 Slave mode Auto
IDE Prefetch Disabled
IDE HDD Block mode Disabled
Onboard FDD Disabled
Onboard Serial 1 Com1/3F8
Onboard Serial 2 Com2/2F8
Onboard Parallel Port 378H
Onboard Parallel mode Normal
Power Management Setup
Power Management Disabled
PM Control by APM Yes
Video off option Susp,Stby -> off
Video off method V/H Sync+Blank
HDD off after Disabled
Doze mode Disabled
Standby mode Disabled
PCI master activity Enabled
Com ports activity Enabled
LPT post activity Enabled
HDD ports activity Enabled
DMA ports activity Enabled
VGA activity Disabled
IRQ3 (com2) Enabled
IRQ4 (com1) Enabled
IRQ5 (lpt2) Enabled
IRQ6 (floppydisk) Enabled
IRQ7 (lpt1) Enabled
IRQ8 (RTC alarm) Disabled
IRQ9 (IRQ2 redir) Enabled
IRQ10 (reserved) Enabled
IRQ11 (reserved) Enabled
IRQ12 (PS/2 Mouse) Enabled
IRQ13 (Coprocessor) Enabled
IRQ14 (Hard Disk) Enabled
IRQ15 (Reserved) Enabled
PCI Configuration Setup
Slot 1 using int# Auto
Slot 2 using int# Auto
Slot 3 using int# Auto
1st available IRQ 9
2nd available IRQ 10
3rd available IRQ 11
4th available IRQ 12
PCI IRQ Activated by Level
PCI IDE 2nd Channel Enable
PCI IDE IRQ Map To ISA
Master Arbitr. Protocol Weak
CPU->PCI Mem Post Enable
CPU->PCI Memory Burst Enable
PCI Master Burst Enable
